Question about True 72 cu. ft. / 2039 liter Commercial Freezer GDM-72F
I NEED LIGHT BULBS FOR FREEZER GDM72 TH REE DOORE IF U FIND IT PLEASE CALL ME AT 3134714631 OR EMAIL ME AT # darousalam48033@yahoo.com
    Guru:
  • 1,524 Answers
Try any good electrical supply for them.
Posted on Mar 27, 2011
How do I replace the lights in my freezer
Turn off the power to the refrigerator/freezer by flipping the appropriate switch in your breaker panel. Alternatively, unplug the refrigerator from the wall outlet.
Open the freezer door. Remove any items from the shelf directly under the light shield, then remove the shelf.
Press down on the top, front edge of the light shield until the locking tabs slip out of the slots. Swivel the light shield downward slightly to release it. Pull the shield out of the freezer compartment and set it aside.
Turn the light bulb counterclockwise to remove it. Insert the GE replacement bulb into the light socket and twist it clockwise.
5
Reattach the light shield by sliding it into place. Gently push the tabs into the original slots.
6
Insert the shelf into the freezer and reload it with the frozen food removed earlier.
7
Close the freezer door. Restore power to the refrigerator by flipping on the breaker or plugging it into the wall outlet.
Jul 25, 2017 | Freezers
How do I replace the door light switch?
I appreciate your post, Deborah!
From what you have described you need to replace the door light switch on your Frigidaire freezer. In order to assist you further I would need your model number. You can locate your serial tag (which lists your model number) on the inside wall of your freezer. I look forward to assisting you. -Matt
Apr 27, 2015 | Frigidaire Freezers
Freezer light bottom not working,bulb good
Warranty time, call maytag, most fridge come with 1 year warranty.
Oct 27, 2013 | Maytag Ice2O MFX2571XE 25 cu. ft. French...
Lffh21f7hwa
Hello Michael - Sounds like the temperature control was accidently turned OFF. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try activating the freezer by pressing the UP arrow until display shows "4" or desired setting. Allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
Jul 01, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
High temp light on, loss of door suction, ice in channels in back pannel of freezer, Why is autofefrost not working? Have to leave empty for 2-3 days to defrost.
The defrost heater element has failed, it has created so much ice buildup on the cores air can not draw through the chanels in the cooling plate, should not be that expensive to repair.
Regards Russ
Dont forget to vote and if you need any more help, Email me at wgheaven@yahoo.com.au
May 07, 2011 | Hotpoint 4.87 cu. ft. / 138 liter Upright...
Light not working in GE chest frezer it is larger than the model below, 22 cf, it is 25 years old.
Check the bulb, check the tabs within the socket, check the door light switch.
Please, unplug fridge when testing these. We'd like to hear from you again.
Mar 27, 2010 | GE Freezer  14.8 Cu. Ft. Manual...
Lights wont come on in the cooler
underneath the unit in the metal box there is a ballast for the lights check it to see if it is getting power and or producing power to the bulbs
Jun 15, 2009 | True 23 cu. ft. / 651 liter Commercial...
Need to change the lightbulb located on the freezer door. Do I turn the bulb counter clockwise or opposite?
Right-tighty, lefty loosey...that would be counter clockwise to remove, clockwise to insert. If the bulb is stuck, you may have to defrost the freezer (I know this sounds a bit extreme) to get it out easier. You may have some ice crystals keeping it lodged in the socket.
May 04, 2009 | Whirlpool 19.6 cu. ft. Upright Freezer...
Kenmore chest freezer about three or four years old.not cooling
Probably a freon lean and not worth repairing. You can never find the leak in a chest freezer. Recharging will buy a little time but you can never reallly trust it again.
Apr 28, 2008 | Kenmore 8.8 cu. ft. / 249 liter Chest...
True 72 cu. ft. / 2039 liter Commercial Freezer GDM-72F Logo
96 people viewed this question
Top True Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a True Freezer Expert? Answer questions, earn points and help others
