Question about Gear Head WIRELESS keyboard/Mouse
Mousse and keyboard will not respond, i plugged usb connecter in all ports and nothing. its a standard keyboard and mousse combo i bought from biglots
  • 54 Answers
CHECK THE BATTERIES
Posted on Mar 26, 2011
Keyboard is connected to the computer... but it will not respond to the computer. when you type nothing happens
If it is a USB keyboard try unplugging it and plugging it into a different USB port. If it is wireless check the batteries. Be sure to try restarting your computer. If possible, try plugging it into a different computer. It may be broken if the other computer cannot see it.
Mar 05, 2011 | Computers & Internet
Optical mouse no light
hi this is jesica am expert to help you to fix this issue for you,kindly call me on +1(518)348-9393 and we will be glad to help you.
Oct 04, 2017 | Logitech Wireless Access Duo Optical...
Hi . .. I want to use this KVM switch to connect
The GCS632U has keyboard and mouse emulation that may not work with all wireless combos. If your wireless combo is going to work the single USB connection would need to go into the keyboard port as that is the only port that will recognize the hot key switching commands. If the wireless combo still has problems then try using a USB wired keyboard to ensure the GCS632U is working correctly.
Mar 18, 2010 | IOGear GCS632U 2-port KVM Switch
Brought a CS62US and Mircosoft KB with mouse. When USB combo plugged on the left USB, only KB is worked together with switching function. When USB combo plugged on the rigth USB, both KB & Mouse worked...
Unfortunately, this switch has a dedicated port for keyboard that listens for the keyboard keystroke. You MUST plug the keyboard into the dedicated keyboard port on the KVM switch for the hotkeys to work. I recommend putting the mouse that comes with your keyboard to the side, and using another mouse, plugged into the dedicated mouse USB port on the switch. Not the prettiest solution, but some of those mouse/keyboard combos have some funky hardware!
Feb 17, 2010 | Altusen Aten CS62U-2 Port USB KVM Switch
I bought a multmedia keyboard how do i attacch it
Your keyboard is USB equipped?
Your laptop has a USB port?
Connect em
Your keyboard has the standard mini plug?
Your laptop has a mini port in the back?
Connect em
If one is one and the other is the other ... I thnk you are out of luck.
If yo are already using your USB port, you can daisy-chain USB devices up to 128 devices (though you would require additional power for that many, probably)
I hope this helps you
a
Sep 25, 2009 | HP Compaq Presario V2000 Notebook
HP keyboard KB 9970
Is it USB or Standard connection. If it is USB then you may not have plugged it into the same USB port you had first plugged it into. Sometimes just plugging it into a different port can cause a problem. Try turning off the computer and then plugging it into a different USB port and then re-boot the computer and see what happens. If your operating system is winows xp or higher the operating system should be able to install a standard keyboard driver to use.
Sep 05, 2009 | HP KB-9970 (KB9970) Keyboard
Usb problems on u400 (a40)
make sure that dust has not fill the port use compressed air ,buy a can from walmart or any biglot store ,next check to see if you have device conflick ,the easy way to fix this is buy a usb hub $6 biglot powerd one are even faster you can connect up to a100+ in a daisy chain .problem solved
Mar 08, 2009 | Toshiba Satellite A105 Notebook
4-port usb kvw switch #GCS634U
The GCS634U is designed and tested to work only with a standard USB keyboard and mouse. However, most wireless keyboards and mice work with it, but they cannot guarantee any specific model or brand that would work correctly.
As you can see, this KVM switch is a bus powered device (meaning it only gets power from the USB ports of the computers). If the computer cannot provide enough power for the KVM switch to function correctly, then the wireless keyboard will be affected.
You may try using the IOGEAR GKM541RA. It's tested to work with the GCS634U. Or you may also try using a self-powered USB hub (meaning, it has it's own power adapter) and connect it in between the KVM switch and the computer. That self-powered USB hub will be the one that will add up power to the KVM switch and help it to function properly.
Jan 12, 2009 | IOGear GCS634U KVM Switch
Gear Head WIRELESS keyboard/Mouse Logo
114 people viewed this question
Top Gear Head Computers & Internet Experts
micky dee
Are you a Gear Head Computer and Internet Expert? Answer questions, earn points and help others
