Question about Phase Linear UDV9010 Car DVD Player
The car radio is locked on volume and station and can not be changed.reset button does not work
    Champion:
  • 255 Answers
HI. take it to the mechanic for repairs
Posted on Sep 22, 2011
How can I get my car radio unstuck from one station?
Try disconnecting the negative ground (-) cable from the battery. That will disconnect power to everything including your radio. It might reset it self when you restore power by reconnect the negative ground cable to the battery.
May 19, 2014 | Pioneer Deh-4100 Single Din Cd Player...
On my 2004 X Type Jag only the volume switch works on the radio unit its self cant change stations play cd of use the steering wheel controls as i said all i can do is turn the volume up or down? any ideas...
Did you find the problem with your radio Terry? I have a 2005 X type and the radio has just suddenly started doing exactly the same thing - cant change radio station or use steering controls, only the volume knob works.
Dec 05, 2012 | Cars & Trucks
It seems as my stereo is locked up. I can't
Your question is lacking some detail , is this a stock radio , after market , and what brand and model . Pictures can help , depending on the siuation code be s radio key is needed or if it's after market do you have a remote ? Try to change stuff with that , could be buttons inop or worst case it's just done. Good luck
Aug 31, 2017 | Alpine CDA-9884 Car CD/ MP3 Player
Locked up. buttons don't respond no sound. no change in screen. clock and station stuck.
hold your volume and mode button down for 3 or 4 seconds and release. This will reboot the radio.
Dec 02, 2009 | Delphi SKYFi3 XM Radio Receiver
Buttons don't work. Sometimes when I click Source button several times, radio gets turned on if I have enough luck, but in most cases it's pointless), then I can change nothing. Volume change, programm...
Try resetting it. Remove front panel, on main unit is an indent that says reset, insert ballpoint to reset and replace front panel. Everything should now work although you will need to reset stations and clock.
Apr 18, 2009 | Sony CDX-L480X CD Player
2004 PT cruiser, Can't change the radio station
just like any computer, unplugging it for 30 seconds or so may cause it to revert to initial settings.... if you take the battery terminal off you will reset everything and that is not necessary.... find the fuse for the radio and yank it.... see if it helps. IF NOT, probably a burned programming mode... hope you like that station....
Nov 19, 2017 | 2004 Chrysler PT Cruiser
Hello
Volume + power resets it - making the player turn off lets you know that the reset work
Will it play non-radio music files fine?
Once again, when you change the radio station, you must press the play or right-pointing arrow button, or it will just continue playing the last radio station that you had it turned to
If it still won't change, then autoprogram the unit and select presets like it suggests in pp.32-35 of the manual
Jun 13, 2008 | Philips GoGear HDD6330 MP3 Player
LDC Screen
Reset method is power + volume + at the same time
Probably, however, you just need to go to the new station and press the play button to confirm the radio station change - then it will play the correct station
Phase Linear UDV9010 Car DVD Player Logo
Top Phase Linear Car Audio & Video Experts
Lyle Siemens
Lyle Siemens
Jaime Hernandez
The Audio Lab
Are you a Phase Linear Car Audio and Video Expert? Answer questions, earn points and help others
