Question about Mitsubishi WS-65809 65" Rear Projection Television
Colors are off a bit - Mitsubishi WS-65809 65" Rear Projection Television
Trying going into the Convergence Settings Under the Menu Advanced section and Setting to factory default or adjusting each color until aligned. If this does not work post back what what not working in this process.
Posted on Apr 01, 2011
My sceptre lcd tv is displaying really bright pink and green colors
I had a similar problem with blacks showing up as green. Turning up the brightness a bit fixed it for me. Not a permanent fix, but something to try if you want to make it last a bit longer until you can get a new one or fix it.
Mar 24, 2012 | Sceptre X32BV-Naga 32 in. LCD TV
My monitor gives 16-bit color at 640x480, but will only offer 256 colors at 1024x768 -- and only displays 16 colors when I select that... In order to access resolution options, I have to go into Advanced...
The monitor has no influence here - something is wrong with your video card: either its driver is missing (or corrupted) or the video chip has failed.
Uninstall all the drivers for the video(except the generic VGA one), from Programs and Device Manager
http://pcsupport.about.com/od/windows7/f/open-device-manager-windows-7.htm
and reboot several times then go to Dell
http://support.dell.com/support/downloads/index.aspx?c=us&cs=19&l=en&s=dhs
select your pc and get the correct driver.
If that doesn't fixes it then the video chip has failed, you will need to buy a new video card.
Aug 02, 2011 | Dell Dimension 4600 PC Desktop
I have problem with color setting
· open Control Panel and select Display menu and open it
· Then select Settings Tab from where you can change resolution and Color quality as 32 bit /64 bit
· ]Or you can click on Advance where you can set DPI
If you want to switch in 256 color
Some games and other software programs require that your monitor be set to 256 colors, or they run better in 256 colors. Many of those programs will switch your monitor to 256 colors automatically when you start the program. For those that don
May 22, 2011 | Computers & Internet
At 1440x1200 resolution the monitor (719Sw) visualizes fine, but a window appears saying "input not supported". Does my cpu not support this monitor. Its a P4, 32.99 ghz 504 mb ram machine
Restart the computer
2 While the computer is loading, press "F8" key on the keyboard right before the
computer reads the hard drive or press the "F8" key multiple times in 1 second
interval until the "Windows Advanced Options Menu" appears on the screen
3 Under "Windows Advanced Options Menu", using the arrow key on the
keyboard, select "Enable VGA Mode" then press Enter. Select "Windows 2000
or Windows XP" for your operating system.
4 Wait while the computer is loading and once the computer finishes loading,
5 Right Click anywhere on the blank area on the desktop then click "Properties"
6 Click on "Settings"
7 Click on "Advanced"
8 Click on "Adapter"
9 Click on "List All Modes..."
10 We recommend that for 15" LCD's select 1024x768, True Color (32 Bit) 60
Hz or 1024x768, High Color (16 Bit), 60 Hertz; For 17" & 18" LCD's select
1280x1024, True Color (32 Bit), 60 hertz, or 1280x1024, High Color (16 Bit)
60 Hertz, or
640x480, 256 colors, 60Hertz or 75Hertz
640x480, High Color (16 bit), 60Hertz or 75Hertz
640x480, True Color (32 bit), 60Hertz or 75Hertz
800x600, 256 Colors, 60Hertz or 75Hertz
800x600, High Color (16 bit), 60Hertz or 75Hertz
800x600, True Color (32 bit), 60Hertz or 75Hertz
1024x768, 256 colors, 60Hertz
1024x768, High Color (16 bit), 60Hertz
1024x768, True Color (32 bit), 60Hertz
11 Additional Valid Modes for use only with 17" & 18" LCD Monitor
1280x1024, 256 colors, 60Hertz
1280x1024, High Color (16 bit), 60Hertz
1280x1024, True Color (32 bit), 60Hertz
May 17, 2011 | AOC 917Sw 19" LCD Monitor
What is the perfect calibration for this television.
Go into the tv menu setting,at the picture setting go down to reset it back for the factory setting.Now,go to the color setting turn the colors setting down anothter 20 precentage for reductiion of colors.The picture should great now,because this is factory setting,but it just a bit to much colors on the screen pictures.
Dec 15, 2010 | LG 32LE5400 32 in LCD TV
I cannot get more than 32 bit colors
you need to download and install your video card driver. please refer to this link http://www-307.ibm.com/pc/support/site.wss/TCTR-MATRIX.html
Mar 29, 2010 | IBM ThinkCentre S50 8183 - P4 3 GHz...
Colors in PAINT are limited
assuming you are using XP-
1. right click on your desktop and select "Properties"
2. click on the "Setting" tab
3. make sure that the color Quality is set to "Highest 32 bit"
4. you can also:
  • click on "Advance"
  • find the tab of your graphic card
  • make sure it is on settings that allow high quality of colors
Apr 26, 2009 | Computers & Internet
Colors are too light
Go into the printer maintenance program and set your saturation level there. I had ti tinker with mine a little bit but, now, about 2000 pictures later, it's still fantastic.
Jan 15, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
I just put in my comp a agp nvidia geforcr rx 5200 grafics card
yes , there a few steps to take for this
1.right click on the desktop
2.click on the settings tab.
3. make sure that the graphics adapter driver is installed if not it will say plug and play adapter
4.if the adapter is installed continue with step 5
5.click on the colors drop down menu and choose the highest possible colors ... usually 32 bit...
the problem could be.. that you are using an older monitor that does not support higher colors then what you are achieving at the moment.. consult your hardware documentation for that information of maximum colors per pixel.
Jan 08, 2009 | XFX NVIDIA GeForce FX5200 Graphic Card
Xbox 360 60Hz over-satured and displaced colors (normal TV, non HD).
Make sure you have the right colors wires in the right ports
Sep 01, 2008 | Microsoft Xbox 360 Console
Mitsubishi WS-65809 65" Rear Projection Television Logo
20 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
