Question about Maytag MTB2156G Top Freezer Refrigerator
Freezer is not keeping food frozen and water is leaking between the freezer door and seal on the freezer door? The fan is blowing cool air.
  • Maytag Master
  • 2,699 Answers
Is the compressor running?how long has the freezer been melting out?if you open the fridge door,turn the cold control up and listen to see if you hear the compressor start,if it doesn't try tapping on the control with a screw driver,if the control is bad it sticks inside and if you tap it sometimes it will free it and start but it will stop again,just doing this to check what's bad in the fridge,lso there's a timer in the fridge section,look around where the control is,you'll see a hole in the bottom of the console,you can stick a straight bladed screw driver up it and turn it slowly until it clicks,if the compressor starts when it clicks you have a bad timer and it was stuck in defrost,if the compressor is running and the freezer is still melting out you could have a leak in the sealed system a freon leak,you can check this by removing the back inside wall of the freezer,look at the evap coil,if there's just ice on the top instead of an even frost pattern over the whole coil then you have a freon leak,if the fridge has been running and you look at the coil it should have frost covering the whole coil,if ice is just on top it's new refigerator time,get back to me and let me know if the compressor is running,iis the door closing correctly and no rips in the gasket,if it has a light in the freezer push the light switch in and make sure the light is going out,if not the bulb is heating up the freezer,make sure the evap fan is blowing in the freezer and no ice on the back wall of the freezer,has any water been dripping into the fridge from the freezer,if so you have a blocked drain.do some checks and get back to me,if the freezer is melting out it sounds like you have a compressor problem
Posted on Mar 26, 2011
All fridge,wood, verry noisy when start,when noisy seems to stop,run,stop,run,several time.modele no is.RFA17WCA. If touch inside...it seems to be a vibrating "FAN"?
First, I'm not a WOODS tech.
Check your warranty and call for service.
*** Following is for information only.***
* Your circulation fan (usually on the freezer side) has ice building up near fan. OR there is a paper or plastic caught in the fan. Check and clear debris.
* Check for air movement while fan is running. Many have plastic ducting that pulls air from the bottom that is usually covered by the lower drawer. Pull out the lowest tray and check the back for ice or food that fell in back to block the air vent. If it's iced up, DON'T hit it as you will crack the plastic. Leave the door open, Turn off and let the freezer defrost. (remove food).
* Check the upper fan vent for ice blockage. Defrost as needed.
* Unplug refrigerator to defrost. (Get help to move as the fridge is heavy and may tip over on you.)
* Once completely free of ice (it takes a while. A fan blowing into the freezer helps. ***DONOT use a heater!*** Warps panels and may over pressurize refrigerant.)
* Allow a completed defrosting of the freezer. (Place frozen foods in refrigerator side to keep it cold while the refrigerator is off. Better to transfer everything to another refrigerator.)
* Keep checking and dumping the drain tray as the ice melts. If no water drains then the line may be clogged. Call for service.?
* Plug in refrigerator but leave out where you still can unplug it if you need to continue to defrost. Move it back only if everything is working (so far).
* Set the temperature to middle of dial and the freezer diverter to normal (middle). Leave fridge empty to allow it to cool down without a load. Check for icing (there shouldn't be any as there is no moisture in box to ice up.) If there is ice then it did not defrost enough. Turn off and repeat manual defrost (open door)
* Once your sure all the ice is gone and the freezer is cold. Move refrigerator back into the counter/wall. (it's lighter but get help anyway.) Start putting back the frozen goods. Try not to cram in everything. Keep enough space on racks to allow air flow AROUND the whole shelf. Keep away from leaning food against the walls and back.
?* Leave the temperature setting at mid range. Your refrigerator should be able to keep food frozen at this setting.
* Check your door seals for cracks
* Check your door perimeter for warmth. It should not be sweating or ice cold. Cool or slightly warm to the touch is normal.
* Check your side panels (not doors). It should be cool but not iced or sweating.
* Final, with the Temperature set at mid range. If your still getting ice then you have a vapor leak. (Moist air getting into the freezer) Note that this moisture can also come from hot moist food placed in freezer without pre-chilling it. If you must put hot food In the freezer. Then place it in the refrigerator section for at least an hour prior to the freezer. The refrigerator can handle the moisture load better than the freezer. The refrigerator just collects the water and drains it to the bottom pan.
* Again, check your warranty and call for service. Have them perform yearly maintenance to check everything.
Aloha, ukeboy57
PS; If everything is okay (so far) then only gradually adjust the temperature SLOWLY. You will find that maxing to the coldest setting will only build up the ice quicker. Normal freezer operation can take care of the occasional (daily) opening of the freezer door. It will 'dry' out the frost and ice build up (If given the chance). But if you find that Ice keeps building then you need a bigger new ice box.
Mar 11, 2018 | Refrigerators
My LG window AC icing on the grid even in fan mode. Once started it gets covered with ice within 1 hours in both cooling as well as fan mode? What can be the reaon
First, I'm not a LG tech.
Aloha, ukeboy57
Feb 21, 2018 | LG Refrigerators
My Vissani fridge model HMDR1030 fridge compartment is not cooling. We'd been noticing our drinks weren't cooling for about a wk. The freezer is ice cold with a small amt of soft frost. I rearranged the...
First, I'm not a Vissani tech.
*Check your warranty and call for service.
* I see that you have done most of the following. I'll post the full answer for others to review. You probably need a complete defrost and return the settings to the middle.
*** Complete answer as follows ***
Aloha, ukeboy57
Feb 20, 2018 | Refrigerators
Lg lbc22518ww bottom freezer not keeping food frozen
door seals may be bad. check for cold air leaking especially on the corners and the hinge side.
Feb 28, 2014 | LG LBC22518 Bottom Freezer Refrigerator
My freezer frosted over everything because the door was not shut tight and now it will not clear.
take out all the food out of the freezer,unplug the fridge and get a hair dryer and start melting out all the ice in the freezer,then blow the hot air into the vent holes on the back wall until you don't see any more water dripping down through the slots in the back wall.turn the machine back on,open the fridge door after around 5 or 10 minutes and if you feel cold air blowing into the fridge you fixed the problem,if you don't feel cold air keep hitting the inside back wall with the hair dryer and keep blowing the hot air into the holes in the back wall.all that it does is the freezer gets cold and there's a fan behind the back wall in the freezer,the fan blows the cold air into the fridge side,if the air ducts are frozen the air can't circulate into the fridge section so you have to melt the ice out so the cold air can blow from the freezer to the fridge.good luck,if you have another fridge remove the food and unplug it and leave the doors open for a day and it will melt out.good luck
Jun 16, 2011 | Kenmore 65234 Bottom Freezer Refrigerator
Refrigerator portion on top does have cooling but freezer on bottom works fine. I have read that the cooling all happens in the bottom and a fan transfers cool air to the the top.
if the fridge part is cool and freezer is fine what problem are you having?is the fridge not cold enough? a common problem with bottom mount freezers is the freezer door doesn't get closed all the way,warm air enters the freezer mixes with the zero degree air and freezes up the air ducts,when you open the freezer door you should hear the fan blowing,if it is check the ceiling in the freezer to see if ice is on it,check the packages for frozen water droplets and stick your hand in the fridge where the air ducts are to see if you can feel cold air blowing into the fridge,if you can't feel air blowing into the fridge,unplug it,open the freezer door,remove the top basket and remove all the food out of the bottom basket,with a hair dryer blow into the back wall into the vent holes and melt out all the ice in the ducts,you'll see water dripping down through the vent holes,when the water stops dripping plug it back in and see if the fan is blowing the air into the fridge.also you can remove the bottom kickplate and you should see a tech sheet in it,read it and it will tell you how to put the machine into defrost,it will stay in defrost for like 20 minutes,you can do this instead of unplugging it, there's a heater that comes on behind the back panel in the freezer,this can help you melt out the ice but if it seems to hard to do just unplug it.
May 25, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
The freezer side is not keeping food frozen. Every three minutes I hear something turn on and it runs for about xx seconds. The model number is ASD2626HES. The refrigerator side seems fine.
Check the temperature setting
Assure that there is enough room for air flow in the freezer or freezer
Check for air flow restrictions in vents
Test the temperature control
Clean the condensor coils
Check the door seals
Test the door switch
Test defrost heater
Test defrost timer
Test evaporator fan
Check for a clogged drain tube
Check for refrigerant leak
Freezer is too cold
Freezer is noisy
Hissing and popping is normal, it is the defrost heater.
Check that the freezer is level
Check the drain pan
Check the condensor fan
Check the evaporator fan
Inspect the compressor mounts
Freezer runs continuously
Defrost the freezer
Freezer starts and stops frequently
Check the outlet voltage
Test the condensor fan
Test the compressor relay
Test the overload protector
Test the compressor motor
Freezer does not defrost automatically
Test the defrost timer
Test the defrost heater
Test the defrost thermostat
Freezer has an unpleasant odor
Remove spoiled food
Clean freezer interior with a solution of h
Clean freezer interior with a solution of hot water and baking soda
Clean the door seals
Remove breaker strips and check for wet insulation
Water on floor outside of freezer
Check the drain pan
If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve
Water inside the freezer
If you have an ice-maker, check freezer and ice-maker for level
Hope this solved the problem, Take care....
Sep 19, 2010 | Amana ASD2626HE Stainless Steel Side by...
The freezer works properly but the lower part doesn't cool would you please help me
Set the freezer control to Warmest.(more air will go to fresh food)
Make sure the freezer fan is blowing.
Check the door seals on fresh food door especially on the bottom.(may be loose letting in warm air)
Aug 10, 2010 | Magic Chef CTB1821AR Top Freezer...
Sub zero 550 (14 years old) has a small but steady leak onto floor from freezer compartment. Small amount of frost buildup on inside of door. Food is frozen and the door "appears" to seal we
Right hand side wall in the freezer - take a look- any frozen water or moisture? Need check a drain line, usually defrost heater inside the freezer wall getting bad and draining water just freezing inside of it.
May 10, 2009 | Sub-Zero Bottom Freezer Refrigerator
Fridge not keeping food cold.
When you open door to freezer do you hear a fan inside that compartment blowing? If you don't the fan motor is shot and will need to be replaced.
Nov 24, 2008 | Jenn-Air JCD2389G Side by Side...
Maytag MTB2156G Top Freezer Refrigerator Logo
118 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
