Question about Vacuums
I need to purchase a new one. Old one lost in move. Phillips Deep Fryer Model H6157/55 magnet power cord.
    Master:
  • 403 Answers
Need to go through phillips, manufacturer specific.
Posted on Mar 27, 2011
I need to print how to assemble a bissell proheat shampoorer
First locate screw pack (you will need a Phillips screwdriver). 2 long Phillips screws with hex nuts, 2 short Phillips screws. Should be taped to under part of handle.
2, Put upper handle into lower handle.
3, feed the power cord through the tool caddy from the flat side. Place caddy to handle so the hex shaped holes on upper portion.
4. Place the hex nut in the hex shaped hole and insert long bolt through the front of the handle. Do the same on the other screw and tighten them snuggly. Be careful not to over tighten them.
5. Insert small screws into lower 2 holes through the back side of the lower hose rack. Turn until tightened.
6. Attach tool(s) (that would be a small brush or the pet brush attachment to end of hose and on the attachment holder on front of upper handle.
7. Wrap hose around large holder closest to handle and power cord is wrapped around outer holder with rotating clamp.
Hope that helped
Dec 11, 2015 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have a Kenmore Upright Model # 11630412001 with a broken power cord
Normally, you would leave the current power connections attached and then line up or label the new cord lines with the old.
There should be a common ground, easy enough to dsitinguish.
A hot, normally black.
A return, normally white.
These may be swapped it the existing wire colors are.
Red = new black
Black = new white
Green or Blue = Green or bare.
I'm a bit surprised t read your post as the cord should have come with connection instructions if the replacement cord is different in color scheme from the old.
ALWAYS TAKE SAFETY PRECAUTIONS WHEN WORKING ON HOT LIVE POWER. NEVER MAKE CONNECTION CHANGES WHILE THE VACUUM IS PLUGGED IN.
IF AFTER YOU CONNECT THE NEW LINES, TEST THIS BY TURNING ON THE VACUUM AND TURNING IT OFF RIGHT AWAY. IF YOU HAVE POPPED A BREAKER OR SEEN BURNING, YOU HAVE TO SWITCH THE BLACK AND WHITE WIRES.
The best thing is to always go online and find the wiring layout for you model.
If you have any doubt, pleast post the wire colors you do see now coming to the connection terminal and post the colors coming out of your new power cord.
Regards,
Worldvet
Jul 05, 2008 | Kenmore 35912 / 35913 Progressive Upright...
How do I replace the power cord on an electrolux 8502A vacuum cleaner?
1 Unplug the vacuum and remove all accessories such as extensions and brushes. Open the vacuum's outer casing to get at the end of the power cord. Exactly how you will do this depends on the model of vacuum. Generally it simply involves the removal of two to three Phillips-head screws.
2 Follow the power cord to the two connections at the vacuum's motor. Unfasten any clips or holding bracket and disconnect the cord from the motor. Sometimes this can be accomplished by unscrewing two connection screws, other times the cord is soldered directly to the motor. If this is the case use wire cutters and cut the cord about 4 inches from the motor to give room for splicing on a new cord.
3 Insert the new power cord into the vacuum. Follow the exact same path as the old one. If there were any brackets or clips that held the old cord in place inside the vacuum or out use them on the new cord.
4 Tie a knot in the cord on the inside of the vacuum casing so that it will not accidentally be pulled out of the motor once it is in use.
5 Connect the new cord to the motor in the same fashion as the old one. With wire strippers take off about 1 inch of insulation from the new cord to expose the two wires. Either wrap them around the connection posts and re-screw, or twist the new cord wires around the 4-inch remnants of the old cord and seal all exposed wire and connections with electrical tape.
6 Replace the vacuum's casing in reverse order from how you removed it. Plug in the vacuum to test.
Sep 11, 2011 | Vacuums
Where can I download or get instructions or manual for the Bravetti deep fryer
http://kitchen.manualsonline.com/support/bravetti/fryer
VISIT THIS SITE. SEARCH FOR THE MODEL YOU WANT AND DOWNLOAD.
REGARDS.
PLZ. RATE THIS
Jul 03, 2011 | Vacuums
Power cord broken inside s251i miele How do i open the s251i ????
HOW TO OPEN MIELE 251 VACCUUM: 1-Unplug from wall and disconnect power cord 2-Remove black switch panel at back of top panel: A-Use Phillips screwdriver, remove two silver screws visible between back of hinged top door and front of black switch panel
B-Push back of the panel down while pushing it forward (towards front of machine). There are two plastic notches and clips which are tightly fit together that you need to separate.
Once it releases, push it a bit more towards the front of the machine and lift off panel. It has wires connecting it to the main body so it will not remove completely.
C-Be careful not to lose the springs that simply sit inside of two plastic channels, one under each of the two switches. These are required for your witches to operate properly.
3-Locate screw at bottom of deep rectangular hole now revealed (under former location of black switch panels). Unscrew using Phillips screwdriver. 4-Open hinged top panel. Locate two silver screws, one on each side of main housing. Unscrew using Phillips screwdriver. 5-This will let you lift off the whole top assembly, door and main housing, revealing the plastic chassis and the motor unit within.
You now have access to the motor, wiring connector harnesses, circuit board and the cord reel.
Dec 07, 2008 | Miele S251i Plus Bagged Canister Vacuum
Hoover Model S3281, disassembly instructions
GET TO THE REEL AS FOLLOWS:
(BEFORE YOU START, BE SURE TO UNPLUG THE DIMENSION FROM THE OUTLET)
1). TURN VACUUM OVER AND USE A FLAT-BLADE SCREWDRIVER TO WEDGE/SLIDE THE WHEELS OFF (PUT THE SCREWDRIVER BLADE BETWEEN THE LITTLE BLACK WHEEL BRACKET PIECE AND THE GREY CHASSIS OF THE VACUUM AND SLIDE/WIGGLE THE WHEELS OFF);
2). THE 2 DEEP HOLES AT THE TOP OF EACH WHEEL RECESS LEAD TO 1-1/2" LONG PHILLIPS SCREWS >> UNSCREW THEM;
3). AFTER REMOVING ALL 4 SCREWS, YOU SHOULD BE ABLE TO EASILY LIFT OFF THE TOP OF THE REEL/MOTOR COMPARTMENT.
4). CAREFULLY LIFT AND ROTATE THE CONTROL PANEL TO THE SIDE.
5). THE REEL IS NOW IN PLAIN SIGHT.
6). I’M STILL TRYING TO FIGURE-OUT HOW TO SAFELY ACCESS THE GUTS OF THE REEL MYSELF. I HAVE A PROBLEM WITH INTERMITTENT VACUUM POWER AND ALSO WITH WEAK CORD RETRACTION.
ANYWAY, GOOD LUCK TO YOU !!!
Jan 01, 2008 | Vacuums
I have a d4c rainbow vacuum, need help replacing the electrical cord
There is no reset button, but some of those old switches are very touchy . . . if there was some  corrosion, you may not have a good contact (was enough of the new wire insulation stripped away, before putting it into the switch) . . .
I prefer splicing, rather than going all the way to the switch  . . its just a matter of cutting out the old cord and splicing in the new cord in a convenient spot up in the motor compartment. . . a Rainbow purist would run the new cord all the way up into the power on/off rocker switch that's built into the top of the handle and then wire the new cord in there, directly at the switch . . . that way means no splicing . . . I've done it both ways, but I prefer to splice and use wire connectors inside the motor compartment . . . because going further, all the way up directly into the on/off switch just to avoid splicing the new cord in requires taking more things apart . . . and risks screwing up the power switch . . . that's not worth the extra time and trouble, IMHO.  (This from someone who has dismantled and refurbished over 200 D4C and SE models)
Jul 26, 2007 | Rainbow 75th Anniversary Canister Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
