I have an element flx 3710 flat screen tv. It does not have a power button and I lost the remote, how do i turn it on
  • 718 Answers
Look along the bottom of the front of the set. The buttons are marked located there.
VOL- VOL+ CHAN v CHAN ^ MENU INPUT power/on
You can also get the user's manual from;
http://www.retrevo.com
by entering the necessary information.
Posted on Mar 27, 2011
How to turn on element flx 3710 without remote
Operate the power switch on the front panel
May 18, 2017 | Element Televison & Video
I had sound but no picture on my Element Electronic FLX 3211B LCD Television Set. I replaced two capacitors, and now I have lit screen by turning on the tv on the side panel. Remote does not control the tv...
You might have bad capacitors still that you cannot see. The only way to be sure is with an ESR meter. Check all the connections on the boards again to be sure that the sensor for the remote did not come off.
Sep 08, 2012 | Element Electronics FLX-3211B 32 in. LCD...
Closed caption is on the screen and i can't remove it.
On your TV Remote:
CAPTION Cycles through the Closed Caption:
?? Anlalog Closed Caption:CC1/CC2/
CC3/CC4/TT1/TT2/TT3/TT4/Off
?? Digital Closed Caption:Service1/
Service2/Service3/Service4/Service5/
Service6/Off
May 05, 2011 | Element Electronics FLX-3211B 32 in. LCD...
Element 32 inchTV want turn on. When hitting the power button it turns on for a quick second display the digital tv words and click back off.
This is a protection circuit that prevents the tv from coming on (to stop damage of the components) ....you need to check your voltages off the power supply and make sure they all read well (EX: 24v12v5v etc). Also look for popped capacitors that would make the values lower than need be for the tv to power on properly.
Once you repair the power supply then you may need to replace other components if needed!
Please rate if this helps! :D
Mar 08, 2011 | Element Electronics FLX-3211B 32 in. LCD...
I have a Element tv model #FLX-3710 and when I turn it on I only get a blue screen.
checked first the signal from ur cable/antenna it seems you haven't a signal from there that's why u got only a blue screen....
Dec 26, 2010 | Televison & Video
Element (FLX-3210) I lost sound when I unpluged my pc plug from my laptop to the TV. Then I went to the tv output which had picture on the screen but no sound. Once the power was turned off the tv it...
The tv turn on now have power and LED power light indicator is on and solid green?Yes,than it is the main Tuner signal board had a short some where and it is the problems and the causes.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Nov 29, 2010 | Element Electronics FLX3210 32 in. LCD TV
I have an element 37in. flx-3710 tv. lately whwn i turn it on the screen stays blacks and flickers for a few minutes untileventually the picture appears.however the picture is either washed out or so dark,...
ldq781, I think you or electronics technician should investigate the units internal "switch-mode-power-supply/cold cathode-fluorescent lamp electronic ballast circuit(inverter) for "failed" "swollen" electrolytic filter capacitors and or "poor quality" soldering of the electronic components to the copper foil traces of the printed circuit board(power supply board) The first thing to do is visit YOUTUBE for video clips of lcd monitors being repaired for these typical types of "failures" which are most common to both types (monitors and lcd tv's) After you do your research then return here and leave additional reply if you still need help. 12fixlouie
Sep 24, 2010 | Element Electronics FLX3210 32 in. LCD TV
Tv not responding to remote or buttons on tv
Well okay!
couple of questions?
1) Is a multi remote - does it or can it control other components like a DVD player or a VHS or Cable box?
2) If it does - you may have selected one of these other components to control
NOTE: Try depressing the TV button and then try the other buttons such as channel or volume to see if it's back working.
Blessings,
A/V Guy
Nov 19, 2009 | Element Electronics FLX-2210 22 in. LCD...
I lost the remote and cant find a universal that is explicitly for this TV - do you know any univeral remotes that will work and what is the code Model Number of Element Electronics TV is FLX3211B Also the...
you can go to menu options, than find programming options.
Look for an option called "autoprogram" and select it. It will search and set all available channels.
There is universal remotes for this tv that you can find by googling "elements electronics remotes":
Jun 06, 2009 | Element Electronics FLX-3211B 32 in. LCD...
Televison & Video Logo
152 people viewed this question
Top Televison & Video Experts
