Question about Air Supply Silencer Spa Air Blower 15 Hp (110 ) ()
The air blower "silencer" will
Start snow blower runs for 3 min. and starts to over heat checked oil its ok then stats to shut down like its not geting oil
Why do you say its over heating .Runs for 3 minutes the oil is OK .
Do you understand how the choke works .
bacsicly you prime the mechine in cold condutions 3-4 pumps choke to max throttle at 3 /1/4 .
Start backing off the choke after 3-to4 mins .
The choke shuts the fresh flow down to the engine in cold condutions ware it needs more fuel then air to run.
When the engine starts to get hot it can't run with out fresh air to mix with the gas it won't run anymore because there is to much gas and not enough air
Its simple fool prof will work everytime if you adjust it right
Mar 01, 2015 | Craftsman Snow Blower / Snowblower Bottom...
My Air Supply 2.0 HP Silencer Blower is too strong (water moving to fast, bubbles are too strong). How do I 'slow down' (or back off) the strength of the blower?
Thank you for posting your question here on Fixya.com.
Two ways you can try to modify it...one electrical and the other mechanical:
1) Add a motor speed control rheostat to the control circuit to vary incoming line voltage and therefore reduce the speed across a wide range of settings. The cost is higher than a mechanical fix and many people do not like to work with electricity. It also requires a means of enclosing the switch to keep it safe from the elements if outdoors.
2) The easier fix is to add a ball valve to the stand pipe the blower sits on. Add it above the check valve and then slowly close it with the unit running to gradually reduce the air flow to an acceptable level.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Apr 21, 2011 | Air Supply Silencer 2Hp 120 Blower (...
I have a fedders portable a/c unit and it works for five minutes and it then shuts down. The circuit braker does not trip and I plugged the unit on different locations with the same results. The unit has...
Thanks for your information that " The unit has very cold air".It's cut off by indoor coil sensor.
Reason for shut off in 5 minutes.(There are one or more reasons for the problem) Check as follows.
1. Evaporator coil,air filter and bower wheel full of dusty. Service your unit completely.
2. Check rpm of blower motor. If less rpm replace capacitor.
3.If all above is o.k and still problem means defective coil sensor. Replace it.
Hope, it's helpful?
Jan 19, 2011 | Fedders A6X05F2D Air Conditioner
I have a builder installed Goodman GDS80904BHA that is approximately 5 years old. Recently, when the furnace completes a heat cycle, approximately 1-2 minutes after the cycle has completed and after the...
I would guess that the fan off setting on your limit is set a little to high. If you have the manual you can see what it says about changing the running time for the fan after the burner has shut off look on the control board and you should see two switches,one to set the time for burners to fire before main blower starts and one to set time for fan to run after burners shut off. To help with the problem you are describing set fan run time up so fan wii run longer. Hope this helps. Thaks.
Nov 22, 2010 | Goodman GDS80904BNA Open Flame Heater
Just had new ruud heat pump installed 5 days ago, it blows cold for the first few minutes and then warm but not warm enough, called installer he said thats the way heat pumps work and he will stop out when...
In most newer operations, the indoor fan motor will come on first before the actual heat comes on.
However if you shut off the power and Remove usually
the upper panel. Located on the inside on the right hand side there is information that will tell you what
the temperature rise should be between the supply air and return air.
Usually this requires a thermometer that you can insert about 5ft away from the furnace, for both
the return air and supply air.
If the temperature rise calls the unit to be between 25
and 45 deg F, Adjusting the blower speed lower should give you warmer air maybe as much as 10deg, but 5 deg seems more probable
Jan 25, 2010 | Ruud UBHC Air Conditioner
Weathermaker 8000 furnance flashing code 31 blower comes on for 90 sec .. then shuts off .. then other fan goes on.. don't see any flames or lighting goin on can you help?
31 PRESSURE SWITCH DID NOT CLOSE OR REOPENED - If open longer than five minutes,
inducer shuts off for 15 minutes before retry. Check for: - Excessive wind
- Proper vent sizing - Defective inducer motor
- Low inducer voltage (115VAC) - Defective pressure switch
- Inadequate combustion air supply - Disconnected or obstructed pressure tubing
- Low inlet gas pressure (if LGPS used) - Restricted vent
If it opens during blower on-delay period, blower will come on for the selected blower
off-delay.
33 LIMIT CIRCUIT FAULT - Indicates
Nov 04, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Duo therm briskair conditioner
check your power supply, 5 minutes is about the time it takes to blow a breaker
Aug 11, 2009 | Heating & Cooling
Air conditioning
You will need a new blower motor, sorry.
Jul 31, 2008 | Heating & Cooling
Blower
The blower operates on air temperature. To make these units as energy efficient as possible the thermo disk that turns the blower on is calibrated (Non-adjustable) to turn the blower on a a certain temperature. Just a pilot light is enough to bring the blower on in 106+°F. You could completely shut down this system in hot weather and save gas from the pilot and electrical from the blower.
Jun 23, 2008 | Heating & Cooling
Readyheater portable forced air 170,000btu/hr
reset switch my heater did the same thing after 5 sec of running
Dec 20, 2007 | Reddy Heater-170,000 BTU Kerosene Deluxe
Air Supply Silencer Spa Air Blower 15 Hp (110 )  () Logo
322 people viewed this question
Top Air Supply Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
Are you an Air Supply Garden Expert? Answer questions, earn points and help others
