Question about GE Spacemaker JVM1640SJ Microwave Oven
Ughes.netI have a GE Spacesaver Microwave oven that I need to replace the door handle on. Can you help? Model JVM1490SD003. Okay I took the door off. I got the inside surrounding plastic frame off....broke a few tabs. The screw for the bottom of the handle is accessible. The top screw is behind the steel door (at the corner)...the door itself piece with the glass in it. There are 6 screws around it which I removed but the door is still solid. no movement. How do I get access to that top door handle screw? Thank you Mike
    Sergeant:
  • 192 Answers
Mike,
Found the diagram HERE and HERE and also has a parts listing you can order.
Hope this helps with you project.
Posted on Mar 26, 2011
Why does my GE Spacesaver Profile, Microwave/Convection Oven, model # JVM1490SD003, in my motorhome, make a clicking noise when I start it up? Sounds like a fan hitting something. The noise goes away
Probably is the fan tapping something. Power it down/DISCONNECT power. pull unit and if there is a cover, remove it. look for the convection fan and see if it free-spins. should find spot where it is hitting and could be adjusted.
Nov 22, 2014 | GE Microwave Ovens
How do I replace jvm1490sd broken handle?
Disconnect, open door, remove screws from rear of door, dismantle door. Here's a diagram showing how it fits together.
01 Control Panel Door Grille Case Parts for GE JVM1490SD003
The part you need is #1801 on diagram
Microwave Door Handle
Color: Black. For white order WB15X10070. For bisque order WB15X10071. For the screws order WB01X10305.
by GE
Part Number AP3184331
May 19, 2014 | Microwave Ovens
The handle broke off of our GE spacesaver microwave. i got a replacement handle but i cant figure out how to take the door apart. anybody have a suggestion?
On MOST microwave ovens, you just have to remove the inner door panel that goes around the perimeter of the glass. The following link explains how to replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
If you have any questions, please post back and let me know. I hope this helps you.
Dec 31, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The door handle broke off my GE microwave
Actually the door handle CAN be replaced at a cost much less than pruchasing an entire new microwave oven. And, YOU can repair this yourself and save the cost of a service call. On MOST microwave ovens, you just have to remove the inner door panel that goes around the perimeter of the glass. The following link explains how to replace the door handle:
If the model number is correct, the part number is WB15X322. The cost is about $40. Replacements may be purchased at the websites listed in the link I provided.
If you have any questions, or if your model number is different than the one listed, please post back and let me know. I hope this helps you
Need to replace handle on micro wave can not
I HAVE A GE PROFILE SPACESAVER 2.0 OVER THE RANGE MICRO WAVE, CRACKED HANDLE, WOULD LIKE TO KNOW HOW TO REMOVE HANDLE AND INSTALL NEW ONE.
Dec 18, 2009 | Jenn-Air M439 Microwave Oven
Broken door handle on GE Spacesaver microwave
TIP: Go to the web and type www.partselect.com enter your model number then scoll down to your part. Panel,door (PANEL DOOR) click to enlarge exploded diagram on left. Veiw enlarged diagram at top of page. You can print the entire diagram for exact assembly by holding your pointer in the upper left hand corner of diagram. Select the print icon. Now you have what you need. If you found any of these suggestions helpful, please rate my solution. D. Lange
Apr 25, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Need to replace GE Spacesaver microwave door handle
never attempt to repair or replace the handle or any part of the door as this almost allways will lead to microwave leakage this will cause most certain death..
replace door or replace the unit today the uniy a very inexspensive..
nbcrca:)
Apr 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Model Spacemaker Microwave Model #JVM1650WB008 handle broken.
Appliance Repaired: General Electric Microwave
Model: g
Age Of Appliance: 5 - 10 years
took a screw driver and pride off plastic on inside of door. be carfule not to break it. only one of two screws that go into handle were visable. had to drill a hole in metal braket to get at second screw. you can just bend the metal braket back inorder to use drill. bend it back when done. took off handle and replaced it. snapped plastic piece I took off back in place and finished.
ge told me i needed to replace whole door. which they nolonger stock and I could not find a whole door for my model on web. found handlw on this website and did it my self
Mar 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Need to replace handle on GE Spacesaver Microwave J VM130K 004.
I looked up the $39.99 part ! (almost as much as a new microwave)
If you want to replace the handle, get the new handle and see how the new handle goes on and you can determine how to take off the old handle.
Mar 26, 2009 | GE Microwave Ovens
GE Spacesaver XL JVM1341WW002 microwave broken door handle!
Its a free country Bage, but microwave energy is extremely dangerous! Repairs are not feasible unless performed by factory personnel under warrantry, and certified. I suggest you contact the manufacturer about the problem.
Ray
Nov 19, 2008 | GE JVM2050 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
188 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
