Question about Hotpoint HSS25GFT 25.0 Cu. Ft. Side-by-Side Refrigerator with GE SmartWater Filtration, LightTouch
Refrigerator makes clicking sound like a turn signal
  • Sean Miller Mar 26, 2011
    Are you having cooling problems also?
    Sean
  • Hotpoint Master
  • 43,501 Answers
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 27, 2011
Turn signals work but do not make sound when turned on
There is a turn signal relay usually located under the dash what makes the clicking sound when you use the tern signal.
Oct 15, 2014 | 2005 Chevrolet Chevrolet Malibu LS
How do I turn off ice maker
Good Afternoon Rsimmon5,
I see that you are trying to turn off the ice maker to your Frigidaire refrigerator, model# FRS6R5EMB. You will be moving the signal arm to turn your refrigerator off.
To begin ice production, lower the wire signal arm to the DOWN or ON position. The ice maker turns off automatically when the ice container becomes full. To stop the ice maker, raise the wire signal arm until it clicks and locks in the UP or OFF position.
If you have any trouble with your ice maker continuing to make ice after this, I recommend contacting either the manufacturer or an authorized technician in your area. Hope this helps.
-Best Regards-
WP
Apr 05, 2014 | Frigidaire FRS6R5EMB Side by Side...
Clicking sound
The clicking sound may due to voltage fluctuation or there is a fault in ur compressor...!!!! needs servicing...
Mar 23, 2012 | Frigidaire Refrigerators
1997 c1500 4.3L after I signal and make a turn my signal light lever clicks off like it should but quite often it will continue to make the clicking noise even though the lights are not coming on. It...
This sounds like your turn signal relay is sticking. If it is sticking it does not matter the position of your turn signal arm. Check the relay. It will be in your fuse box under the hood.
Oct 13, 2017 | 1997 Chevrolet C1500
My flasher make clicking sound with turnsiginal on.Installed a new one still does it.Put foot on brake and it quits and starts again making clicking sound.Whats the problem.
The problem is in the multifunction/turn signal switch.Try wiggling the turn signal switch and see if it will quit temporarily.
Dec 17, 2010 | 1998 Chevrolet Blazer
Directional signals make vitually no audible when clicking
There is a turn signal switch device found under the dash that can sometimes be placed in an area that impedes the sound from reaching the driver. Turn the signal on while parked and in a safe area and listen for the source of the turn signal sound under the dash. Many times they are found along the steering column. Use a long screwdriver touched on the actual assembly and place the handle to your ear to verify that this is the correct assembly. If it is and it's not blocked somehow, check with a parts store for a replacement and tell the you would like one that has a substantially louder indicating sound. They should be able to accommodate and once replaced should resolve this safety issue.
Feb 11, 2009 | 2004 Toyota Highlander
Turn signals wont work
replace the hazard fuse under the dash any repair shop can heklp you with it
Aug 31, 2008 | 1999 Mitsubishi Eclipse
Turning signal makes grinding noise when turned on.
this is the flasher unplug it and go get a new one
Jun 11, 2008 | 1995 Mercury Sable
Hotpoint HSS25GFT 25.0 Cu. Ft. Side-by-Side Refrigerator with GE SmartWater Filtration, LightTouch Logo
130 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
