Question about Fellowes PS70-2 Shredder
Fellowes ps70-2 the red and green light is on , it will work in rev
Fellowes Powershred PS80. Took bin out to empty, now wont run.
Had similar problem. Make sure there is absolutely nothing stuck in there. Get the vacuum on it if you have to. It is simply not making proper contact.
Jan 25, 2014 | Fellowes Office Equipment & Supplies
Red and green light is on but it wont shred
I own a Fellowes PS 60 shredder.
Here is a link to the manual for a Fellowes PS60 Shredder.
Maybe it will help you in resolving some of your problems.
https://app.box.com/s/q3r8jlatlfskvgyh5ne6
Fellowes Shredder PS60
Nov 13, 2012 | Fellowes Powershred PS-60 Shredder
When plugged in and turned on, both the red and green light come on and it does not work forward or in reverse
Mar 27, 2011 | Fellowes Powershred PS-60 Shredder
Green and middle red light go on but motor does not. does not shred
Check the sensors on top and bottom of cutters. Clean with cotton swabs and compressed air. If this does not help, bad sensors or main board.
May 14, 2009 | Fellowes DM8C Cross-Cut Shredder
Need a sensor switch for fellows powershred 220. Won't sense paper.
The top sensors may be bad or even the main board that they are connected to is bad. Try cleaning them with a lightly moistened swab or compressed air. Fellowes will sell you the parts.
Apr 29, 2009 | Fellowes Powershred 220 Shredder
Fellowes shredder will not work
Check the front door switch and the BIN FULL switch actuator.
Oct 22, 2008 | Office Equipment & Supplies
Red light on with green light
This is more than likely a sensor issue. Fellowes Customer Service can advise you on a solution with a little more info than provided. 1-800-945-4545
Oct 16, 2007 | Fellowes PS70-2CD Shredder
Fellowes PS70-2 Shredder Logo
183 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
