Question about Frigidaire Affinity ATF7000E Front Load Washer
Frigidaire affinity front load washer, ATF7000e wont start led read PAU 30 any Help?
  • 4,323 Answers
Hi
PAU error means cycle has been interrupted; it is not a right error though. Please follow these steps:
1. Wake the washer by pressing any button.
2. Wait 5 seconds.
3. Press and HOLD the Start/Pause and Cancel buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an E followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash.
Post back with the complete error code for further assistance. Hope this helps..
Daniel
Posted on Mar 26, 2011
Code saids pau
If the PAU error does not clear after properly restarting the washing machine cycle, push "Cancel," then disconnect the power cord. Wait a few minutes and restore power to see if the error code goes away. If not, the control board may need to be replaced.
Apr 11, 2014 | Frigidaire Affinity ATF7000E Front Load...
Code pau
For pause mode, just push the start/pause button again.
The front door will not lock and pau is flashing on my frigidaire affinity front end loading washing machine and it will not start
You will need to replace your door lock mech.
On the bottom of the door seal lift the edge and locate the retainer spring and remove the spring then remove the door boot,unscrew the door lock disconnect the wirng and replace the door lock mech
Oct 07, 2011 | Frigidaire Affinity ATF7000E Front Load...
Won't start led read pau then 45
Hi!!
The error code 45 means control board communications problem. And Pau shows when the cycle was interrupted, try disconnecting the unit form the wall outlet, wait for about 10 secs. and plug it back in. If this do not clear the error code. Replace Board.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Nov 02, 2010 | Frigidaire Affinity ATF7000E Front Load...
Pau err
I have had that problem before...Try unplugging it and plugging it back in...sometimes it's almost like dealing with a computer.
Apr 22, 2009 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity ATF7000E Front Load - shows pau and the number of minutes left
Its an issue with the front door sensor and the motherboard. I had to replace the mechanism since it could no longer work. Cost me 250 and almost 2 years later its happened again
Sep 15, 2008 | Frigidaire Affinity ATF7000E Front Load...
Err pau
Press "stop" & "cancel" together for over 10 seconds to clear the display; and continue your..........
And rate me pl.......
Dec 01, 2007 | Frigidaire Affinity ATF7000E Front Load...
Err Err err err err pau
Nov 15, 2007 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity ATF7000E Front Load Washer Logo
228 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
