Question about GPS
I have 2 hand held lowrance globalnav 200 that wont turn on with either batteries or the cigarette lighter plug in. 1 makes a crackling noise when i try to turn it on, the the other one turns on and immediately shuts off when i let go of the on/off swich. Any idea what is wrong with either of them and do you know a company that fixes older hand held lowrance gps's?? PLEASE help- over 900 grouper rocks and ten years of my life are at stake!! Thanks so much! John
SOURCE: x3-02 nextar gps
three step solution, easily correctable. wrap in towel, smash with ball peen hammer, gently lay in trash. You should have no more issues after this.
Posted on Mar 22, 2008
  • 6 Answers
SOURCE: GPS Won't Turn On
dude check it the car charger really isnt a chargers. what! i kno i kno. the '' proper" way of chargin ur battery is thru the computer or u can purchase a a/c to usb adapter and charge it on the wall but the car charger is a trickle charge as long as the green light is coming on that means that there is power going to it and support is going to just tell ur charge the batter the right way over and over again try charging on the computer for about four hrs then see whats up if its still not working then call tech support and make sure u tell them that u tried charging it on the computer for four hrs
Posted on Jan 21, 2009
  • 3 Answers
SOURCE: Porsche cigarette lighter is bigger than standard cigarette plug
Found a cigarette lighter assembly that is the standard DIN/SAE size that is a direct replacement for the one in my car.
Posted on Sep 01, 2009
HarryHarley
  • 343 Answers
SOURCE: GPS plug do not fit in car cigarette lighter
Buy a adapter for your cigarette lighter socket that has multiple sockets with one that will fit the Garmin adapter.
I've never heard of a problem you are having??
Are you using a Garmin plug?
If not get one.
Posted on Feb 24, 2010
sharcnet
  • 2130 Answers
SOURCE: Garmin Nuvi Doesn't turn on
Try resetting the unit. The procedure can be found here:
http://www.sharc.net/discus/messages/6/313.html?1268661443
- Jim
Posted on Mar 19, 2010
The monitor keeps making crackling noises
Try relocating the monitor to rule out external interference, if no the monitor will need to be checked for bad connections such as bad solder joints.
Mar 09, 2012 | Summer Infant 02100 2.5 inch Color Hand...
Tip
Automobile Radio Secuity Code
Tired of searching for your vehicle in dash receiver security code after the battery has been disconnected? Here is a simple device that will keep that from happening.
You will need a cigarette lighter plug, a 9 volt battery snap-on connector, and a standard 9 volt battery. The snap-on connector can be retrieved from an old smoke alarm. Solder the connector to the two wires from the cigarette lighter plug; Making sure the polarity is correct ( + to + and - to - ). The center tip of the plug is positive and the two outside springs are negative. A piece of shrink tubing slipped over each wire before soldering makes a neat and safe connection. Connect a fresh 9 volt battery to the snap-on connector. When the vehicle's battery needs to be disconnected; Plug the device into the cigarette lighter before the battery is detached and power will be maintained to the radio.This eliminates the need to input a security code.
on Feb 27, 2010 | Car Audio & Video
Reader plug in not working - not powering up reader - cigarette fuse good - which wire on the daignostic plug in should have power
THE OBD 2 GET IT BATTERY POWER AT THE DIAGNOSTIC LINK CONNECTOR.WHEN YOU PLUG IT IN TO DATA LINK.THE OBD 1 SCANNER WILL POWER UP AT CIGARETTER LIGHTER OR AT THE BATTERY.MY SCANNER IS POWER UP 9 VOLT BATTERY WHICH BRINGS IT UP UNTIL I POWER UP USING CAR LIGHTER.
Mar 10, 2010 | 1999 Oldsmobile Alero
Lowrance 350 wont turn on
Plug it in. Is there a green or red light on the iWay 350? If red, it will probably turn on now while plugged in and just needs to be charged. If it won't charge, it is malfunctioning. If no lights come on when plugged in, the 350 is malfunctioning.
Does the green light come on the cigarette lighter adapter? If not, the fuse in the cig adapter is blown or the power cable needs to be replaced.
I
Jul 13, 2009 | Lowrance Boating
Powering a car amplifier
Bad idea. The wiring leading up to your cigarette lighter is usually a cheap 16 gauge wire. The amplifier will not be able to draw enough amperage through that power source. You could however, use the positive on your cigarette lighter as your remote for the amp. This would be helpful if your cigarette lighter turns off and on with the car.
Jun 24, 2009 | Car Audio & Video
Unit (tom tom 1xl) turning off
One hour is about the time the unit will run without a power source.
You need to check that the cigarette lighter is working. Check the car fuse.
Check the fuse (one of the six bumps) on the cigarette lighter plug has not blown.
Is the cigarette lighter / Tom Tom lead damaged in any way?
Peter
Mar 01, 2009 | Tomtom One XL GPS Receiver
Zumo 450 Power Through Cigarette Lighter
You should be, Check to make sure the fuse isnt blown on either the cigarette lighter plug or in the plug that has the wires coming out of it.
Nov 24, 2008 | Garmin zumo 550 GPS Receiver
My Garmin Nuvi (200 I think) freezes..
My recomendation is to use the original accesory for cigarete lighter. I'll give you an example: when I connect my Nuvi 200 to any other USB cable (computer or home charger) its behaviour is like you said - it "says" that is connected to a computer and remains in stand by. But when I connect it to cigarette lighter (but note - the original one) the nuvi 200 recognize it as a car power source and works. The battery symbol disappear from screen and it works perfectly. When I turn off the engine or simply unplug the device from cigarette lighter (not from nuvi !) it recognizez that and ask me if I want tu turn it off on remains on on own battery. If I make no option the nuvi will turn off automatically after some seconds. So it recognize perfectly the car adapter and its behaviour is adapted to a car.
Oct 08, 2008 | Garmin Nuvi 350 Car GPS Receiver
Can't lock onto satelite signal!!
Sounds like the aerial. There is a very fine wire in the center of the male aerial plug. If this is bent then you will have that problem. Aerials are hard to get, dealers say they are obsolete...update your model. Cheers, Peter
Feb 27, 2008 | Lowrance Globalnav 310 GPS Receiver
Camera power not coming on
well hard to answer but i suppose you use nimh batteries if now work vist your nearest service center also clean the contacts inside
little help i hope thx ake
Feb 07, 2008 | Fuji FinePix S3100 Digital Camera
GPS Logo
46 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
