Question about Cakewalk A-500PRO USB/MIDI Keyboard Controller
Hi Guy's, just purchased the cakewolk A-500Pro. I having real difficulty with the driver installation. The installer goes through the first process and when it asks you to plug in the usb cord and turn unit on to usb, this is where my difficulty lies. The computer is doing alot of something but then it just fades and nothing is happening even after a good heatlhy 10 mintues of waiting. I have gone through all the trouble shooting material in the back. Made sure no programs are running, no antivirus, no adaware, shut down the internet. However windows continues to want to install the driver, I let that happen once but even that failed. I'm also logged in as administrator. I'm running Windows 7 pro 64 bit ( also been using the 64 bit installer. Sheesh ! I have installed tons of drivers in my day but not totally stumped. I want to use this unit ? HELP !
  • 3 Answers
Read through the guideline, n u will be clear by ur self!
Posted on Mar 26, 2011
Korg pa 800 gone dark
Sounds like your keyboard screen is going bad, You need to contact Korg and order one, you can do it yourself or they have authorized repair shop around your house.
Good luck
Jun 10, 2014 | Korg Pa800 Synthesizer
I am needing to replace my piezo drivers for the S715 cabinets and they are 8 ohm 15 watt drivers. Will these cabinets only safely handle 15 watts, or can I replace them with higher wattage drivers? I am...
No worries here, in fact you can attach a non-piezo hf driver, coupled with a 2.2uf/3.3uf MKT filter and that should do the job with ease, even better than with piezoelectric devices, hope this helps...
Sep 14, 2013 | Phonic Powerpod 740 Plus S715 PA System
Hello guys, i have a problem with my midi keyboard. My PC doesn't recognize the USB connection and i can't find any solution.
Well first start by verifying USB port works by plugging in a hard drive or something thus proving you have a good port and USB Cable. At which point hook the keyboard up ( and make sure to properly install drivers provided on cd with purchase) being a pc this may take several attempts to install. What software are you trying to control? Reason? Logic? Fruityloops?
Oct 07, 2011 | Alesis Q49 USB/MIDI Keyboard Controller
Hi i recently bought a Takamine EG 260c G Series acoustic electric Guitar with TP-4T preamp installed in it. Now the problem is when i connect my guitar to an amplifier, the sound comes through it only...
That is working backwards from what it should be. I suspect a wiring error. Since this is a recent purchase, do NOT risk voiding your warranty. There isn't any real good documentation on the tuner.
I am not sure which tuner you have HOWEVER with one type, the FIRST press will turn on the tuner with the sound going out as well till the tuner goes off. The SECOND press silences the sound and is tuner only, the THIRD press turns off tuner and passes the sound. This is different than a lot of tuners and you will need to do three presses to restore sound instead of the usual two.
May 02, 2011 | Takamine 1 NEW Takamine EG350SC G-Series...
I am trying to play some music using my laptop and a beringher bcd 3000 dj mixer but when I plug in the mixer the "found new hardware " sign comes up and next there is a pop up which says...
Sometimes just plugging into a different USB port on the back of the laptop will work better than the ones on the sides. I also find using the headphone jack out to a couple RCA mixer channels is far more reliable that USB which often comes and goes. Just a thought. Beringher should have the drivers, you can download and install the universal ASIO drivers as well which can be a little tricky but works for recording - from here: http://www.asio4all.de/
Jun 05, 2017 | Behringer Bcd3000 B-control Dj Mixer...
Hi. I purchased some Grover Rotomatic tuners on my electric guitar and am having difficulties figuring out how to put the strings through them. Normally where there should be a hole where the strings go...
If you see a hole on the thumbscrew post, you have to line it up with the hole in the solid post by screwing it in or out until it does. Then you put the string through. Hope this helps.
Jul 02, 2010 | Grover 205c Mini Rotomatic Guitar Tuners...
WDM Driver failed to install is the first of four
Make sure you verify that your computer meets the requirements for the Omega. I have one of these and it installed on an XP with no problem.
Maybe you have Vista instead of XP. OFTEN there are incompatibilities of Vista. If you have that or heaven forbod Windows 7, you may either need a different WDM or have to backstep to the XP operating system.
In short, VERIFY the requirements of teh Omega and its software with the OS and system you are trying to install it on.
A last thing to try is to install it while in "SAFE MODE".
Nov 13, 2009 | Lexicon Omega Desktop Recording Studio
Connect usbtocomputer
Hello - I am too a personal owner of a CASIO CTK keyboard, a little older than yours (model CTK-601) a great keyboard BTW, and I have connected it to my computer successfuly.
There are 2 ways of connecting the keyboard to your PC......Using the MIDI outputs and a special MIDI to gameport adapter - if you have a very old system and have a joystick port (D-sub shape) on your soundcard or PC, then you use that cable. Of course this is legacy and stopped existing in newer computers, now USB is used.
Only the professional line of soundcards have direct MIDI inputs. For most of us, with consumer soundcards and PCs, there are no MIDI inputs.
The good news is that newer keyboards support USB MIDI and features direct USB connection - so all you have to do is install the drivers that are provided with your keyboard, usually a CD, and follow the instruction to install the USB drivers for your casio keyboard, BEFORE you plug in the cable (very important!) once installed you reboot and connect your keyboard using a USB cable
Now if your keyboard is older and has MIDI outputs, like mine for example, you will need to purchase a MIDI to USB adapter, those have MIDI cables in one end that plug to your keyboard and the other end a USB connector....... I don't know about the rules if I am allowed to post websites, but the product i'm using is the Uno from M-Audio - in google do this search:
"m-audio"uno
(exactly as shown above with quotes, and uno outside quotes)
Your CTK-810 may alreayd have a USB connector on it, as it is a newer generation keyboard - I am pretty sure it does - what you will have to do as stated above is located your bundled CD-ROM and install the USB drivers - you will need to purchase a USB cable (seperately).
Aug 17, 2009 | Casio 76 Key Smartmedia Keyboard
Cakewalk A-500PRO USB/MIDI Keyboard Controller Logo
113 people viewed this question
Top Cakewalk Music Experts
Michial Gueffroy
Marvin
Marvin
Are you a Cakewalk Music Expert? Answer questions, earn points and help others
