Question about Lexmark C510 Laser Printer
Always says paper jammed but there is no paper jaming inside
    Genius:
  • 1,087 Answers
  • Power off the printer for 30 seconds. If the issue persist, follow the steps below.
  • Open the printers front cover and make sure to check for any paper left inside the printer.
  • Verify that you are using media within specification for the printer in terms of size and weight and that the paper is being fed from the appropriate input source.
  • Make sure the paper trays are loaded correctly. Incorrect loading of the trays can result in poor paper feed performance
  • Posted on Jul 26, 2011
    Hp4200 duplexer paper jam
    If it jams every time, remove the duplexer and look for a piece of paper on the metal plate as the paper feeds out of the duplexer and back into the machine. Also use a file folder to push any jammed paper out from inside the duplex module.
    Mar 14, 2015 | HP LaserJet 4200 Printer
    Paper jam
    check if there is any piece of paper is jamed inside your printer i think that is why your printer always says paper jam
    Jul 08, 2010 | HP DeskJet F380 All-In-One Printer
    Paper jamming sign lit up but no jammed paper seen
    hi there shuld be paper inside or may be when u removed jamed paper not proper way some pice of paper struck in the sensor thats why paper jamed lit up clear the whole paper path it will solve problem if not there is any path sensor not working good just clean the path sensors
    thanks
    May 14, 2010 | Toshiba e-Studio163 Copier
    Paper jamming sign on but no trapped paper seen
    thanks
    May 14, 2010 | Office Equipment & Supplies
    Paper jamed
    Hi
    Thanks for using FixYa. Perform the steps below in order to solve this incidence:
    1. Disconnect the power cord or power supply adaptor from the rear of the HP All-in-One product.
    2. Remove the paper pack remaining in the input tray.
    WARNING - Do not try to remove the jammed paper sheet yet. Trying to clear a paper jam from the front of the device can damage the print mechanism. Always clear paper jams through the rear access door.
    1. Open the rear access door or the two-sided printing accessory.
    2. Gently pull the jammed paper sheet out of the rollers.
    3. If the paper tore when it was being removed from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the device. If not all the pieces of paper are removed from the device, paper jams are likely to occur again later.
    4. Replace the rear access door or the two-sided printing accessory.
    5. Restart the printer to continue the current job.
    Please seee this link for more details--
    HP Photosmart C5280 Paper jam error
    Please do rate the solution and revert for further assistance.
    Thanks
    Rylee
    Aug 14, 2009 | HP Photosmart C5280 InkJet Printer
    Printer problem
    Hey there.
    1-st of all please tell us what printer model do you have and what kind of paper are you using.
    Mar 19, 2008 | Office Equipment & Supplies
    Jams EVERY TIME
    Where is the paper jamming? Out of the paper tray or under the drum or in the fixing unit? Did you make sure you have the paper tray set up to the correct paper size and orantation for the paper in the paper tray and dose it happen at any other time and where is it jamed up at. Need more info.
    Mar 14, 2008 | Sharp AL 1631 Copier
    Panasonic kx-fp 342 papaer jam
    paper jam or missfeed always due tothe following:-
    1-malefunction of paper feeding system due to broken gears belt chain please check smoth mechnical movement and apply light grease in gears and change any broken part.
    2-something is blocking the paper path (staplers-pins)droped inside.
    3-malefunction of paper detection micoswitch please confirm free operation for the lever in mechnical one and clean of dust and dirt from optical one,
    Mar 06, 2008 | Panasonic KX-FHD351 Plain Paper Thermal...
    Clear paper jam
    Sometimes there is little bits of paper stuck inside a sensor causing the printer to detect a jam. Use an air duster can to and shoot some air at all the sensors. The sensors look like little plastic fingers that get pushed down when paper moves over them.
    Jan 02, 2008 | Lexmark X5150 All-In-One InkJet Printer
    Dell 1700N
    We had a printer with the same problem, and turning the pickup wheels inside out (on the back of the paper tray) solved the problem.
    Hope this helps.
    Oct 19, 2007 | Dell 1700n Laser Printer
    Lexmark C510 Laser Printer Logo
    42 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
