Question about Philips Magnavox DVD/VCR Dual Player
Magnavox MWD2006 clock will not advance. I have tried unpluggint the unit and letting it sit to refresh. No luck.
My clock chimes out of secrence quarter past then hour chime is quarter to hour? how can i fix please
Sounds like the minute hand is a quarter hour off. Make the clock strike on an hour. Count the number of times it strikes, then remove the minute (long) hand, and the hour hand. Replace the hour (short) hand to the number that the clock struck, and tighten by pressing hour hand in toward the dial, then replace the minute hand in the position that it's pointing at the twelve. Now it should be showing the time that it struck. To make sure, advance the minute hand to the half hour, and let it strike the half. Advance it to the next hour, and it should strike the correct time that is showing on the clock. For example, if the clock strikes four, and is showing three, then move the hour hand to the four while the minute hand is pointed at the twelve, then press the hour hand on each side of the center shaft towards the dial to tighten it. Now advance to half hour, and let strike, then advance to the next hour. It should strike the correct hour. I hope this helps more than confuses. Good Luck
Feb 08, 2015 | Home
Mdr515h dosent work
Sounds like you need to do a "Hard Reboot" . . . Unplug the power cord and let it sit overnight, then plug it back in and it should work for you.
Jan 11, 2012 | Magnavox MDR515H HDDVD Recorder
37MF321D/37 TV turned off last night. This morn, won't turn on
Please read these replies to the same problem. A new power board costs around $284.00..
http://www.fixya.com/support/t465280-magnavox_37mf321d_37
Jan 01, 2010 | Philips Magnavox 42MF521D/37 Television
Self-cleaning door lock is engaged and door won't close. How do I get door look to release so I can close the door?
I would first try resetting the breaker or unplugging the unit for a minute or two and see if that yield`s any success. If not...
Try holding the door switch pushed in.(or held closed in electrical terms) This may require a second person if you can`t reach the clock/timer while engaging the switch. With the switch held, set the unit for self-clean, let the lock advance to a "locked" position and once it indicates it is locked press cancel while still holding the switch closed. This should in theory force the lock to advance to it`s open/unlock position.
Hope that help`s. If so please rate the solution I provided.
Thanks for visiting fixya and good luck.
macmarkus :)
Dec 08, 2009 | Frigidaire Ovens
U99
A U99 error code signifies a general communications failure and is not associated with any specific problem. It could even be related to the firmware version of your DVD recorder.
Try turning off the power and unplugging off-unplug for at least five minutes before reconnecting.
If U99 reoccurs, you should contact the Global Service Center Network for assistance.
Jan 27, 2009 | Panasonic DMR-ES10 DVD Recorder
HP monitor goes black and asking for frequency settings
If you see the initial boot screen until windows boots then you may have a setting for the refresh tate too high in Windows. Try starting in VGA safe Mode by hitting F8 during boot. Once there you go to control panel, Display, settings tab,Advanced and choose monitor. you'll see a refresh rate, try setting it to 60 or 70 and see if it works on reboot.
Be sure to use the VGA option...its ugly during the session but will let you reset the rate.
Good Luck!
Jan 07, 2009 | Computers & Internet
Magnavox MSR90D6 Clock
The clock is hosed and probably never worked on these models...it just sits there, it's like there is no clock crystal or whatever they use these days in DVDR's...
BTW: You can get these untis realy cheap on eBay and probably for that very reason-probably recycled units being sold...
You can record manualy ok with them.
Funai Corp. dropped the ball to get these quickly to market...so sad !!
Feb 15, 2008 | Philips Magnavox MDV650 DVD Recorder
Out of Range
the refresh rate of your computers graphics card is set either too high, or too low. right click on the desktop, select properties, go to the settings tab, and click advanced. then go to the Monito tab, and play around with the different refresh rates, until the picture will show up. This is usually, around 60 Hz or less.
Feb 10, 2008 | Philips Magnavox 27MS343S 27" TV
Database refresh on Iriver H10
I have done this. my iriver is almost full i have the 20gb, when the you do the database refresh, it just takes a really long time. mine takes about 2 hours to finish, once you see the clock on database refresh you cant do anything but wait till its finished.
Oct 18, 2007 | iRiver H10 MP3 Player
Philips Magnavox DVD/VCR Dual Player Logo
52 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
