Question about Miele Washing Machines
Hi I can't get the washing machine door to open on model w970 please help
  • 822 Answers
Sounds like interlock has packed in.
WITH POWER OFF......
you need to remove lid...............put your hand down front of door interlock and flick the switch.................replace interlock asap.....
cheers
Posted on Mar 26, 2011
Removal of fasia on mieie w970 wasing machine to fit new on off switch.disp removed and 3 screws removed .right hand side is fixed dont want to force it.
Hi dear. Open the door. There should be 1 or 3 10mm bolts around door gasket remove them. Where soap dispenser Top LHS 3 T10 screws,remove them. Open Bottom LHS pin trap.Remove the drain hose from the cover and right underneath it, there is a clip. You need to push it down to open front panel from left to right. Then you can access it. Thanks.
Mar 29, 2016 | Miele Washing Machines
Why dose the water leak out from the Miele Touchtronic W1113 Large Capacity Washing Machine w/ Stainless Steel Honeycomb Washing Drum?
Hi dear.Please check the door gasket for any wear & tear.(Also open the door,ajar inside the door gasket, check inside of it for any fine tear or cut.)Please check for pump filter.Is it attached correctly.I hope that helps.Thanks.
Jun 19, 2010 | Miele Touchtronic W1113 Washing Machine
Door lock
Switch off. Try some WD40 on the machine lock (not on door) and open & close door many times, to ease out the lock.
Jan 28, 2009 | Hotpoint WMA54 Front Load Washer
Door of indesit washing machine no opening model no WM12X
First thing if this unit has an electric lock you probably open the door at the wrong time and threw it out of sync. First try to do another load from the beginning cycle and let it finish. If this don't work unplug your machine and then try. I hope this helps you.
Nov 23, 2008 | Indesit W 123 Front Load Washer
Hoover Washing Machine Door wont open. Please help the door opener feels slack! How do I get it to open. Its a hoover nextra. Thanks Lisa
Either clip on the door is faulty or its the door interlock in which the door locks into easily replaced by undoing the clip pullling back the door rubber and replacing ..
Aug 05, 2008 | Hoover Washing Machines
Hi my Zanussi washing machine model zwf1437 only has the power led and door led on. The program LEDs do not come on when buttons are pressed. Appreciate any info on this chris
Hi Chris,
If the door led normally goes out when the cycle starts you may have a problem with the interlock system which prevents the door from being opened when the machine is running. If the machine "thinks" the door is still open, it won't start. You could try closing the door a "little more firmly" to see if this has any effect.
If this suggestion does help you solve the problem, please give my reply a rating to help others judge my knowledge. If they do not, please give me more details so I can try to help you further. Cheers, D
Jun 30, 2008 | Electrolux Washing Machines
Error`E40
hi there e40 fault is a problem with your door interlock. get it replaced and all will be fine..
Feb 28, 2008 | Zanussi ZWD1470W Front Load Washer / Dryer
ZANNUSI TD900 Product Number 916110209 Doors can not open
Click on your brand (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line. Press "end of cycle" button & wait for 2 minutes before trying the door gently; do not force the door. & rate me if helped on this great site!!
Jan 11, 2008 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
108 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
