Question about Vacuums
I have a zing ear ze-03 gw 100 electronic dimmer switch for a lamp that is defective. Where can I purchase a replacement switch (same or equivalent)? Thanks!
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 27 Answers
Zing ear ze-03 is available on this link:
https://www.ceilingfanswitch.com/product/lamp-dimmer-zing-ear-ze-03/
Posted on Jun 24, 2017
ORDER THE SWITCH ASSEMBLY AT WWW.KENSELECTRONICS.COM
Posted on Jun 13, 2011
Instructions for replacing a bag in a bissell zing model 2203 cannister vacuum
Hello, this is Ava with Think Crucial.
You may view the online manual for your Bissell model on how you can replace dust bag by clicking the link below.
Bissell ZING 22Q3 SERIES User Manual Dust Bag Replacement
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Mar 01, 2012 | Bissell Vacuums
I have a hunter fan and my contractor switched the load and green wire in the new zing ear switch. I just need to switch the 2 wires and I can't get the switch open. can anyone help?
I found out that mostly they are connected with fastons. You can get them at hardware or auto parts stores.
From what I've heard Zing Ear switches are a bear when it comes to taking apart or taking off wires.
Good luck.
I hope this helps. If it does, I would appreciate a vote. Thanks,
Handie Andie
Apr 03, 2011 | Vacuums
Hello, I am looking for a wiring diagram to install a touch/dimmer switch by "Comfort" mdl # RH-934B - Darjung Ind Ltd. It has a standard lampcord (two wires) coming from it as well as one...
the black and the white will go to the lamp ,eg,output.The yellow is the sensor wire which should be firmly attached to the metal base of the lamp
Mar 25, 2011 | Vacuums
Need replacement switch for zing ear ze-256 switch. Used in a lamp, has off, lo and high positions
I have the same issue. I bought a ZING EAR dimmer but it won't fit in the space allowed by the pole the lamp is made from.
The switch is simple, the positions are: Off/On/Half.
The switch uses a diode to provide half voltage to the lamp. I have two solutions and I'm not sure which I'll use yet. First, I can use the dimmer but I'll have to get a 500K pot with a switch to fit in the hole. I'll attach wires to connect to the PCB of the dimmer. In essence, I'll remote mount the 500K pot.
The second solution is to get a rotary switch like this:
http://cgi.ebay.com/Lamp-parts-3-way-2-circuit-rotary-switch-5-8-TR-302-/380282854100?pt=LH_DefaultDomain_0&hash=item588a9fdad4
and use the diode salvaged from the original lamp switch. In my switch the diode is still good.
I know this sounds awfully complicated, but it's really not.
Randy.
Email me and I can give better details if you like.
westerville5595-now@yahoo.com
Mar 05, 2011 | Vacuums
A 40 W fluorescent lamp gives out more light than a 4o W filament bulb.explain whether the fluorescent lamp is actually using electrical energy at the same rate as the filament bulb??
The lamps are both using 40 watts of energy, but the fluorescent lamp gives more lumens (visible light measurement) than the incandescent.
Fluorescent gives at least 5000 lumens for 100 watts.
Incandescent gives 1750 lumens for 100 watts.
You can see that if you had a 100 watt incandescent, it would be 1750 and you would only need 35 watts of flourescent.
Gary
Feb 19, 2011 | Vacuums
The on/off switch doesn't work on my floor lamp electric trait # PL/F 27W 6500K UL. E224694 Is there a replcement for it or is there a repair place here? Cary, N.C.
Suggestion: Someone just might want to peek inside the Electronic Ballast Enclosure mounted within the unit's base when they have the time and inspect for signs of failure similar to what I found in mine before insisting on buying a New Switch and risking disappointment first-cut. Burnt components are a dead giveaway, as (usually) is a blown fuse, although there's nothing wrong with jumpering that fuse to see what lights-up again or smokes, atcmb.
Those little snap-in SPDT switches are really rather rugged - your unit just MIGHT have a defective switch and nothing more - but I for one do tend to doubt that notion. Best double-check first before ordering.
Sep 13, 2010 | Vacuums
Carbon motor brush source?
unfortunatly the only way you could purchase the carbon brushes is from a vacuum parts dealer directly. the brushes will most likely end up costing you close toth price of a new motor anyway. sometimes its best to just get a new motor as the newer designes rotate teh brush much faster for better cleaning.
Oct 25, 2008 | Filter Queen Majestic Canister Vacuum
Power Switch for Fantom Lightning
I think that the marking is 5E4, not SE4
Nov 18, 2007 | Fantom Vacums Lighting Canister Vacuum
Vacuums Logo
1,715 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
