Question about Microwave Ovens
What cleaners can I use on a Thermocast acrylic sink?
  • 822 Answers
Cream cleaners only.....others are abrasive............
cheers
Posted on Mar 26, 2011
Never have used a garbage disposal, now after 4 month and using it only about 30 times the water in the sink will not drain. When I turn on the garbage disposal the water in the sink swirls so I know it is...
hello fowl..... you have a blockage in the garbage disposal. you can use a chemical drain cleaner and pour it into the sink where the disposal is located. you should also look into that drain with a flashlight to make sure that there is not a fork or some other object causing the blockage. If you do not choose to use the chemical, you can also disconnect the disposal using the wrench that should be under the sink where the disposal is located. if you choose this method, have a pail handy to catch the water. also unplug the disposal before you work on it. Joe
Apr 24, 2011 | Microwave Ovens
Tip
SOME USEFUL KITCHEN TIPS.....!!!
1) To get much cleaner and sparkling dishes just add few tablespoons of VINEGAR to your
dish-washing detergent....Vinegar is a master in cutting of the grease that helps in getting sparkling dishes easily.
2) To clean the spills in Oven just sprinkle some salt over hem immediately. After the oven has cooled
down, brush away the spills with damp cloth.
3) Smelly sponges are a real mess....to clean them just clean them properly and thoroughly and then microwave it
while its wet. Once you see steam arising from the sponge take it out...and be CAREFUL as it will be too hot.
Wash before reusing it, with water. Be sure that there are no METAL components in the sponge.
4) For removing lime build up and hard water from a teapot, just add 1-2 cups vinegar to some water in
teapot and bring it to nice boil. Sim for 10 minutes and then rinse it out.
5) OLD STAINED SINK....To clean and whiten it just add half cup of salt in it and then scrub it
with a lemon over it to get a sparkling sink as new.
on Apr 09, 2010 | Microwave Ovens
My Grohe Ashford faucet is loose from kitchen sink. For the price - the things seems cheap to me - under the sink some traingular piece of plastic holds it in - but no apparent screw to tighten? What am I...
Sorry, I got your solution and was about to post and at the same moment supply went off. I don't use a ups. sorry for my fault. I will not let your money flush out, Indeed I will fix your sink. I'm barely on my bike battery because no supply is here kindly give me another few hours because we are facing a torando out here. I will make sure that you will get your output more than your investment.
Apr 02, 2011 | Microwave Ovens
When my dishwasher drains both sides of sink fill with water...then they both eventually drain back into the dishwasher.
Sounds like your sink drain trap or line is clogged. When the dishwasher drains, the sink drain can't keep up, the water backs up, then backs down the dishwasher drain line into the dishwasher. You may not notice the slow line when you run a little water into the sink, but with the amount of water coming from the dishwasher the problem is worse. You can try taking off the trap under the sink and making sure it's clear. If the problem is farther down the drain line, you can try snaking it yourself, or call a plumber. I don't recommend using Liquid Plumr or Drano because if those don't work, they leave the line full of caustic chemicals for the next person who works on it. That can be dangeerous.
Dec 07, 2010 | Microwave Ovens
I need to clean brown stain and scale (?) from two 'plastic' tea kettles, one a Chefmate, the other a Kitchen Gourmet. The latter is much more stained than the other, with entire interior incuding spout...
If you can find this product: (Or order it online)
el-4.jpg Picture: http://www.sanishieldproducts.com/images/el-4.jpg To find a distributor: 800.528.3149
Shower Tub & Tile Cleaner
  • CLEANS everyday scale, calcium, hard water spots, soap scum & body oils on showers, bathtubs, tile and sinks.
  • EFFECTIVE on glass, fiberglass, clear plastics, ceramics, aluminum, stainless steel, brass, chrome, porcelain and cultured marble surfaces.
  • UNIQUE biodegradable, cherry-scented chemistry. 32 fl. oz. size (950 ml)
ELIMINATE" TUB & TILE CLEANER 32 oz.
  • Non-toxic, non-fuming non-abrasive, non-corrosive, non-flammable
  • Biodegradable
  • Removes soap scum, scale, hard water deposits and body oils
  • Safe on plexiglass, plastic fiberglass, chrome, brass, gold, silver and ceramic
It is carried by Ace Hardware $6.49 ea
An awesome product that you spray on and let sit overnight. then simply wash it off. (Non Toxic / Non corrosive) No gloves required but does have an odd odor so I would let it soak outside. Heavy accumulations may require a second treatment.
Also great on shower heads. Remove it.. place it in a glass overnight and then re-install the next moring. Does not discolor anything. Ditto for shower enclosures and tile. Why this product is not in great demand is a mystery.
Link with picture: http://milo.com/32-oz-eliminate-shower-tub-and-tile-cleaner (out of stock!)
THIS WILL Clean it.
Kelly
Sep 10, 2010 | Microwave Ovens
I have B30 Mini Keurig. The green power light comes on but the blue flashing light never comes on after I put the kcup and water in there. It does not brew. What could be wrong?
I also just had the same problem- the answer for me was the coffee mug. The sensor lights where you place your mug don't like certain coffee cups- in my case it was any clear mugs. First I had a clear acrylic coffee mug, then a clear glass mug, then tried regular opaque coffee mugs and it worked fine. So maybe if it's clear or somewhat transparent it might mess up the sensors. Hope that's all the problem is for you.
Aug 29, 2010 | Microwave Ovens
I have a stainless steel sink in my RV. When it was stored for the winter, I used FRI-Z-AIR containers to absorb moisture. Some of the crystals spilled into the sink and actually etched spots into the sink...
I would try SOS pads or even fine sandpaper if necessary. Make sure you go with the "grain" so it isn't obvious afterward. It is possible to blend with those grain lines in stainless steel, we used to do it in a factory.
Aug 04, 2010 | Microwave Ovens
My hand sprayer on my sink is leaking every time I turn the water on. It's leaking from the sprayer and in dripping under the sink. How can I fix this?
Check for a leaking O-ring/Washer/Seal and replace. Sometimes the internal parts of the sprayer head will wear out. Replacement sprayer heads can be obtained from your local hardware store.
I'll look forward to hearing back from you. :-)
Apr 26, 2010 | Microwave Ovens
Microwave oven H-4020 BM...... How to clean inside????? I am unable to get the stains off and inside looks terrible.
First, wipe out any excess crumbs. Then fill a microwave-safe bowl with about 1-2 cups of water. Add some lemon juice, or put in half a piece of fresh cut lemon (squeezing some juice out first) into the bowl... Microwave until the water is boiling. Then let it sit for a few minutes to let the steam penetrate the interior. Carefully remove the bowl and interior tray. Wipe down the interior with a damp cloth. Wash the tray in the sink with dish soap, dry, and then return to microwave. For the outside, spray with a kitchen cleaner and wipe with paper towels. The main idea is that the steam from the water will loosen food particles, and the lemon will add a fresh smell.
Jun 23, 2009 | Miele H187MBALU Convection/Microwave Oven
GE Spacemaker XL 1400
Jun 23, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
42 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
