Question about Pioneer Televison & Video
I have a Pioneer SH-DT510 HD set top box, the remote control has decided it will only work from about 2 feet away. I have changed the batteries in the remote with no luck, do you think its the remote or the receiver in the box, is there anyway of testing it, I don't want to get new remote if its the receiver thats stuffed. Thanks Steve
SOURCE: set top box and remote control
I have the same problem. When I move the 8300HDC away from the TV, or power off the TV, the remote responds. There seems to be some kind of RF interference, which makes no sense since the TV shouldn't emit RF, and the the box should be using IR only for remote input. My TV is a 46" LCD Samsung. Try turning off the TV and see if the 8300HDC responds to powering on and off with the remote.
Posted on Nov 18, 2007
SOURCE: samsung remote code for dish net. not working
i am in the same boat as you bud
Posted on Jan 17, 2008
  • 5 Answers
SOURCE: Dog ate my converter box remote
This site has a list of replacement remotes for converter boxes:
Posted on Jul 03, 2009
SOURCE: I bought an Alba CDVB4 and the remote isn't right
Not sure if you found the problem for this, but I had the same problem and couldn't find any reference to this except your question so thought I would put up an answer in case it can help you or anyone else.
Aparently, Alba have got hold of the codes that Toshiba use for their remote controls, so if you have a Toshiba telly an Alba product like this won't work. The only solution being to return it and get a different make.
I returned mine twice for a straight exchange thinking it was just a manufacture fault before I found this out. I then exchanged it for a Bush set top box - only a fiver more - and it now works PERFECT!
I hope this helps some.
Posted on Feb 21, 2010
  • 8617 Answers
SOURCE: Timer light will not stop flashing. can't turn on TV
Unfortunately the first generation DLP's from Mitsubishi are prone to have Capacitor failure through out the chassis. Most likely that is what your set is experiencing. I would start by replaceing the suspect caps on the DM amd The Power boards. You can get the V26 Chassis DM/Power repair kit from which also contains instructions.
Posted on Jun 22, 2010
Can't control my Dura V10 R/C helicopter more than 10 feet away...has new I need a new remote controller box?
Just bought furs v10, can't control it either. Opened it up and found battery loose, and antenna wire solder joint broken at PCB board inside helicopter. Flew it maybe 3 minutes. Not impressed!
Feb 18, 2012 | Toys
I have a 2 year old Pioneer VSX-819H-K that only recognized the remote signal from about 2 feet away. Worked fine last night. Changed out the remote batteries three times, then programed a Cox...
You have to order for the IR receiver module for the system. Also check inside the frond panel of the system is there is any durst accumulated in frond of the IR receiver unit.
May 07, 2011 | Pioneer VSX819HK 5 Channels Receiver
Remote will not control the tv. batteries is good, but nothing happen when pointing at the tv five feet away. what is cause/
hi, it could be either 1 of 2 things.
1.remote is faulty, if the remote used to work but now doesntand you are sure the batteries are good, its probably not that.
2. a faulty IR / Remote Control Sensor Board . very common problem with an easy cheap replacement. here is a link to one for $20, just remove the back of the tv and remove and replace the new board. be careful when working inside the tv, lots of fragile things in there!
good luck!
Feb 10, 2011 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Hi, wondered if you could assist please. I have a Yamaha SH DT510 Set top box that I purchased back in 2003 with my home theatre equipment, however, have experienced a problem with one of the speaker or...
What is your actual 'problem'? There's nothing in a set top box that would pick one speaker to fail unless it was, say, one of the two optional channels like the center or sub, which probably need to be defined internally. I imagine the menus would lead you there.
Otherwise, your audio equipment would be where I would start the troubleshooting.
Oh, btw, did you mean PIONEER SH DT510?
Jan 11, 2011 | Audio Players & Recorders
Antsig AP593 universal remote
Not sure if you've decided to throw your remote control away already or not. But try using the manual search code. Basically press "TV" (light blinks once), then press the "Up" channel button and the "up" volume button at the same time (light comes on permanently), then hold down "Power" whilst putting the remote RIGHT IN FRONT of the place where your tv receives signal (usually where you can see a light), and I mean right in front! Hold it down until your tv powers off. Then it should be configured and working. It took me about 1 minute or more for the TV to react and turn off. Then you can check if it turns on again and if the channels are working.
Jul 17, 2010 | Televison & Video
My dish dvr remote only works on satellite from zero inches away from reciever. The remote works on the tv from 20 feet away. Have tried wiggling the antenna, etc. Any other ideas?
Check your batteries.. Trust me on this it happens lol..Also do you have anything on top of the tv like a VCR or DVD player? That can cause that also. If your able too control the reciver with the remote than it could be a number of these things. Just check ubstructions anything that can be blocking it. Some newer model tv's have a light censor that causes the remo too stop working as well. If its a newer model like an HD tv this could be your issue as well
Nov 15, 2009 | DISH Network IR Remote Control
Direct TV remote quits working - conflict with Samsung LCD?
Turned power saving feature on the TV to low and moved the receiver about four feet away from the TV and the remotes work fine now.
Sep 03, 2009 | Samsung TV Remote Control
My Pioneer SH DT510 digital tuner has frozen can someone tell me how to fix this.
This is a common problem with this device. Mine did the same about 6 months after purchase. It is a defect and you will need to contact Pioneer to replace it. To get it to work in the short term, you need to remove the plug from the wall so that it can re-initialise.
But trust me, this is only a temporary fix...
Jul 19, 2009 | Televison & Video
Remote does not work past 2 feet away
Try holding the remote close to your head, i heard it gives better strength with car keys so why not this.
Dec 01, 2008 | Durabrand STS92 System
Pioneer 530H DVD recorder
You said that you have changed the batteries.
While you're checking the batteries, make sure that the contacts for the batteries aren't corroded or bent. You can clean them with a pencil eraser followed by a nail file. If necessary, gently bend them back to their correct position.
Try these too,
  • Go up to the receiver and try changing the channels without using the Remote Control.
  • Refer to the Remote Control setup instructions, and make sure you have the correct codes programmed for your equipment.
  • Make sure nothing is blocking the front of the receiver (e.g., furniture).
  • Make sure you are operating the Remote Control within 20 feet of the receiver.
If all the above doesnt work,
Either the remote or the receptor on the device is not functioning.
1. Use an Infrared Sensor Card to see if the remote is sending a signal.
2. If the remote is sending a signal, it used to control that device, and no other solution works, you should have a service center look at the device and remote to determine the problem and if it can be fixed.
You can visit this site for further support,
Hope my info solves your problem,
Thanx for using fixya....
Oct 01, 2008 | Pioneer DVR-530H-S DVD Player/HDD Recorder
Televison & Video Logo
94 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
