Question about Sony BRAVIA KDL-32M4000 32" HDTV LCD TV
I have a sony bravia lcd 26" kdl 26m4000.I have been having a problem where all of a sudden the buttons on the remote and tv will not work except the power buttons. when turned back on the logo screen comes on but then goes black. I unplugged it let it sit for 15 minutes or so and it came back on. but it did it again within a week of the last time.
    President:
  • 1,961 Answers
You need to open the cover of your TV to check the components inside.have a visual check on the power supply board first.The power supply maybe fluctuating and goes shutdown this is cause by a leaking capacitors.you can easily identify a faulty capacitors they look to bulging and deformed replace them all.use replacement capacitors of the same rating.Resolder also all the components at the power supply board.The power supply board has 3 voltage output use a multimeter and measure the output of the power supply 24v for the inverter board 5v for the main CPU board and 12v for tha audio.when 1 of these voltages is failed your TV will shut off.you can also order a replacement board online at shoppejimmy.com heres the link
check the inverter board.this board supplies high voltage to the back light lamp.This lamp illuminates the screen.if the inverter board is faulty you will have a black screen.resolder the board and check for any defective capacitors.re tighten also all the connectors make sure connectors are not loose.solder the connector terminals.
Posted on Mar 26, 2011
Infrared on tv doesn't work
It is possible that the receiver in the TV has failed.
Dec 04, 2013 | Sony Bravia KDL-26L5000 26 in. LCD HDTV
Blank screen
The fault is with its main power supply regulator section itself. One or more voltage rail is missing. Your TV need a through checkup. Seek tech assistance.
Jun 06, 2012 | Sony Bravia KDL-40V4150 40 in. LCD HDTV
On the TV screen it displays "VIDEO 5" I can't get it to go away. I have misplaced my Sony remote and only have the cox remote control. I hope you can help us. Margie
Only Sony tv remote will work here to disappear onscreen display.
Have Sony tv remote and press INFO/ DISPLAY button once, on-screen display will disappear.
No other remote will work for that.
Thanks.
Nov 08, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
How can i access to a sony bravia kdl-26m4000 factory service
With the remote and TV off, press these buttons in order DISPLAY, 5, VOL-, POWER. Be careful!!!
Apr 13, 2010 | Vizio L30WGU 30 in. HD-Ready LCD...
Bravia KDL40W2000 Remote and manual controls no longer work
check to be sure your remote is sending IR signal, with
a smart phone camera hold remote IR eye in front of camera and click any buttons on remote, you should see
a light coming from IR eye. If no light emitting, remote needs to be replaced.
Oct 29, 2017 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Hi! I have a problem with my sony bravia lcd tv model:kdl-46z4100. The only working buttons on a tv and a remote controller are power buttons. After turning on a tv you can only see a black screen with a...
You may have a case of a bad signal board. The clue was that your power button on the tv and remote are the only ones functioning. If the tv is still under warraty, call the service number to get help!
Nov 16, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
I can't get rid of the information bar across the top of my TV
Press " i " (information) button on TV remote and on-screen display will disappear.
Dec 29, 2008 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Sony BRAVIA KDL-32M4000 32" HDTV LCD TV Logo
83 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
