Question about Roadmaster Woody comfortable transport Wagon
Lost assembly instructions for this wagon - Roadmaster Woody comfortable transport Wagon
  • 51 Answers
Go on line and you can find the instructions on the internet
Posted on Mar 26, 2011
Replace a brake light
COUPE The side marker lights for the SC and SC2 are part of the turn signal/parking light assembly. Refer to the procedure in this section for lamp removal and bulb replacement. Rear Turn Signal, Brake and Parking Lights EXCEPT WAGON
  1. Disconnect the negative battery cable. Fig. 5: Remove the trim panel fasteners - except wagon 84196109.jpg
    Fig. 6: Carefully remove the trim panel - except wagon 84196110.jpg
    Fig. 7: Pull the lamp assembly straight back and out of the opening 84196111.jpg
  2. Remove the trim panel fasteners, then carefully remove the trim panel.
  3. Remove the 2 retaining screws from the side of the lamp assembly, then pull the lamp assembly straight back and out of the opening.
  4. Tilt the assembly downward for access to the sockets, then twist and remove the socket(s) from the lamp assembly. Replace the bulb(s), as necessary.
  5. Installation is the reverse of removal. Fig. 8: Tilt the assembly downward for access to the sockets 84196112.jpg
    Fig. 9: Twist and remove the socket and bulb from the lamp assembly 84196113.jpg
WAGON
  2. Remove the retaining screws from the side of the lamp assembly, then pull the lamp assembly straight back and out of the opening.
  3. Tilt the assembly for access to the sockets, then twist and remove the socket(s) from the lamp assembly. Replace the bulb(s), as necessary.
  4. Installation is the reverse of removal. Fig. 10: Exploded view of the tail lamp assembly - wagon 84196114.gif
High-Mount Brake Light EXCEPT WAGON
  2. Open the trunk for access to the lamps.
  3. Locate the bulbs at the rear underside of the trunk lid. Remove the bulb(s) by twisting, then pulling straight out.
  4. Installation is the reverse of the removal. Fig. 11: Remove the high-mount brake light by twisting its socket 1?4 turn counterclockwise - except wagon 84196115.jpg
WAGON
  2. Raise the liftgate, then remove the wedge blocks from each side of the liftgate assembly.
  3. Remove the lower fasteners from the liftgate lower trim panel, by pushing in the center of each pin approximately 1?8 in. until it clicks, then remove the fastener.
  4. Insert a screwdriver or small prybar into the hole in the lower trim panel (located near the wiper pivot on the pivot hump) so that the tool sits on top of the pivot. Lift up on the tool handle to disengage the trim panel upper clips, then remove the lower trim panel from the vehicle.
  5. Unplug the high-mount brake light wiring harness.
  6. Remove the brake light fasteners, then remove the lamp assembly from the liftgate.
  7. To remove the bulb(s), push slightly on the top edge of the lens and rotate it away from the housing. Remove the bulb(s) from the housing. To install:
  8. In order to prevent the possibility of water leaks into the liftgate, inspect the lamp gasket for damage and replace, if necessary.
  9. If removed, install the bulb(s) by inserting the bottom edge of the lens into the housing and snapping it into place.
  10. Position the lamp into the liftgate and tighten the fasteners to 35 inch lbs. (4 Nm).
  11. Connect the wiring harness to the lamp assembly.
  12. Align the upper clips on the lower trim panel to the liftgate slots, then install the panel by pushing at the clip locations.
  13. Reset the trim panel push-in fasteners by spreading the center pin tabs and moving the pin so that it sits approximately 1?4 in. out of the fastener. Insert the fasteners into the bottom of the trim panel and push the center pin until flush.
  14. Install the liftgate wedge blocks.
  15. Connect the negative battery cable and check for proper lamp operation. Fig. 12: Removing the liftgate lower trim panel assembly - wagon 84196116.gif
    Fig. 13: Exploded view of the high-mount brake light bulb and lens assembly - wagon 84196117.gif
Nov 04, 2010 | 1998 Saturn SL
I need to replace rear tail light bulbs on 1996 Saturn SL1
WAGON
WAGON
Reverse Light EXCEPT 1991-96 COUPE For the Saturn wagons and sedans, the reverse lamp is part of the rear turn signal, brake and parking light assembly. Refer to the procedure in this section for lamp removal and bulb replacement. 1991-96 COUPE
  2. Reach behind the bumper bar and disconnect the harness and socket from the reverse lamp. Remove the bulb from the socket.
  3. If necessary, unfasten the retaining nuts and remove the lamp from the bumper bar.
  4. Installation is the reverse of the removal. Fig. 14: Exploded view of the reverse lamp mounting - 1991-96 coupe 84196118.gif
Oct 23, 2010 | 1996 Saturn SL
Lost instructions to assemble Lego muck and scoop - can
I am not sure which set you have but you can go to http://www.peeron.com/ and look through their list of sets. Many of them have scanned in instruction booklets.
Jul 09, 2010 | Toys
Powertec multi gym assembly manual
Lost the instructions manual on assembly..powertec support. i need assembly instructions. Im from Argentina.
I ask apologies for my bad speech. Help me please.
leonidas33@hotmail.com.ar
Jun 10, 2010 | Powertec WB-LS Workbench Leverage Gym
How do I get the old wipers off my hyundai 2000 elantra wagon and put on new armour all wiper blades?
The old wiper blade assembly can be pushed out of the end of the wiper arm. Depending on the blade, you may need to use a screwdriver to depress a locking tab on the blade assembly. The new wiper blade snaps into place on the end of the wiper arm. Also, your new wiper blades usually come with diagrams/instructions. Check them.
Jan 23, 2010 | 2000 Hyundai Elantra
Stop light bulb replace
Believe it or not, for the Taurus wagon, Ford wants you to take it in to the shop. The Taurus wagon tail light assembly is really a stupid design. I will do my best to describe it here. You must remove the two phillip screws on the tailight assembly, seen when you have the hatch door up. The trick is the assembly is still held with a hinge type, snap in deal that holds the front part of the assembly tight to the body side. You might be able to see or access it from inside the spare tire cover or the access door on the passenger side. Being oh so careful to release the clip so you can pull the assembly free to change the bulb. Hope this is some help.
The tail lamp / break lamp uses bulb number 3157.
May 02, 2009 | Ford Taurus Cars & Trucks
Spring Horse
You can go to the Radio Flyer website and download the assembly instructions.
Jan 10, 2009 | Radio Flyer Liberty The Spring Horse By
Legacy wagon tail light replacement
The one thing youll find with subaru's is that they like to put nuts in funny places that are hard to access. There are either 3 or 4 nuts holding the tail-light assembly in place, which means youll need to take out most of the inner panels to access the others. You should not need a sealant unless the rubber seal is done for or there is water inside the car. Hope this helps
Nov 02, 2008 | 1997 Subaru Legacy
Assemble a Carl Lewis Multi Gym
hi i have lost the assembly instructions for my multigym for the carl lewis multigym,
can any one please help???
Oct 27, 2008 | Sport & Outdoor - Others
Roadmaster Woody comfortable transport Wagon Logo
168 people viewed this question
Top Roadmaster Toys Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Roadmaster Toy Expert? Answer questions, earn points and help others
