Question about Pioneer Televison & Video
No power with main switch & remote, only click sound & green LED instantly turn red, no power Pioneer SD641HD5
  • 319 Answers
Hi Dowy,
This is a sure sign of a power supply failure. You will need to replace the bad capacitor(s), or replace the whole PS board.
This is not usually a user serviceable replacement, if you attempt to go alone, be aware of present voltage even when unplugged!!
Brian
Posted on Aug 04, 2008
    Genius:
  • 1,447 Answers
Hi-
If this is a projection TV, im suggesting to check the bulbs for your television, it might need replacement. Bulb might be busted already, bulb is a consumable part so you can order it from your manufacturer.
Thanks for using FIXYA, keep me posted for inquiries.
Replaced power supply and reset still on light no sound just a flashing green light
Remove Mains Plug and press Standby switch from LED Panel for 30 sec.
Press Input & Ch Down Switch from LED panel and plug in and start LED
LED will start and "K" will appear on screen
Press Ch Down & Vol Down switch at same time
You will get 1/10 page on screen
Go to 9/10 page by pressing left & right button from remote
Select EEP and press Ok button from remote
After 30Sec remove main plug and restart LED.
Dec 13, 2015 | Sharp AQUOS LC-32D44U 32 in. LCD TV
After replacing power supply and resetting tv still only have green flashing light
Remove Mains Plug and press Standby switch from LED Panel for 30 sec. Press Input & Ch Down Switch from LED panel and plug in and start LED LED will start and "K" will appear on screen Press Ch Down & Vol Down switch at same time You will get 1/10 page on screen Go to 9/10 page by pressing left & right button from remote Select EEP and press Ok button from remote After 30Sec remove main plug and restart LED.
Model no. 32A33 lcd sharp tv. no picture. power red led glows. with remote on green led comes. no picture. some times sound is coming.
Main board fault. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
Apr 04, 2014 | Sharp LC-32A33M LCD TV
Aoc l32wb81
The set is not responding to remote control. There should be a voltage loss, from its main power retulator board.
May 07, 2013 | Televison & Video
Sony bravia screen just stays on black and wont go to picture.
It sounds like a main board failure but could be a power supply issue as well. The set will need to be diagnosed
Oct 01, 2012 | Sony Bravia Kdl - 60Ex700 60 inch 1080P...
Pioneer KEH-8031ZT connection diagram of power and speakers
There are two kinds of pioneer color codes:
pre 1999
P o w e r Memory (+12v Constant) Orange Ignition (+12v Switched) Red Ground (-) Black Illumination Yellow Phone Mute Yellow/Black Power Antenna Blue S p e a k e r s Right Front (+) Gray Right Front (-) Gray/Black Left Front (+) Green Left Front (-) Green/Black Right Rear (+) Gray/Red Right Rear (-) Black/Gray Left Rear (+) Green/Red Left Rear (-) Black/Green
and 2000 or newer
Memory / Constant 12V(+) Yellow Switch / Accessory Red Ground Black Illumination Orange/White Antenna Remote Blue Amp Remote Blue/White Left Front (+) White Left Front (-) White/Black Right Front (+) Grey Right Front (-) Grey/Black Left Rear (+) Green Left Rear (-) Green/Black Right Rear (+) Violet Right Rear (-) Violet/Black headunitwh.gif
Jul 01, 2011 | Car Audio & Video
Looking 4 pioneer fhp5o5md manual
If its a typical pioneer stereo the wiring is as follows
black/ground
red/switched power
yellow/12 v constant
orange/dimmer control
blue/ power antenna or amp remote turn on
grey/right front +
gray black/ right front-
white/left front +
white black/ left front -
violet right rear +
violet black/ right rear-
green/ left rear +
green black/ left rear -
Hope that helps ya out
Apr 03, 2010 | Pioneer Car Audio & Video
Pioneer Pro-118 won't turn on
Take off back cover. The problem power board is to the right of the board where the power plug feeds into the TV. There is a large white fuse right bend the power plug. With a meter it read ok; about 8 inches deeper into the TV on that board was the resister next to two fuses. My 4 amp 125 volt fuse did not read on my meter. After replacing, it worked fine. Check all three fuses while you're in there.
Feb 12, 2008 | Pioneer PRO-200 60" Rear Projection...
Amlifier not working
connect your remote turn on and your problem will be solved
Sep 23, 2006 | Crunch BlackMaxx BLX2000D Car Audio...
Televison & Video Logo
62 people viewed this question
Top Pioneer Televison & Video Experts
Electro Med Services...
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
