Question about DSMiller DS Miller Inc. Equivalent of LENOVO - IBM Z60M-2530 Laptop AC Adapter (839431951540)
Ibm z60m hangs at the logo on boot until I press the enter key then it boot to the operating system
  • 794 Answers
Hi gmmcclure,
If you are encountering issue that you need to press the enter key before you can enter Windows, this is a possible cause of recent changes on your computer. Try to configure the BIOS to address this isuue. Just follow the procedure below:
1. Start by turning off the computer.
2. Then, turn on the computer. As soon as you turn it on start tapping F2 button.
3. Once you're already inside BIOS press F9 button then select YES by pressing ENTER.
4. Afterwards, hit on F10 then press ENTER once again.
5. Wait until your system boot up and kindly observe your system.
Hope it helps.
Thank you for using Fixya.
Posted on Mar 26, 2011
Change boot cd rom bios300
Your IBM 300 series desktop computer is normally set to boot its operating system directly from the installed hard disk drive.
There are some cases where you may want to boot from a different device, such as loading from the floppy drive to install a new operating system.
In order to change the boot order on the IBM computer you need to access the Basic Input Output System (BIOS) menu.
Close any applications that are still running.
Turn off the IBM 300PI computer and then turn it back on again.
Tap the "F1" key when the "Configuration/Setup Utility" prompt appears at the bottom of the screen.
Tap the down arrow key four times to highlight the "Start Options" entry.
Press the Enter key.
Highlight the "Startup Sequence" entry and then press Enter again.
Scroll down and highlight "First Startup Device."
Press Enter. Scroll through the list of available boot order devices.
Highlight the device you want to use, such as "CD Drive" or "Floppy Drive," and press Enter.
Press the "Escape" key twice.
Highlight "Save Settings" and then tap Enter.
Power off the IBM computer and then power it back on.
May 06, 2013 | IBM 300PL (PC 300 PL 733) PC Desktop
My ibm m-50 has not install windows 8, why?
Step 1:
Are you upgrading or installing from a disk ?
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system (note after you have loaded the operating system you should go back and change the first boot device to your failsafe or optimized defaults) after windows has loaded your computer will automatically restart it might restart 2 times one to finish the installation the next will be because the operating system is loaded and will boot from your cd during the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart otherwise it will keep booting from the cd /dvd drive
Feb 05, 2013 | IBM Thinkcentre M50 8185-E3u Pc - XP Pro -...
How set boot sequence for ibm mother board
During the boot process you will see on the screen for a very short time to press a certain key to enter setup usually the Delete or F2 key the F1 key for IBM PC 300GL
this will vary depending on your computer and operating system
or this will set the boot order
the using arrow keys navigate to advanced bios features press enter change which drive you want to boot from
hope this helps
Sep 06, 2012 | Microsoft Windows XP Professional
Como instalar windows xp en una think pad x600
hope this helps
Apr 22, 2012 | IBM ThinkPad 600X Notebook
Won't boot in safe mode
Starting an IBM Thinkpad T43 in safe mode allows you to troubleshoot technical issues that you otherwise couldn't. Often when a system has a virus or other type of malicious program, safe mode is the only way to locate and delete the problem. In safe mode, only the computer's essential programs are enabled, and only the files necessary to running the system are in use. Learn how to start an IBM Thinkpad T43 in safe mode using a few fairly easy steps.
1.Close all programs and restart the IBM Thinkpad T43.
2.Press "F8" repeatedly after the IBM logo appears, but before the operating system logo appears. If the "F8" key doesn't work, restart the computer and try pressing the "F11" key repeatedly.
3.Press the "down arrow" key to select "Safe Mode."
4.Press the "Enter" key. The computer will boot up in safe mode.
Sep 16, 2011 | IBM ThinkPad T43 Notebook
I can't fomat my computer as i don't know how to set first boot device as my DVD drive
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
but if you format your hard drive you will lose the current operating system and you will have to install another operating sytem unless you partition your hard drive and intall another operating system to that partition
hope this helps
Nov 26, 2010 | IBM (25P3294) Motherboard
IBN Z60 M- ERROR 2010: Stuck key 01
do you have a bios password set on your z60m? what type is your z60m (what number is under type on the bottom of the laptop)? feel free to e-mail me directly if you like and maybe i can help you out. lordraptor1@yahoo.com
Jun 05, 2010 | IBM ThinkPad Z60m Notebook
Compaq Presario SR12320M will not boot up Help
    • If your computer has a single operating system installed, press and hold the F8 key as your computer restarts. You need to press F8 before the Windows logo appears. If the Windows logo appears, you will need to try again by waiting until the Windows logon prompt appears, and then shutting down and restarting your computer.
    • If your computer has more than one operating system, use the arrow keys to highlight the operating system you want to repair, and then press and hold F8.
  1. On the Advanced Boot Options screen, use the arrow keys to highlight Repair your computer, and then press ENTER. (If Repair your computer is not listed as an option, then your computer does not include Startup Repair as a preinstalled recovery option.)
  2. Select a keyboard layout, and then click Next.
  3. Select a user name and enter the password, and then click OK.
  4. On the System Recovery Options menu, click Startup Repair. Startup Repair might prompt you to make choices as it tries to fix the problem and, if necessary, it might restart your computer as it makes repairs.This should solve your problem
Aug 17, 2009 | Computers & Internet
Access BIOS
what computer brand and model is it ?
Robert
Sep 01, 2008 | IBM NetVista PC Desktop
Replaced cmos battery
Try this:
Press and hold F1; then power on the computer. Hold
F1 until the “Easy-Setup” menu appears.
If you have set a password, the “Easy-Setup” menu appears
after you enter the password.
Plagiarized from:
http://www.wimsbios.com/phpBB2/topic9023.html
Mar 28, 2008 | IBM ThinkPad 600X Notebook
DSMiller DS Miller Inc. Equivalent of LENOVO - IBM Z60M-2530 Laptop AC Adapter (839431951540) Logo
26 people viewed this question
Top DSMiller Computers & Internet Experts
David Payne
David Payne
Are you a DSMiller Computer and Internet Expert? Answer questions, earn points and help others
