Inside unit won't come on but outside will causing severe frost buildup.
  • jcord25 Sep 05, 2008
    The inside unit will not come on until I move the set switch all the way to right and the back the set temperature. The unit will then come on in about 30 seconds as normal
  • 1,420 Answers
MaKe and model number?
Posted on Aug 04, 2008
I have only had my frost free fridge freezer 1 year could you tell me why my freezer only freezes the 2 bottom trays and not all 4?
Can you provide a model number and Make? Example below
Cooling stops? Frost buildup on walls in freezer or fan inside or outside fridge not running? Let me know by answering my post here, Thanks John T. Appliance 911
Contact
Apr 30, 2015 | Frost Refrigerators
Frost buildup
POSSIBLY faulty door seals allowing outside moisture to enter freezer compartment. This is especially prevalent in older units and/or tropical climate zones [ie high humidity] ... OR if freezer is OVER-LOADED with food items !!!
If you are putting in large quantities of fresh produce to be frozen it is quite often better to PRE-COOL all the items in your refrigerator PRIOR to placing in your FREEZER as they will usually have a high moisture content which will cause frost build-up in your freezer ...
Sep 20, 2014 | Refrigerators
Royal dometic. not sure year or model. started cooling several days after power connected..auto defrost kicked in second time there was frost buildup and now neither fridge or freezer will get cold..have...
When you feel cooling unit from outside behind cover and unit is on for a couple of hours min, does it feel warm, hot? describe any other things you notice please.
Apr 09, 2013 | Refrigerators
Wine cooler frost buildup
Some dual temperature wine coolers build up frost in the rear and top of the main compartment. Check the defrost timer, located either inside the main compartment near the light, or outside on the back of the wine cooler near the compressor. Look in the owner's manual for the correct settings for the defrost timer and adjust yours as needed. Make sure that you have the wine cooler in a spot where the outside temperature remains at or near room temperature to reduce frost buildup.
Aug 11, 2012 | Danby DWC283BLS Wine Cooler
Freezer compressor gets hot
Check behind and underneath for dust buildup, sounds like your compressor needs cleaned on the outside, the dust is causing it to overheat and retain condensation, hence the ice buildup. Easy thing to check, good luck.
Jul 02, 2017 | Frigidaire 19.53 cu. ft. Commercial...
Ice forms inside unit -frost buildup-on outside-out side fan shaking unit fan running fo r ours
First to solve your icing problem. Due to indoor coil & air filter blocked or short of gas ice formation will be there. And also check the speed of blower motor, if less rpm, change capacitor for blower motor.
Service the unit also.
Second, for shaking the unit means your out door fan cracked or broken. Check and replace it. Is it helpful?
Dec 16, 2010 | Heating & Cooling
We have a window unit model ash08fas1 and it is leaking water into the window to our carpet. Does this model come with a drip pan or plug that needs to be moved? And how do we access it?
Look at your unit from outside the house. The back of the air conditioner should be slightly lower than the front. If it is level or the front of the air conditioner is lower it will drip into the house. Some window units have a drain for the water outside and some don't. Look for a hole in the bottom of the unit outside and if you find one make sure it is not plugged. Also dirty coils can cause a frost buildup on the inside of the unit. This will drip also. If this is the case you should see the ice buildup by removing the front cover or removing the front filter.
Jul 04, 2010 | GE ASL05LA Air Conditioner
Bottom freezer model.. looks like shaved ice all over inside.. not sure why it is frost free...
u most likely have a defrost component out that is causing ice buildup. this will start blocking the flow of air and cause cooling problems. usually it will be one of 3 things. defrost heater, bi metal defrost terminator or defrost timer or on some units an adaptive defrost control. this problem takes about 7 - 10 days to start causing a problem. removing all frost behind panel will buy you as much time.
Mar 03, 2010 | Refrigerators
Samsung refrigerator - frost on outside of freezer drawers
try checking the freezer door seal.
if slight gap anywhere around the door seal drawer fronts will frost up.
warm seal up with hair dryer and ease seal out with your hands..
problem often happens with door reversal.
Oct 09, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
AIR CONDITIONER
Do you have any frost on the lines going to the outside unit. If the large line is frosted your evaporator (Cooling coil in the furnace) could be frozen up. Operating it with the fan in automatic with the cooling on will sometimes be the cause of this condition.
If there is not frost on the large line going to the outside unit and you are getting air circulation inside the house the problem could be a loss of refrigerant charge. Look at the joints where the pipes were soldered to the inside and outside units for signs of oil. If you find oil at any point it is the indication of a refrigerant leak.
May 17, 2008 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
46 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
