Question about NAD T763 Receiver
There is no sound and I have an S CLIP message on the screen
Hi this is Fardeen i Just want to know how to send a picture by MMS with my Nokia N70. plz let me know as fast as u can i did active my mms but dont know how to use it kindest regards
  1. PRESS THE MENU BUTTON ON YOUR PHONE
  2. LOCATE THE MESSAGE FOLDER ON YOUR PHONE
  3. CLICK ON NEW MESSAGE
  4. SCROLL TO ''MULTIMEDIA MESSAGE''
  5. INSERT THE PICTURE,SOUND CLIP OR VIDEO CLIP
  6. TYPE IN THE SUBJECT OF THE MESSAGE THAT YOU WANT
  7. TYPE THE CORRECT RECIPIENT'S NUMBER
  8. THEN SEND IT.
Feb 11, 2011 | Nokia N70 Smartphone
Clip won't restart -dead?
it sounds dead to me
is there a master reset or anything on there?
i dont have oone myself but i have similar things
Feb 18, 2010 | SanDisk Sansa Clip MP3 Player
Where is the a c filter located on 2006 lincoln l s
To Replace: This is done with the hood opened and located at the bottom of the windshield on the passenger side.
Note: The fasteners are reusable.
Remove the right side of the cowl vent screen.
Remove the two-part pin-type retainers and separate the Velcro attachment of the rubber hinge cover to the rear outboard corner of the cowl vent screen.
Pull up the cowl vent screen to release the lower clips.
Push on the RH corner of the filter to release the clip. Release the LH clip and remove the cabin air filter.
To install, reverse the removal procedure
To Reset:
Press the STATUS control to access the System Check function, the message center will display A/C FILTER XXX% RESET FOR NEW.
Press and hold the RESET control to set to 100% , the message center will display IF NEW FILTER HOLD RESET.
After a successful reset, the message center will display A/C FILTER LIFE SET TO 100%.
Feb 16, 2010 | 2006 Lincoln LS
A flashing envelope is constantley on the screen
I had the same problem, it was because someone sent me a media message that couldn't be displayed. If you've gotten a text with a sound clip or picture lately, try deleting that message and it will hopefully go away.
Nov 30, 2009 | British Telecom Synergy 2110 Cordless...
My sansa sanclip just froze.iit was charging and
Hi.
You have two Solutions.
Solution 1:
Resetting the player:
1. Slide and hold the Power switch up for approximately 20 seconds.
2. Release the Power switch.
3. To turn the player on, slide the Power switch up then release instantly.
Solution 2:
Updating the Sansa Clip Firmawre:
  1. If it's not installed yet, download and install the Sansa Firmware Updater.
  2. Connect your Sansa Clip to the computer.
3.1. Assuming there's a new firmware available, the following message will appear on your lower right task bar. Click on the balloon message:
3.2. 3b. OPTIONAL: You can also manually run the SansaUpdater from your programs files. Most likely it will be under All Programs > SanDisk > Sansa Updater > Sansa Updater.
4. Select the Firmware check box.
5. Click Download Now. Firmware downloads and updating starts.
6. Click Finish after the firmware has been downloaded.
7. Disconnect your Sansa Clip from the computer.
8. A "Firmware upgrade in progress" message will appear on the Sansa Clip's display screen. The device will turn itself off after the firmware is updated.
Additional Help:
Sansa Clip Manual Guide.
If you need any Further Help Just don't Hesitate Asking me.
Thank You For Using Fixya.
Good Luck.
Nov 03, 2009 | SanDisk Sansa Clip MP3 Player
I have a samsung a777. I cant receive or send text........it saids it successfully sends but My friends dont get my text and they said they try to send me a text and it sends but i dont receive it can you...
Check out this link below to download a PDF manual, software, and more for your phone. Just copy and paste into your browser.
http://www.samsung.com/us/consumer/mobile/mobile-phones/at-t-phones/SGH-A777EGAATT/index.idx?pagetype=prd_detail&tab=support
Check out the section on Messaging page 65 in your manual:
Important!: When creating a message, adding an image, a sound file, or a video clip to a text message changes the message from a text
message to a multimedia message.
Important!: Adding an image, a sound file, or a video clip to a text message changes the message from a text message to a multimedia
message. This also changes the Options that appear in this menu.
Note: A multimedia message should only be sent to a phone which can
support the receipt and display of this message type.
Note: If you exit from this View screen, you will need to go to the Messaging ➔ Inbox screen, the Recent Calls screen, or you will need to dial your Voicemail contact to access your messages.
Note: Messages can also be accessed by navigating to your Inbox (Menu ➔ Messaging ➔ Inbox).
Messaging Settings page 72 in your manual:
You can set up various options for using messaging services.
1. When the Idle screen displays, press the Menu soft key,
then select Messaging ➔ Messaging Settings.
2. Select the type of message settings that you want to
change.
• Text Message
• Multimedia Message
• Voice Mail
• Push Message
• Broadcast Message (SIM card dependent)
3. Press the Select soft key or the key.
Hope this helps, let me know if I can help you with anything else. It would be very kind of you if this does work for you to please rate me or leave a short note. I would really appreciate it. Thank you for your time.
JimmyC
Oct 16, 2009 | Samsung SGH-a777 Cell Phone
How do I change SMS alert tone on Samsung Tocco Lite mobile
Go to Menu > Settings > Phone profiles > click the two arrows beside Normal (or whichever one you use) > go to the top of the screen and select New Messages > Choose Message Alert Tone > Sounds > choose the file.
Oct 13, 2009 | Cell Phones
Samsung D75 digital camera. Having taken a clip in movie mode, I have a 'standby' message on the LCD screen. Can't seem to get rid of it to take another clip. When I press shutter button I just get a bleep...
Problem resolved. My own stupid operating fault. It appears that, in movie mode, you don't just press the shutter button to start a shot, you have to hold it down for a moment. Not made clear in user manual, but I should have twigged earlier.
Thanks for your contact/help.
Aug 29, 2008 | Samsung Cameras
NAD T763 Receiver Logo
66 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
