Question about Acer X193W+BD Monitor
I'm trying to get my Xbox 360 to play on my monitor while my monitor is also connected to my main computer. The computer is connected to the monitor via a VGA cable, and the 360 is connected via an HDMI cable. However, whenever I try to change the input, the screen flashes black for a moment, then goes back to the the first input. I cannot get it to change to the HDMI channel. What am I doing wrong and how can I fix it?
  • Paul Bade Jul 25, 2017
    Hi kathryn_felt, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Have you tried a different HDMI cable?
sandrew
  • 2961 Answers
SOURCE: input not supported when trying to play a game
the game will need to be set to the same screen resolution as your monitor or the best that suits, beccause of it being widescreen, so look in the graphic or video settings in the game, or change the resolution of your monitor to suit the games highest setting. This is done by right clicking on your desktop, down to properties and then the settings tab in the next window and then move the slider at the screen resolution box.
Posted on Apr 25, 2007
Riziel
  • 116 Answers
SOURCE: monitor goes black
Sorry to have to tell you this, but this is common in LCD monitors. The reason that it is going black when it boots is for one of two reasons. You either have a bad power supply that powers your LCD or your LCD's backlight is blown. These can be repaired or you can purchase a new one. But if it goes black 9 times out of 10 is because the backlight is bad. These can be repaired!
Posted on Nov 26, 2007
headstrong
  • 233 Answers
SOURCE: Acer AL1716 blank screen but powers.
Probably a bad inverter board, the inverter board powers the bulbs that display the image. this is VERY common problem on all LCD tv's,laptops and monitors.
usually a small transformer blows open on the inverter board. the innverter needs to be replaced if this is the this case.
Posted on Jan 05, 2008
SOURCE: connecting dvi cable straight to acer monitor
The cable box is probably outputting a resolution the monitor is not compatible with. Computer monitor and television resolutions are usually different, and not cross compatible in some cases.
For example, wide screen monitors are usually 16:10 aspect ratio, while TV is usually 16:9 aspect.
The AL2216wbd is a 1680x1050 display, while HD TV is either 720p (1280x720) or 1080i (1920x1080).
If your cable box is set to 1080i that would be too high for the monitor. You will need to set it to output at 720p, and even then you will probably get a vertically stretched picture since the monitor has a taller aspect.
Posted on Jul 28, 2008
  • 5 Answers
SOURCE: Acer AL2416W 24" Monitor switches off and on after a few minutes
it must be your videocard. Also use a DVI cable, don't use VGA.
Posted on Jan 29, 2009
Trying to hook up xbox 360 to computer monitor
Unless you monitor is HDMI capable I don't think it is possible without some sort of adapter.
http://godora.hubpages.com/hub/How-to-Connect-Your-XBox-to-your-PC-Monitor
Jan 19, 2014 | Acer P205H Widescreen LCD Monitor
Tip
How to resolve Xbox 360 disc read errors. Xbox will not play disc.
Is your xbox360 having trouble reading disc? In this guide I will provide some common solutions to help you fix your disc read issues.
1)Remove any memory devices or usb flash drives.
2)If the disc you are using is excessively scratched, this can cause the xbox to have trouble reading the disc. You can use a damp soft cloth to try and clean the disc. Grab the disc by the edges and using a soft damp cloth lightly wipe the disc from the center going outward.
3)Try removing your Xbox hard drive and then play a disc. Turn off the console. Locate the hard drive on the top of your system(depending on how you have it positioned). Press the release button on the hard drive.
If your system can read disc without the hard drive attached then you may need to replace the drive.
4)Clear the Xbox360 cache. Clearing the cache may remove updates to certain games. Keep this in mind.
Go to System Settings in the My Xbox menu. Select Memory, highlight your storage device and select Clear System Cache. Try and play the disc.
If after the above steps you are still having trouble. You may want to contact Microsoft Xbox live support to have your system serviced. You can find the support information in the link below,
Xbox Support
Regards,
G33k
Visit the links below for other technical articles
Connect your Nintendo Wii to the internet
Connect your Xbox 370 to the internet
Connect your Nintendo DSi to the internet
Connect your PlayStation 3 to the internet
How to access Windows 7 God Mode
Tips to clean and speed up your computer
How to configure a wired/wireless home connection
How to access facebook when it is blocked at school
Extensive list of device driver links for common electronic devices
Keywords
xbox 360 disc read errors, xbox 360 disc read, 360 disc read errors, xbox disc read issues, xbox 360 disc read issue, xbox 360 scratched disc, xbox360 disc not playing, xbox360 cant play disc, xbox360 disc will not play
on May 14, 2011 | Microsoft Xbox 360 Console
I cant connect my xbox 360 to my rca colortrak plus stereo monitor pip model f27676bc and i dont have a remote, i dont have a remote so i want to know how to cha nge the input maualy so i can play my xbox...
go to the manu in TV and put aux, and connect the xbox 350
and try it. However will be a good idea that you will your instr. manual for tv download free.
wwww.fitness.manualsonline.com
God bless you
Sep 28, 2012 | Televison & Video
What do i have to download to play xbox 360 games on the computer?
Sorry, but you cannot play Xbox 360 games on your computer. If you want to connect your 360 to a computer monitor, you can use HDMI if you monitor supports it or pick up a VGA adapter for the Xbox 360
Mar 06, 2011 | Microsoft Video Game Consoles & Games
Could you tell me in steps how to conect to xbox live
Step 1 Form your Xbox 360 you need to be connected to the Internet by a straight LAN line or wirelessly. You can test you connection by going to the setting screen on your Xbox 360.
  • Step 2 Once connected to the Internet for your Xbox 360 go to your main account screen and find the tab that says "Join Xbox LIVE" click on that link then follow the simple instructions that the Xbox LIVE will provide. At this point you should have a name in mind for your gamer tag.
  • Step 3 Xbox 360 LIVE has several different options available for memberships. They are a monthly, 3-month and 12-month membership accounts. I would recommend a simple one month account if you just wanted to check out the features offered on XBOX 360 LIVE. If your an avid gamer and love to play games online with friends, the 12-month Gold membership is the way to go.
  • Step 4 Once you've completed the process of joining Xbox 360 LIVE, they will send you a confirmation email confirming your membership. Now you can log on to Xbox 360 LIVE and start doing this like customizing your avatar and playing online multi-player games.
  • May 26, 2010 | Microsoft Xbox 360 Elite Console - Black
    How do we connect xbox consul to imac and play
    There is no way to connect the original XBox console to an imac's monitor. There was never an hdmi or VGA connector that was worth buying made for the Original XBox.
    The XBox 360 has a nice VGA adapter. But no the original XBox, sorry!
    Apr 14, 2010 | Microsoft Xbox Console
    EA Sports server issues
    yes they are talking about on xbox live for online play. put it this way the ea servers are like an engine that hasnt been run for 30 years. they are all gumed up and broke down. they probably are planing a new ea game and dont have enough memory for online play for all the games
    Jun 24, 2009 | EA - Electronic Arts Tiger Woods PGA Tour...
    X box 360
    You can't get an IP address on the Xbox that way. You need to get an IP address from a device that works as a DHCP server such as a residential router. Connecting the Xbox to the PC will do nothing for you.
    Nov 08, 2007 | D-Link DI 514 Wireless Router (DI-514)
    My moniter no longer turns on
    Sounds like you blew something out inside. Take it to a tech. We can't possibly diagnose it in this forum.
    Jun 23, 2007 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
    Strange problem with XBOX-360 games
    Try changing the display settings of the XBOX 360 or the TV. Also make sure you possess the latest updates for the Media Center Edition: http://www.microsoft.com/downloads/results.aspx?pocId=38DF6AB1-13D4-409C-9
    Feb 22, 2006 | Microsoft Xbox 360 Console
    Acer X193W+BD Monitor Logo
    70 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
