No Power. Upon Switch ON, juts a sound click and won;t power on anymore. No LED indicator.\Already check fuse, still the same
  • 822 Answers
Needs cops on power board..................
cheers
Posted on Mar 26, 2011
Imac intel will not power on
Possible failed video card. 3rd LED indicates MLB and GPU are communicating: (CAUTION! There is high voltage from the powersupply so any attempt to open iMac other than removing glass panel to see the indicators...should be done by authorized ACMT)
  • LED 1 - Indicates that the trickle voltage from the power supply is detected by the main logic board. This LED will remain ON while the iMac is connected to the AC power. The LED will remain on even when the computer has been shut down or put to sleep. The LED will turn off only if the AC power is disconnected or the power supply is faulty.
  • LED 2 - Indicates that the main logic board has detected proper power from the power supply when the computer is turned on. This LED will be ON when the computer is turned on and the power supply is working correctly.
  • LED 3 - Indicates that the computer and the video card are communicating. This LED will be ON when the computer is communicating properly with the video card. If LEDs 1 and 2 are ON and you heard the startup sound, but LED 3 is OFF, then the video card might be installed incorrectly or need replacement.
  • LED 4 - Indicates that the computer and the LCD display panel are communicating. This LED will be ON when the computer is turned on and video signal is being generated. If the LED is ON and there is no image on the LCD display panel, the LCD display panel or inverter might be installed incorrectly or need replacement.
Aug 01, 2017 | Apple 24" iMac Desktop
My haier tv model no. hl42e wont come on
Hello
If its power indicator LED at the front panel is also do not light up, there is some fault with its power regulator board inside it. Open your tV, and locate the power regulator board. It is easy to locate as, AC power goes direct to it after ON/OFF switch. Check the protector fuse [a glass cartridge type will be used] is burned out or not. If it ahs burned out, replace it with same type in both size and ampere capacity. You can not is rating on its rims; or it will be markde on the printed circuit board itself, under the fuse holder.
If the newly inserted fuse also blow out as soon as you switch ON the Tv, never use anymore fuses, as there is some direct short circuit with that power regulator board. It is better to replace that boad as card basis, than making any "surgery" to it. OK.
Oct 11, 2011 | Haier HL42E LCD TV
Olevia 537-b11, blue light won't come, even when power cord is replaced. Please help!!!!
Since you've already replaced the power cord and still the led light won't came on, this is an indication that the power supply board of your unit is dead. If it is not under warranty period(if so, avail it because the manufacturer will fix it for free) open the back cover and check the continuity of the fuse using the multimeter, if you found it open replaced it with the same current(ampere) ratings and then try to turn on the TV. If the replacement fuse blew again, this is an indication of more serious problem on that board. If the replacement fuse didn't resolve the issue, other parts on that board gone to malfunction as well. If this is the case, I would advice you to replaced the entire board for your convenient. The cost will almost the same rather than troubleshoot it. Check the actual part no of your board and check this LINK.
Hope I helped you.
Have a nice day!
Thanks for using fixya.
Sep 09, 2011 | Olevia LT37HVS 37 in. LCD HDTV
Okay, so my Panasonic PT-43LC14 went black in mid show last night. The bulb is approximately 18 months old. The LED indicators upon Power On are; Power LED blinks green for approximately 70 seconds; Then...
Check the bulb again and look at the root of where the main stem comes out inside and be sure you don't see any bubble like appearence around the stem at the bottom there. If you do see this then the bulb is bad. Otherwise try this: Hold volume down on front of unit and pip on remote for about 5 seconds. Message will come on screen that timer has been reset to zero. This sets the lamp timer to 0
May 17, 2011 | Panasonic PT-43LC14 43" Rear Projection...
My Washburn SX65C is not working
check the grounding resistors, 300-470ohm 5 watt, big ones. they may need to be resoldered to the board, they get hot and break solder we;ds as they cool.
Apr 22, 2010 | Washburn Amplifiers: 25 WATT Guitar...
Generic Laptop Won't Boot Up
You are going to have to send it in for Repair. Your Version of Windows Embedded has been Corrupted and they will need to Reload it.
Jan 22, 2009 | Generic Memory USB-Powered Silver Acrylic...
Generic computer won't boot up
Have you tried removing the main battery and the cmos battery for about 30 minutes?
Jan 22, 2009 | Acer TravelMate 2300 Notebook
43H70 has sound by no picture
also check the horizontal o/p transistor for short if ok ,look on the deflection board and see if there are any b+ voltage markings and test with meter for b+.
Sep 12, 2007 | Toshiba 43H70 43" Rear Projection...
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
