Question about Frigidaire Affinity ATF7000ES Front Load Washer
Can I reverse the door on my new Frigidaire Affinity front loader?
    Scholar:
  • 116 Answers
Hi, as far as i know you can only reverse the dryer, the wiring for the door latch doesnt allow you to reverse it on this washer.
Sean
Posted on Mar 26, 2011
Reset error code 90on an fridgidare affinity front load washing machine
Most front loaders have door latch problems, try to deactivate the latch.
Jul 12, 2015 | Frigidaire Washing Machines
Why does the door unlock before going into the cycle
Hey friend, that's a great question!
It sounds like you may have an issue with the door strike or door latch on your Frigidaire front loader. I would recommend contacting a professional to come out and properly locate the reason to why your door is unlocking before going into a cycle. -Matt
Sep 22, 2014 | Frigidaire Affinity ATF7000E Front Load...
Code E 21 Error on Affinity Washer Front Loader
I've had problems starting my washer because the door does not close properly, and then I get an error or pau code
What has worked is to unplug the washer for a minute, close the door, and then plug it back in. it then starts normally with 2 pushes on the start button
Jul 06, 2014 | Frigidaire Affinity ATF6000F Front Load...
How can you tell when the door lock is bad on a 2011 frigidiare affinity front loader washer
Mike,
I understand that you are wanting to know how to tell if the door lock is going bad on your Frigidaire Affinity washer. One way to tell is if the washer is telling you that the door is not shut or locked when it is. Try to reset the appliance for 3 minutes, by either unplugging it or resetting the circuit breaker. If you are still having trouble with the door lock, I would suggest to have a local authorized technician to come look at the lock and fix it if necessary.
-Best Regards-
Jan 14, 2014 | Frigidaire ATF6000ES Front Load Washer
Reverse door swing
Hi halej308 - Unfortunately Frigidaire front load washer doors cannot be reverse.
Sep 29, 2012 | Frigidaire Affinity ATF7000E Front Load...
Front end loader washer door does not line up to close
Check to see if the door is sagging. If so, contact Frigidaire you might be able to adjust the door and save money rather than replace the switch.
Aug 02, 2012 | Frigidaire Affinity ATF7000E Front Load...
I have the frigidare affinity front loader washer and just started it up. It stopped about 5 mins into the cycle and the indicator light says dr. I tried to shut the door but that didn't work. So I...
You need to replace the door lock mechansim. Fairly easy to do yourself, just pull the spring strap off the rubber door gasket and remove 2 screws holding door lock. Install new door lock and re-install door gasket and spring strap, and WALLA! she works:)
Nov 28, 2010 | Frigidaire Affinity ATF7000E Front Load...
I want to buy a Frigidaire Affinity washer because I found one at a good price, BUT several reviews say there is a moldy smell that is awful. Any advice?!
Leave the door open to allow the tub area to dry after use (both top and front loaders). Front loaders also have a propensity to hold a small amount of water in the rubber door seal. Wiping this up after each use will also help prevent the growth of mould.
Nov 23, 2010 | Frigidaire ATF6000ES Front Load Washer
LTF6700FS - (affinity) front loader - door lock will not engage - latch looks fine and child safety feature is not on
Sheck the hinche if is twist or pull that the most comon problem. If is that, disconect the door ahd replace the hinche. If the hintch is OK sheck the lock set up if is of place. Some time is being forced to open or to close it and bend the lock clip.
Aug 11, 2009 | Frigidaire Affinity ATF6000F Front Load...
Washing Machines Logo
704 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
