Question about Toro LX466 22HP Lawn Tractor 13RT61RH244
Is there a triple grass catcher/bagger option for the LX466, model 13AT61RH048?
Cutting grass but it isn't going into the bagger?
grass catchers need special shaped or good blades to throw the cut grass into the bag
check/ replace the blades
May 06, 2016 | John Deere D130 22HP V-Twin Foot Pedal...
Grass catcher doesn't fit
Do you a plate to attack to back of tractor with 4 bolts.
Feb 04, 2014 | Husqvarna Tractor Bagger
I canot get a bagger kit for the 54inch cut lawn tractor in UK, can a 48, bagger be fitted and altered to fit which I can get in the UK
I have never seen a catcher for this size of deck, Husqvarna do not offer one, i am sure the deck aperture is different from the 48" machine, if the catcher is available in the US, would they just supply the upper and lower chutes? the 52" deck produces a vast amount of grass, so will fill the boxes very quickly, you would spend more time going back to the dumping area than actually mowing, mulching would be a much better option, if you have to collect would a tow sweeper not be better, it holds more grass, and you would not have issues with poor draught, and grass blocking in the chute ( a big problem with noise compliant machines, and damp grass , and side ejection )
Oct 10, 2012 | Husqvarna Lawn Tractor - 54in. Deck, 26...
How to attach a john deere grass catcher
Make and model are important and would help. Generally they are pretty simple. Some older models you had to bolt a mounting bracket to the rear corner of the frame and then a support slipped into the bracket. Some newer models have a drop in feature (these have rounded ridges on the back of the frame and have horizontal slots cut in them). On these the support bar simply drops into the horizontal slots then a swinging bar slips into 2 holes on the fenders to support the rearward hanging weight. The most important part is getting the right bagger model for your model. If it is a very old model that discharges grass out the back of the deck you may have a hard time finding a bagger at all. If you have a side discharge just make sure you are getting the right version for your tractor. If your tractor has a smooth flat back you need the version that has a bolt on mounting bracket. If it has the rounded vertical humps you need the newer version.
Oct 01, 2012 | Garden
Bagger won't pick up green grass
There could be a couple of reasons for a bagger not picking up clippings. One could be a clog in the ducting or in the air venting from the catcher (if applicable). Second could be worn out blades that can not generate the power to move the clippings to the catcher.
If this is really helpful, please rate.
Jul 10, 2011 | John Deere Garden
Wheels and grass catcher basket
I am guessing but is your problem that the front wheels do not not grab the yard well when bagger is getting full? I had this problem and I installed weights on front wheels on rims.
Feb 24, 2011 | Garden
Cut grass clippings does not get picked up by riding lawnmower
When using a bagger, you need correct blades on mower or Worn blades will cause the deck not to get the vacuum needed for the bagger to pickup.
Aug 22, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
How do I install the grass collector
Assuming that you have the correct grass catcher..... Install the discharge deflector at the deck discharge. This is the smaller piece that bends 90 degrees. It will slide into clips on the deck when you have the deck's plastic deflector raised up. Next, install the bagging assembly. It's pretty straightforward. Lastly, install the plastic chute (tube). Push it in the grass catcher (bagger) opening, and then pivot it over the deflector and down onto it to seat it. Connect the straps.
Best regards, --W/D--
Aug 10, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Mtd bagger not bagging ...its 100 deg today grass is short and the tube keeps clogging up w /grass it wont go into the bagger .how can i fix the problem??? chris
The MTD web site has a list of items to check:
http://support.mtdproducts.com/cgi-bin/mtd.cfg/php/enduser/std_adp.php?p_faqid=68&p_created=1027017166&p_sid=tq2XafGj&p_accessibility=0&p_redirect=&p_lva=214&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTQsMTQmcF9wcm9kcz0wJnBfY2F0cz0wJnBfcHY9JnBfY3Y9JnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9YmFnZ2VyIGNsb2dz&p_li=&p_topview=1
Aug 10, 2009 | Gaiam Reel Lawn Mower Grass Catcher
Toro LX466 22HP Lawn Tractor 13RT61RH244 Logo
102 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
