Question about Wurlitzer Jukebox CD Player
Disc player picks up CDs, puts them down, they spin and then it picks them back up without playing them.
In my experience this is usually a problem with the CD player or the CD control unit. I have had this problem with my Wurlitzer CD Carnegie and I solved it by simply taking a Q-tip, moistening it with rubbing alcohol and lightly rubbing it on the CD player's laser lens and then using the other side of the Q-tip to dry it. Over time dust and dirt can build up on the lens causing read errors, which in turn cause the jukebox to reject the CD. If that does not help, I would suggest looking into replacing the CD player or the CD control unit.
Posted on Mar 28, 2011
Sony CDP-C910 will no longer play cds or eject changer cartridge
Mine did the same thing. My player was primarily used in the garage and the cold weather may have caused my player to do the same thing. I just fixed my player. I removed the top cover and looked at the CD in the play position. In the upper right corner from the CD, you will see a spindle motor with a belt on it. Gently spin the motor back and forth carefully with your finger. I rotated it a half-spin in either direction, careful not to dislodge the belt. When I turned the player back on, the mechanism operated as it normally would and began playing the disc. I was able to eject and reinsert the magazine without any issues, solving the problem. Hopefully that will work for you.
Dec 17, 2012 | Sony CDP-C910 10-Disc CD Changer
My DVD has problem read disc DVD. When I put inside disc VCD everything is fine. I have region 0 on my dvd.
hi,
i have got the same complaint some days ago. your players spindle motor is faulty.
its winding have some problem. spindle motor is that one on which the dvd spins. when u insert the dvd it is not rotating at the required rpm. thats why it is not reading. the problem will not be with video cds . because it doesn't required a high rpm. replace the spindle motor. it will not cost a lot. its sure that ur problem will be solved.
if then also the problem remains,
your player's laser pick up unit have some problem with its DVD laser. there are two types of laser in dvd players. one for reading and playing audio cds, mp3 and video cds and the other for reading and playing dvds. in your player dvd laser have problem. dont think that these are two separate unit. the lasers are mounded in the same unit. if any of the laser get damaged you have to replace the whole unit.
if u need any more assistance feel free to contact me through fixya.
bellow is the image of laser pickup mechanism
ok
Jan 26, 2011 | Cyberhome CH-DVD 300 DVD Player
My DCM-360 has stopped playing discs after my moving house. It spins the carousel, picks up the disc and then puts it down without spinning the disc up. Laser problem or disc-spinning-motor problem or...
Had a similar problem with my Denon. When I inserted CD it takes it in but immediately stops - like it doesnt sense the CD. Same problem with Single or Multi changer. Removed cover, removed reader ( 4 screws) and found lens had fallen out. Cleaned, reinstalled with touch of super glue on rim - works fine.
Oct 12, 2010 | Denon DCM-360 5-Disc CD Changer
When playing a DVD, we experience frequent stops and starts..
It may be a dirty lens, or perhaps the drive is getting stuck.
The first thing to try, if you feel up to it, is to clean the lens. First, you'll need rubbing alcohol (peroxide isn't the same thing) and a Q-tip. Add a tiny amount of alcohol to the Q-tip and gently rub it against the lens of the laser. After a few times around the lens, use the dry end of the Q-tip to pick up any excess alcohol lying around. Put the player back together and try playing a disc.
If it still doesn't fix the issue, then the following steps can be taken.
Have a disc in the drive and while it's off, open it up. Start the drive and see if it's spinning freely. If not, then onto the next part.
Use some WD40 on the shaft of the drive motor that makes the disc spin. Just use a little bit at a time and work it in by manually spinning the spindle (what the disc rests on). Once that's finished, put the disc back in and reassemble the drive, plug it in, turn it on, and see if it spins better.
Jun 05, 2010 | Zenith DVD2381 DVD Player
Laser lens not reading disc.The disc spins,but i get no video,or audio when dvds ,or cds are played. Cleaned the laser lens didn't solve problem. Figured the laser pick up has played out.Can anyone help me...
faulty lens you will need a replacement depends on brand and price sometimes its cheaper to buy a new dvd player, i know its a throw away society but thats just the way it is
May 07, 2010 | Televison & Video
I works mechanically, but doesn't play the CD
try cleaning the lens first use a lint free swab and GENTLY clean the lens. don't use any liquid on this. if that doesn't work then load a disc and gently spin the disc when it lifts into load posistion. if begins to spin on it's own then replace the spindel motor. if it still does not spin, replace the optical pickup, the EF sensors inside the pickup no longer have the ability to read (see) the disc.
Feb 03, 2008 | Teac PD-D2380 5-Disc CD Changer
Dvd player not working
buy new one then replace it with the old one and take it back for refund
Oct 30, 2007 | Durabrand DVD-1002 DVD Player
Bad disc
I have the same problem with some of the Discs I have burned. Most people say the power supply, but I have 2 of these units so I swapped the power supply to see if that was it. The problem stayed in the one machine, ruling out the power supply.
Aug 26, 2007 | Cyberhome CH-DVD 300 DVD Player
Open Questions:
See all Wurlitzer Jukebox CD Player Questions
Wurlitzer Jukebox CD Player Logo
159 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
John Robertson
John Robertson
Level 1 Expert
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
