Question about Craftsman Saws
I have a 7 1/4 inch circular saw and I need to get the blade off. Which way does the bolt turn?
  • steve_kunkee Mar 26, 2011
    What does left to right mean? Clockwise or counter-clockwise??
    I added a comment, then saw this so I posted here too - left to right means nothing to me. It is ambiguous. Is it clockwise or counter clockwise? left hand or right hand threads?
    Master:
  • 406 Answers
Counter-clockwise.
Posted on Mar 22, 2016
dontbother10
  • 2220 Answers
SOURCE: On a 10 inch power
Place a finger nail in the thread near the end ot the shaft. If when rotated CW it comes off the shaft it is a left hand thread. My 10" Craftsman radial saw has a left hand thread on the blade shaft.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Jul 30, 2010
jyackle5
  • 8197 Answers
SOURCE: I cannot get the blade
The blade bolt on the saw has reverse threads. If you need a new bolt you can order one at the link below. You will need the model # of the saw though.
http://www.dewalt.com/parts-and-service.aspx
Good Luck please rate 4 thumbs up and please leave a testimonial
Posted on Oct 10, 2010
  • 4088 Answers
SOURCE: Cannot get bolt off to
Try turning the bolt in the opposite direction. Many saws use a left-hand threaded bolt to prevent self-loosening. Hope this helps!
Posted on Jan 10, 2011
mc1bean
  • 3053 Answers
SOURCE: How do I change the
Here is what you do, this is common on some skill saws, you of course make sure is unplugged, get your self a stick ( like a small broom handle type, or a piece of 1 by 2 chuck or wood, or anything of about that size. Put saw on its side, with the blade side toward you to get access to the nut to take off blade. As you know the blades go down( clockwise when operating to cut wood) and of course now, you have the problem of taking off the blade counter clockwise because the angle of the blades are going back words, ( nothing to grab on to the wood, to put a wrench on going counter clock wise to take nut off. What the idea for you and normal way is this, as the saw is on the side, with the nut/blade side toward you, you wedge the piece of wood, between the left top side of blade under the frame of the blade, meaning you are wedging it in, so the blade when turning the nut counter clockwise to unscrew, will stay in place. Think of it as wedging the blade with a chunk of wood, so it will not move. AGAIN, it comes off (nut) counter clockwise, so, you are just using this wood chunk to keep blade from moving, and then to put new blade on, just reverse procedure. Thanks Mike
Posted on Jul 26, 2011
psycodelek
  • 202 Answers
SOURCE: How do I tighten my
make sure its unplugged 1st then put a screwdriver in the hole on the blade to lock it while you turn the nut clockwise
Posted on Sep 18, 2011
Circular saw motor turns when tightening saw blade
Insert a tool such as a screwdriver across the blade guard and against a tooth to prevent blade rotation, then tighten the blade nut. Be sure to remove the wedging device before operating the saw
Dec 29, 2012 | Now Evolution #Fury 7 1/4" Mp Circular Saw
Change blade Makita LS1030 10-Inch Compound Miter saw
There is an 8mm bolt on the front of the guard. Loosen/remove this and the central guard mount will drop slightly. Behind the metal guard is a slide lock for the blade spindle. Push the lock bar and turn the blade untill it catches and is held solid. Then remove the blade fixing bolt and bobs your uncle. Alternativly, with all mitre saws, you can just pop an old bit of wood on the work base and then use the spannrer/allen key supplied to turn the blade so it bites into the wood as if you are trying to cut it. This will hold the blade steady and you will also be turning the bolt in the right direction.
Jul 23, 2012 | Makita 10" Miter Saw LS1030N
Cannot get saw blade off a makita 5090d saw.
Lift the guard and clamp the blade in a vice using a pair of soft jaws and then undo the bolt.
Jun 10, 2012 | Makita 5090d 96v Cordless Trim Circular...
My Craftsman 7&1/4 inch 12 amp Circular Saw(Model 315.108330) slips while cutting. The motor keeps spinning but the saw stops rotating. Can I Fix it?
Most circular 7-1/4 saws have a bolt and a compression washer that acts as a brake shoe that holds the blade secure but under dire circumstances will allow the blade to slip some rather than hold the motor shaft and allow burn out. The compression washer under your bolt has become worn and doesn't grip the blade securely. You can find a split washer that will fit under the blade and give you some more friction, or go to sears and order another compression washer for your saw.In the Sears Parts List found at: http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Saw-Parts/Model-32018780/0247/0744410/50035950/00001?blt=06&prst=&shdMod=
see part no. 44
Feb 23, 2011 | Craftsman Evolv 12 Amp 7-in Circular Saw -...
Cannot tighten blade on old craftsman circular saw.bolt turns blade shaft and motor without tighting blade
Is the washer/spacer in the blade too thick and you are perhaps tightening up on that instead of the blade. Also check the threads on the bolt, see if the bolt turns all the way in without the blade in position. It may be jamming up before gripping the blade.
Jan 24, 2011 | Sears Craftsman 7-1/4 in. Circular Saw...
7 1/4 B&D saw - blade stalls but motor continues to run
There should be a special washer between the bolt (that holds the blade on) and the blade. If the arbor has a flat side on it, then the washer should have a matching hole so that the washer cannot turn independently of the arbor. Or, some saws use a spring washer which is cupped and becomes flattened against the blade as the bolt is tightened. If you have the first type of washer, perhaps the bolt is just not tight enough. If you have the second type of washer, perhaps the washer is backwards. If you have neither type of washer, you need one.
Jul 28, 2010 | Sears Craftsman 7-1/4 in. Circular Saw...
How can I change the circular saw in my Back & Decker Circular Saw, model: P3703 (1100 watts)
Unplug it and loosen the bolt in the middle of the blade. It's a standard thread, so turn it lefty-loosey. But you need to hold the blade from turning. That's easy by putting a screwdriver in front of a blade tooth, under the sole plate. Let the sole plate prevent the screwdriver from rising up with the blade as you turn the bolt. If your current blade has small teeth (like a plywood blade) then you can raise the sole plate as for a maximum depth of cut, then push the saw against the front edge of a workbench (or block of wood somehow held still) as if you were going to cut it. Before you remove the bolt, take note of the exact orientation of the washer (or washers)so you can replace them the same way.
Jun 18, 2010 | Black & Decker Saws
How do I install the blade on a bosch cs10 circular saw
Their web site seems to be down at the moment but most circular saw you just need to lock the blade somehow. Sometimes putting the blade up against a piece of wood so it can't turn will get the job done. Unplug the saw so it can't run. Some saws come with a custom wrench to turn a custom bolt, others a regular combination wrench would work. There should be a bolt that goes into the center of the blade. To keep the bolt from coming out while cutting, they are reverse threaded so you loosen it by turning the bolt the reverse direction you on a normal bolt. take the bolt out and be careful you don't loose the washers on each side of the blade. Put in new blade and reverse the process of taking it apart.
Dec 02, 2009 | Bosch Circular Saw Blade, 6 1/2"
Craftsman # 315,10851 7 1/4 inch circular saw.
In the past I have clamped a pair of vice grips on the old blade so I could remove the bolt from the arbor.
Sep 12, 2009 | Saws
I have tried numerous times to undo a nut on my Black and Decker circular saw without success. which way do I turn the nut to undo it and take the circular saw blade?
Am I correct that this is a hand-held saw? Want to make sure of the terminology.
If so, the bolt holding the blade has right hand threads -- meaning it loosens by turning counter-clockwise.
Is there a blade lock? Are you using it?
Apr 30, 2009 | Saws
Saws Logo
176 people viewed this question
Top Craftsman Saws Experts
Craig Butler
Craig Butler
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
