Question about HP Computers & Internet
Whenever i put on my laptop, there is message that reads "system has detected that there is a cooling fan that is not working well" what does dis mean, and wat do i do about it?
  • 822 Answers
The fan is running too slow...............over heating will follow. strip lappy down and remove all dust from fans and heat sink fins. ............
cheers
Posted on Mar 26, 2011
SYSTEM WILL NOT READ CD OR DVD
Sounds like the deck needs to be replaced. If you contact Bose, they will usually give you a flat fee quote for the repair.
Mar 17, 2013 | Bose 3·2·1 II System
I get this message when I turn on my laptop. It's almost a year old. "The system has detected that a cooling fan is not operating correctly. Continued operation is not recommended and may...
More that likely the fan is going out. Check the fan exhaust to see how much air it is moving if any. A laptop cooling pad will probably help out and possible prolong failure. If its under a year old, the maufacturer may fix it for you. You'll just have to contact HP and see if they will, or if they can get you a new fan to replace yourself if they wont do it for you.
Sep 11, 2011 | Computers & Internet
I got toshiba nb205 as i get error A PROBLEM WITH COOLING SYSTEM HAS BEEN DETECTED RETURN IT FOR SERVICE IMMEDIATLY i get its fan changed now its fan is in running condition and i am also using cooling pad...
hmmm, you could try booting into bios (hitting del key at bootup) and see what the internal temp readings are. Laptops have tricky cooling schemes that usually rely on one fan and heat pipes. If I were you I would backup my data and take it to a qualified laptop repair shop.
Nov 02, 2017 | Toshiba NB205-N210 Netbook
Hi , I am using hp pavillion dv4 1131tx laptop. My screen always randomly turns black and then shuts down after a few seconds. when i start it back up, i get this message: "The system bios has...
well your CPU centeral processing unit is overheating ..check the fan if its still working.. if its then try to clean the fan take it part and get it clean .
May 06, 2011 | Computers & Internet
I have bought a new toshiba A665 a week ago. I have a problem saying. ' A problem in the cooling system has been identified. Switch off ur computer and return it for service.' Cooling fan is working but...
At a week old, get a replacement or fix it right away. Fix should be free, but no computer during service.....
Toshibas run too hot, in my opinion.... so you have to keep after the fans and keep lint cleaned out of it....
Overheating will yield un stable system,
Feb 26, 2011 | Toshiba (K000831860) Cooling Fan
Whenever i try to access my Windows Movie Maker or Skype there is a message that reads "A video capture device was not detected. Verify that a device is turned on and connected properly, and try...
Just reset it! At the back of the router is a small hole.With a toothpick or some like press gently for 30 seconds and wait for the router to start up again.Log in to http://192.xxx.xxx and start a new configuration.
If you need more help come back.
Post / thumbs / testimonial are welcome!
Dec 31, 2010 | Computers & Internet
I just got my Qosimo laptop and a window saying "Vibration has been detected in the PC. The hard disk drive head is temporarily moved to a safe position" What is that and why does it keep popping...
The cooling fan is worn out and it vibrates. That vibration is lethal to the hard disk so its protection system has temporarily put it in a safe state. The only way to fix that is to replace the fan and this is a job for a repair shop.
Nov 05, 2010 | Toshiba Qosmio X505Q880 (PQX33U01J00H) PC...
A problem with the cooling system is detected. Satellite A25-S207
The sensor that reports the cpu temperature could be faulty or could be fan loose from cpu or faulty motherboard .
Aug 02, 2009 | Toshiba Satellite A25-S207 Notebook
How to fix my Toshiba laptop in cooling system please ?
you probably need to clean the cooling fan...it collects dust over time, and doesn't move the warm air out as it should...its fairly accessible by removing the bottom case cover...please rate my response.....
Jan 29, 2009 | Toshiba Satellite 1715XCDS Cooling Fan...
Computers & Internet Logo
144 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
