Question about Microwave Ovens
Hello, We have a Franklin Industries Blender Model # FR1355 which still works very well. However both of the silicone/ rubber seal rings for the bottom of the glass/ stainless containers have been misplaced. It would be a shame to have to discard a properly working appliance for the sake of a small rubber seal. Can you suggest where to get replacement rings? Thanks in advance for your assistance, JK
5 Suggested Answers
tiway1
  • 100 Answers
SOURCE: glass turnable replacement
check with www.microwaveglasstrays.com
Posted on Jun 30, 2008
tiway1
  • 100 Answers
Toll free 1-877-894-0035
Posted on Dec 19, 2008
richroth
  • 9472 Answers
SOURCE: I need the bottom seal
Here is a contact list for Hitachi so you may order your part.
Posted on Jan 09, 2011
  • 8909 Answers
SOURCE: I lost the sealing-ring for
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Posted on Mar 31, 2011
I have a blender thats been about 20+ years old... However, although I continue to use it well, lately it has been subject to leaking and other issues. I suspect that the rubber part (to hold the liquids...
Do you happen to know the make / model of your blender? If you do, you should be able to go to the manufacturer's website and order a replacement "o-ring".
Aug 17, 2011 | Microwave Ovens
Is the blades supposed to come off when I take the container off of the blender.. My blender is brand new sat for 3 or 4 years after I bought it. . The first time I used it , it was extremely hard to get...
You did not specify a brand or model number of your blender; however, most blender jars will lift off their power base without turning or with only very little turning motion to release them from the base. The blade assembly should NOT come off as you remove the blender jar from the power base.
Were you successful in removing the bottom ring which normally screws on to the bottom of the blender jar from the powerbase?
You should make sure you have properly attached the blade assembly for your brand/model.
The blender blade assembly should be held on to the bottom of the blender jar by the bottom ring which screws on clockwise; most will have a sealing gasket that fits between the blade assembly and the sealing surface of the blender jar to prevent any leakage while in use. It will take much more turning to unscrew the bottom ring to release the blade assembly than it should to release the bottom ring from the powerbase.
Assemble your blender jar and blade assembly and try a dry run by placing on the powerbase, giving a couple of bursts of power, and then seeing if you are able to remove without the blender ring unscrewing.
Make sure you are comfortable with the action required to remove the blender jar from the powerbase before you put in to use.
Jul 31, 2011 | Microwave Ovens
I lost the sealing-ring for my blender. How can I get a new one? solveig
I hope this helps.
Mar 31, 2011 | Microwave Ovens
I purchased the Danco 80701 "Repair Kit for Delta, Aquasource, and Glacier Bay Faucets with #70 Ball" so that I can repair a leak in my Delta kitchen faucet. The instructions on the package are...
Sounds like the old style center-control delta type faucet, rubber washers describe older type but still good. The rubber seats have holes in middle, supply water to the cylinder which diverts water to the spout, and has a seal over top of ball allowing stem for handle.
Think they are talking about flex-hose type faucet accessory getting clogged, Maybe: lift the flex-hose faucet housing off the center-control faucet body? Water to it runs directly from center-control faucet and if broken seat gets in narrow line could inhibit spray.
Kitchen faucet spout too has an O-ring under where it connects to the faucet body. Unscrew large nut where meets the faucet body unit (slip-joint pliers), once free of threads, spout should pull straight up, easy or slight tug. I use bent paper clip to remove old one trying to save it in one piece so as to get exact size (that's important) to replace, push on one side then other.
Jan 13, 2011 | Microwave Ovens
I have a Waring Blender 51BL25 that just stopped working. Can it or should it be repaired?
Hello Patricia. We are clearly living in an age of replace rather than repair. The reason is simple. Repair shops generally will not look at a small appliance for less than fifty dollars. Putting that much money into a repair than may be short lived doesn't make sense when a replacement blender is often less than fifty dollars on sale. Joe
Thanks for choosing Fixya!
Nov 23, 2010 | Microwave Ovens
Can i bake cookies on my sharp carousel with bake setting. can i use an ordinary micro safe plate or do I need something else?
yes you can bake cookies in the carousel on BAKE I suggest those new rubber looking bake plates help a lot to reduce the moisture that makes them soft.
I think they are silicone rather than rubber, i am sure you know the ones I mean
Thanks for using FIXYA
Oct 11, 2009 | Sharp R-1850A Convection/Microwave Oven
What product should be used to lubricate the support wheels under the glass turntable? Sucessive cleanings of the glass has not eliminated noise from the wheels during operation.
Use silicone spray, never an oil nor oil based products. The silicone spray has a carrier that evaporates after spraying, leaving only pure liquid silicone behind. It is non-toxic and non-flammable once the carrier has evaporated.
You can get silicone spray at hardware stores, and most cans come with a tube that assures you get silicone only where you intend to.
Sometimes, the noise is from gummy buildup on the wheel axles. If you can remove the wheels (some are attached to removable rings), try soaking in ammonia and hot water then scrubbing lightly with an old toothbrush. Then rinse well. If this is the cause of your problem you won't need the silicone spray.
Mar 22, 2009 | Microwave Ovens
Microwave Ovens Logo
46 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
