Question about Pioneer Televison & Video
SOURCE: Pioneer projection TV vertical lines on screen
do you have full picture and did this set have any faults before this,possible image burn on crts.from previous horizontal fault.
Posted on Aug 18, 2007
SOURCE: Pioneer SD-643HD5 64 in. Rear Projection
You need to replace convergence chips - they are behind the large black heatsink
Posted on Sep 02, 2007
SOURCE: HELP TO FIND IC's CONVERGENCE GENERIC NUMBERS
STK392-180 http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
SOURCE: remove and replace pioneer convergence board
pioneer sd p6085-k convergence blue
Posted on Nov 04, 2010
SOURCE: I have a 64 inch
Ha Ha, I had the exact problem. I think mine is the same model of TV as well, I have a 64" Pioneer made in 2003. So my TV would hit the slanted ceiling above my stairs as I tried to move it down. I first took off the wheels of the TV and this helped but it was not quite enough. So since the bottom of the TV is flat with exception of the side boards and the front trim. I removed the front trim temporarily and cut off the side boards with a circular saw till even with the flat bottom. This gave me 2.5" more clearance which was enough to fit the TV downstairs. Hint if you scribe the cut line with a utility knife it will reduce chipping.
TimBilt
Posted on Aug 05, 2011
Mar 28, 2011 | Pioneer SD-643HD5 64" Rear Projection...
Dec 14, 2010 | Pioneer SD-643HD5 64" Rear Projection...
Sep 06, 2010 | Pioneer SD-643HD5 64" Rear Projection...
Jun 19, 2010 | Pioneer SD-643HD5 64" Rear Projection...
Dec 30, 2009 | Pioneer SD-643HD5 64" Rear Projection...
Apr 15, 2009 | Pioneer SD-643HD5 64" Rear Projection...
Jan 25, 2009 | Pioneer SD-643HD5 64" Rear Projection...
Nov 03, 2007 | Pioneer SD-643HD5 64" Rear Projection...
Aug 01, 2007 | Pioneer SD-643HD5 64" Rear Projection...
May 22, 2007 | Pioneer SD-643HD5 64" Rear Projection...
223 people viewed this question
