Question about Jensen Car Audio & Video
Hi .i have a jensen vm9224 and i bypass the parking brake switch wire (pink) so i can watch video when driving . the dvd video was playing and i put car in reverse to park vehicle , the back up camera came on and after that the dvd would not play but only the sound, no video , any solution , Thank you for your help.
  • 2 more comments
  • bossdevita7m Mar 26, 2011
    hi lild86, , i gave the unit to a radio shop for repair , they opened it up & said nothing looked burnt , but needed a repair manual and can't get one from jensen there the only company that don't supply any info. i guess it has go bak to jensen for repair , any other fix ,
  • bossdevita7m Mar 27, 2011
    hi lilb86 , Guess i got no choice but to send back to jensen radio company, Thank you for your help ,
    2 thumbs up Thank you again .
    lilb86 , 2 thumbs up , Thank you
  • 902 Answers
Sounds like you shorted the pink wire. check to make sure its grounded correctly and see if you can see video from the back up camera if not you deff shorted out something inside video processor common on self install jobs that dont use a relay for the bypass
Posted on Mar 26, 2011
  • 1 more comment
  • brian shevack Mar 26, 2011
    is there video in any mode? if not you did likely mess up the video processor
  • brian shevack Mar 27, 2011
    no prob glad i could offer assistance thumb me up if you feel like it
Bypass parking break feature on the Jensen VM9311TS
You can purchase an aftermarket bypass kit from electronics store or off ebay... But hey, be careful, no watching movies while driving... K
Jun 05, 2009 | Jensen's VM9312 Car DVD Player
How do i bypass the parking brake switch in order for my video to play
DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On my Jensen, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Aug 23, 2008 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
JENSON VM9512 CODES FOR BRAKE BYPASS
turn on the player, start the radio option, go into the setup menu, tap the language tab, ON THE REMOTE press "stop, stop, 5,4,3,2,1" This will bring up the secret menu, you do not need to connect the pink wire
Mar 10, 2008 | Audiovox VM9512 Car DVD Player
yea it will work if u leave the car running but once u shut off the car and turn it back on it doesnt work there has to be another way
Mar 01, 2008 | XO Vision XO9013 Car DVD Player
Parking brake
If you have the VM9410 then there is a way to play dvd's even when you are driving. You must ground out the pink wire in the harness. This allows you to watch dvd's even when driving. good luck!
Feb 24, 2008 | Jensen VM9410 Car DVD Player
Trying to find the parking brake
YOU DONT NEED TO HOOK THE PINK WIRE UP JUST PUT IN A DVD AND TYPE IN 543210. THIS IS A BYPASS CODE SO YOU CAN PLAY DVD WITHOUT HOOKING UP THE PINK WIRE. YOU MUST HOLD DOWN THE 0 FOR 4 SECONDS WHEN PUTTING IN THE CODE.
Jan 15, 2008 | Jensen VM9510 Car DVD Player
Bypass the parking brake for vm9412 jensen
Hit Setup On Remote.
Select Language.
Get Remote And Hit 5,4,3,2,1,0.
Listen For Beeps. Touch “Hammer/Screwdriver” Logo.
Select Brake Override
Switch To Brake Override “ON”
Now Hit Setup On Remote.
this works thank you for posting this.
derek
Dec 25, 2007 | Jensen VM9510 Car DVD Player
Jensen in dash dvd monitors
jensen double din dvd monitor it a uv8020 model to bypass the e brake or parking brake
Dec 19, 2007 | Jensen VM9510 Car DVD Player
Bypass brake for a jensen vm9311
the wire is pink and say parking on the wire.
Nov 24, 2007 | Panasonic CQ-C3300U CD Player
Jensen vm9311
Need to know and bypass codes for the jensen 9311 but dont have the remote...
Oct 21, 2007 | Jensen VM9510 Car DVD Player
Car Audio & Video Logo
659 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
