Question about Directed Electronics 479V Remote Gen 2 Responder
How do you unplug or remove viper remote system
  • 391 Answers
You just need to remove the two connected to the starter wire (ignition switch), and connect the car side of the two together. Then the ignition switch will control the starter again, without interferance.
Posted on Mar 26, 2011
Why won't it start vehicle?
[PDF]Responder LE Model 5701 Security and Remote Start ...
xtremetruck.net/file/1101-Viper+5701+Owner's+Guide.pdf
the year, make and model of the vehicle; vehicle license number and vehicleidentification number. All ..... One five-button/2-way Supercode Responder LE RemoteControl. ? .... Disarm. Unlock LED blink for one second with 2 Beeps. Remote. Start..... Long-time Viper system users will notice the following differences:.
Viper LED 2-Way Security + Remote Start System
https://www.viper.com/car/securityremotestart/.../viper-led-2-way-securit...
Viper's elegant new Responder LE transceivers mark a giant leap forward in 21st century vehicle security and remote start, and an evolutionary milestone for the ...
Viper 5901 remote start error fix - YouTube
? 2:38
https://www.youtube.com/watch?v=wsSorAf88nw
Jan 13, 2013 - Uploaded by Power2ThePeopleZ
5901 won't start vehicle; gives an error. ... or even try to open the hood. the door remains locked when you start the car with theviper alarm.
Help With Programming/Pairing Viper Remote - YouTube
? 2:49
https://www.youtube.com/watch?v=cgbQsZuVyt8
Dec 2, 2010 - Uploaded by Paul L
I have a two-way remote from my Viper 5901 system. ... The other car (one in video) has the Viper 5701 system in it. .... and then release 3) press the remote start button 2 times until pairremote is displayed 4)press and old ... I had the same problem that the remote won't pair with the system no matter what.
15964701 Viper 5701 2 way alarm w/ remote start won't
Jan 05, 2016 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper 211hv draining battery
If you are sure it is the system draining maybe the installer did not properly connect the GEM module. It would be wise to return to where it was installed and have that checked. If you are unsure if that is the cause then you could unplug remote unit and see if problem persists..
Feb 19, 2014 | 211HV Keyless Entry System
Python same as Viper?
Hello Anthony,
This remote will not work with your system. It is only compatible with the Viper 591XV, Viper 690XV, Viper 790XV, and Viper 791XV.
Feb 03, 2014 | Directed Electronics 479V Remote Gen 2...
Viper 501 remote start and security system. is there any way to reset the system. truck will start but shuts off when you try to put it in gear.
The quick solution is to power off the security system by removing the power source. Unplug it from the ignition bypass plug and plug the ignition direct bypassing the system.
Oct 30, 2013 | Vehicle Parts & Accessories
The Responder LC remote for my Viper 5901 will not charge. What can do I do to fix this? I have only had this system for less than 2 months.
Plug the charger into an outlet. Plug the charger into the remote, unplug the charger from the remote. Repeat until "charge" appears on screen of the remote. You may have to repeat the process approximately five times until charge appears. There was an issue with the batteries in the remotes having to be reset. If this does "fix" the issue, your problem may be with the charger itself. You can use any usb charger to charge the remote, i.e. phone car charger, computer, etc.
Feb 02, 2011 | Viper 5901 Security Remote Start System
My viper remote, no matter what button I push on it just beeps and an icon that looks like a antennae flashes but nothing happens.
Try this first, unplug the 2-way antenna on your windshield. Let it sit for at least a few minutes. Try recoding the remotes after you replug the antenna back in. This is an issue i have seen on some of the Viper units. Usually they never have issues, but here and there they need reset.
Aug 21, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I need to bypass my viper remote start system as I
Check ur battery take out any extra wire that hook up to the battery.The system should have no power to the Viper system.U should able to start ur car without the Viper remote.
Apr 21, 2010 | Viper Security and Remote Start System...
Viper 5900 remote start does not show it is off on the remote.
try a couple of things, 1) try unplugging the anntena for the alarm for about 5 minutes. 2) remove battery from remote for 5 minutes 3) reprogram the remote
May 21, 2009 | 5900 SST 2-Way Security System / Remote...
I have a viper starter and car alarm with 2 controlls and one got stolen what should I do
The Viper alarms will accept (if I remember correctly), 4 codes at one time. That is, 4 individual remotes, or two remotes two times, or one remote 4 times. So, if you program your remote 4 times, it will essentially remove any previously programmed remotes. Another option, and you'll have to check with your dealer, but I think there is a way to delete ALL remotes, and then program your remaining remote one time, and again, all previously programmed remotes are now removed from memory. This was done by the manufacturer just for such events.
May 17, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Directed Electronics 479V Remote  Gen 2 Responder Logo
207 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
jason
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
