Question about Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph
Pump 635 impeller shaft is broken, can't find another, thanks
Here is a simple solution to your shaft impeller problem. First, you need to buy a brass (non-ferrous) round bar about 1/8 inch thick. Any other metal types WILL NOT WORK. Cut about 4 1/2 inches from the brass bar and verify it will fit in the impeller. If it does not, then you need to re-size it. The best way to do that is place it in a drill press and use a metal file (the reason for the 4 1/2 size). As the brass bar rotates, press the metal file against it until a desire size is reached. You may have to remove it from the drill press from time to time and see it will fit into the impeller. When the correct dimension is found, place it back in the drill press and use a medium grid emery cloth to smooth it down. Remove it from the drill press and cut it to the proper size (3 1/2 inches). Remember to round out both ends smooth before re-installing it back in the pump. Reassemble as normal and you are done!!! This should take about 30 minute to perform including installation. I did this to my Intex pump and it runs very smooth and have not problems with it.
Posted on Jun 16, 2011
  • TFED Jun 16, 2011
    Note: If you find that the 1/8 inch brass round bar is too small, then try 3/16 inch. It is better to buy a size that is a little bit bigger than the hole in the impeller since sizing it down will give you the correct dimensions.
  • Ron Davidson
    Ron Davidson May 12, 2014
    WHO CAN MAKE ONE OF THESE I DONOT HAVE EQUIPMENT
  • 4 Answers
I tried the brass rod and it worked great! Only my pump is a Krystal Clear model 637R. What I found after disassembly was a ceramic shaft ~3" long...it was broken at the top and bottom. The impeller is the same piece as the rotor that contains a powerful permeate magnet. I went to Home Depot, they didn't carry brass rod so I lucked out buying a 3" 10-32 flathead Phillips screw. Using my drill motor I chucked the screw and ran the drill while first filing the head using a ******* file then the threads. Flipping the screw over repeat filing until 1/8" is reached. Use a mill file to finish the final .010. I used some 600 grit to polish smooth. I reassembled and the pump is smooth and quiet now. I think if steel screw or other ferrous material it acts as a short
circuit magnetically and might over heat. Good luck.!
Posted on Sep 04, 2012
  • 640 Answers
Intex is notorious for not offering after market parts for their pool filters and pumps. Because these systems are relatively inexpensive and are designed for smaller pools, it is almost always just as easy and cheap to replace the pool filters altogether. The only way that you are going to find a replacement part is to find someone that has an old one that is not being used. Even then, it might not be economical to replace it. I know this is probably what you didn't want to hear so I apologize.
Posted on Apr 26, 2011
    New Friend:
The stainless steel rod wear resistance worse than ceramic rod. would you mind change it with ceramic material? Seamark specialized in manufacture ceramic rod, which has good wear resistance and high density,low noise. and the price is also acceptable.
Linda: info@smkceramic.com
http://www.smkceramic.com/
Posted on Sep 04, 2015
A stop-gap MacGyver alternative:
I found that a #7 aluminum knitting needle was the correct diameter for the shaft (4.5 mm) I cut a 39mm length out of the needle, and discovered it contains a ceramic like material. I installed it in the pump, and It worked great for several weeks.
This apparently is not a permanent solution like the brass rod, but on a summer holiday weekend, Walmart and similar stores do sell knitting needles, but not brass rods. Also, you can cut the knitting needle with a saw and file the edges smooth. Not everyone has a drill press.
I opened the pump to find out why it failed. As you can see in the picture, ythe aluminum needle is just too thin, and wore through. Maybe a Stainless steel rod would hold up!
Posted on Jul 16, 2015
  • Linda Huang
    Linda Huang Sep 04, 2015
    would you mind using the ceramic rod?
  • gromittoo Jun 13, 2016
    I looked everywhere for ceramic rod, but I could not find anyone selling the correct size. After going through Knitting needles, I gave up, and used a different pump (much smaller).
3 Suggested Answers
tinkerbill
  • 12 Answers
SOURCE: Need Intex Pump model #635 impeller
You know, I have made some amazing repairs on plastic items using nothing more than a soldiering iron! If you have the piece that broke off, you can carefully melt it back together. You can add more to the weld if you match the type of plastic but not too much or you imbalance it. In this case it looks like PVC. To repair it without the missing piece, form it out of epoxy putty, roughly shape it just before it sets up solid, & sand to finish.
Posted on Jan 02, 2010
SOURCE: need impeller for 635 Krystal Clear pump
You can't. This exact thing happened to me at the end of last year. All the fins are broke. We ended up upgrading to the pump, and now this one overheats after 30 minutes and shuts off!
Posted on Jun 30, 2009
How to tell if impeller/pump is bad? The impeller wobbles on the shaft.
I suggest that the impeller has failed ( broken off the shaft)
possible cause is something( coins , bobby pins, bra wire etc ) went through the pump git jammed and broke the impelller fitting on the shaft
fix is normally a new pump assy. unless you can get access to a good second hand unit.
Sep 08, 2015 | Washing Machines
Remove impeller from Waterway 502n22c
To remove the impeller you first take the front face plate off to expose the impeller. Then isolate the shaft from the motor with a pair of needle nose vise grips and using a pair of channel lock pliers grip the end of the impeller and rotate counter clockwise to un thread it from the shaft. If the shaft seal has been leaking there may be to much corrosion to turn the impeller in which case it needs to be broken off.
May 13, 2013 | Waterway 5HP Executive 56 Frame Spa Pump...
Broken Impeller
INTEXSTORES.COM CARRIES ALL THE PARTS TO FIX YOUR IMPELLER.
Aug 29, 2010 | Intex Krystal Clear Model 635 Pool Filter...
I have a ao smith sp 1520 2 hp pool pump. the impeller broke off the shaft. how do i change the broken impeller please
Remove the back of the motor ... you will find there are flats on the shaft. Put your 7/16 or 1/2 open end wrench there and with your other hand, spin off the broken impeller.
Aug 22, 2010 | AO Smith 2 hp Swimming Pool - Jet / Well...
Impeller keeps breaking , can i buy a new one wo replacing the whole pump
normally Impellers don't just break,, it may be misaligned or even a cracked or broken spline in the hold down ,, I checked on this pump,, it doesn't say if it was the T model or not, But from what I have searched,, No parts are available for this model,,
Aug 02, 2010 | Intex Krystal Clear Model 635 Pool Filter...
Intex Krystal Clear Filter/Pump Model 635 replacement parts for the pump
my intex 635 pump impeller is broken i need a replacement part. i do not have the money for a new pump.
Jun 30, 2010 | Intex Krystal Clear Model 635 Pool Filter...
Pump will not draw water in from skimmer.the pump seems to work fine except that need help?
ON A HAYWARD #1 BROKEN IMPELLER OR PLUGGED ,#2 SHAFT SEAL #3 LID SEAL #4 TANK CRACKED.. LOOK FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY USE YOUR ZIP IN YOUR SEARCH .. YOU WANT THE IMPELLER WITH THE BRASS SHAFT ! ASK FOR IT HECK DEMAND IT !... YOURS IS PLASTIC = PLASTIC THREADS (JUNK) . IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 23, 2010 | Hayward 3/4hp Super Pump Inground Pool...
Pump fan blades have broken off, I"m looking for a replacement part.
Unfortunately, you're not alone on intex pump failures... in fact there's people intending to start a class action suit against the company because of the pump impellers failing and there are not parts available for replacements...and their customer service people aren't much help either.
You may be able to buy an inexpensive complete 635 pump, but it looks like an different model may be a safer bet.
Sorry to be the bearer of lousy news.
Aug 02, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Need impeller for 635 Krystal Clear pump
Jun 28, 2009 | Intex Krystal Clear Model 635 Pool Filter...
No water flow in pump
The impeller in the pump unit could be broken. If there is water flow into the pump, but no flow back to the pool, the impeller is most likely broken.
Make sure the hoses are not hooked up backwards.
Jun 20, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph Logo
3,577 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
