Question about Norelco SmartTouch 9190XL Electric Shaver
Model 9190XL does not hold charge. The screen promises 95 minutes and that decreases quickly to 75 and then 55 and then 0.
  • Norelco Master
  • 1,624 Answers
Battery needs replaced. You will find the correct battery at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-liion-battery-cell-for-select-models-p-380.html
Scroll down page for disassembly video. For easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Posted on Mar 30, 2011
300cc 95 model explore don't want to charge can it
start with battery first-is it old can it hold 12.6volts--chec wiring for wear and bad connects--hav alternator tested--coils are ignition sysytem--charging area is ur concern
Jun 24, 2013 | Cars & Trucks
Iphone 4 battery
If your iPhone battery gets low quick, try disabling features within your iPhone which may help increase battery life.
1. Decrease the screen brightness of your phone.
2. Turn off 3G when not in use ( 3G can decrease the battery life greatly )
3. Turn of Location Services in Settings. ( GPS can decrease bettery life greatly )
4. Turn off bluetooth.
5. Charge your iPhone up to 80% everytime and then stop charging. ( Studies show that charging up to 80% everytime can help increase the life span of your iPhone battery )
Feb 25, 2013 | Apple iPhone4 4G iPhone 4
Resseting the Clock, I had to cut the battery cables and rewire them, bu i dont know how to reset the clock
Keep pressing the knob that you use to adjust bass, treble, fade, ect, keep going, you will get to clock. Next one after clock is set the clock. Then you have to be quick about it, turn that same knob to increase or decrease the hour, then it will move to minutes and turn till you get the right minutes.
You really have to be quick about it, it took me several times before I got it completed.
if anybody has the 2.5S model 2010 Altima >>> hold the Clock button for 2 seconds, when the words SEEK and TUNE appear, press the Seek button (top LEFT) up or down to change the Hour ... then press the Tune button (top RIGHT) to change the minutes ... press Clock again to end adjustments.
Jul 13, 2011 | 2000 Nissan Altima
My battry is not charging properly.it goes upto 100% and the charge is finished in 4 or 5 minutes
Laptop batteries worn out with the passage of time and their charge holding capacity decreases.
The battery now has very less charge holding capacity (equal to 4-5 minutes), that's why it says it is 100% charged (capacity of 4-5-minutes).
So, it is recommended to replace the battery with original battery as it would last longer and serve you better.
Let me know if any further clarification/ assistance is required.
Good Luck!
CreativeTECH
Dec 15, 2010 | Compaq HSTNNLB42 Laptop Battery
Power meter says the battery is charged to 95% but when I un plug it the screen goes blank and it needs to be rebooted
Ok, just because the battery is 95% charged doesn't mean that it has 95% of the charge it's supposed to have. When a battery ages it holds less and less of a charge so it can have just a tiny bit of power and show as 95%. You can check the health of the battery on this Dell by removing the battery, pressing and holding the status button. The more lights that light the worse the battery is. Dell recommends a new one if 5 or more light.
Also, check the battery charge by just pressing without holding. This time the MORE lights the better. It may be that powermeter is lying.
Dec 14, 2009 | Dell Precision M6300 Notebook
I have a Starter Brand Watch that did not come with a manual. I can't seem to get the chime to stop chiming on the hour.
Just bought a STARTER Sport Watch Model# STW14 @Walmart
TO CHANGE TIME:
1. Press and release MODE button quickly 3X in a row(top middle no.(Seconds will flash)& change Seconds by pressing START button 2. Press & release RESET button 1X quickly(Minutes will flash) & you change Minutes by pressing START button 3.Press & release RESET button 1X quickly(Hour will flash) & you change Hour by pressing START button. 4.Press & release RESET button 1X quickly(Date will flash) & you change Date by pressing START button.5.Press & release RESET button 1X quickly(Month will flash) & you change Month by pressing START button 6. Press & release RESET button 1X quickly(Day of week will flash) & you change Day by pressing START button 7. Press & release MODE button 1X quickly to return to Normal use
TO SET ALARM: 1. Press and release MODE button quickly 2X in a row(Hour will flash)& you change Hour by pressing START button 2.Press and release RESET button quickly 1X (Minutes will flash)& you change Minute by pressing START button 3. Press & release MODE button 1X quickly to return to Normal use
TO VIEW MONTH & DAY: 1. Press & Hold START button 2.Just Release START button to return to normal use.
TO USE STOP WATCH: 1. Press and Release MODE button quickly 1X 2. To START stop watch: Press START 1X quickly 3. To STOP Stop watch: Press Reset button 1X quickly 4. To RESET Stop watch: Press & Hold START button and press RESET button quickly @ the same time, 2X in a row 5.Press & Release MODE button 1X quickly to return to Normal use
Sep 12, 2009 | Bulova Watch
Motorla Slvr L7 Won't hold charge
nokia mobile phones has maximum charge holding capability.motorola phones consumes more charge if we use mp3 player in it.are you a continuous user of mp3 player then try to decrease it
Jan 15, 2009 | Motorola Mobility SLVR L7 Cellular Phone
Norelco SmartTouch 9190XL Electric Shaver Logo
192 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Bruce Foote
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
