Lexsor 32" widescreen LCD TV
  • 822 Answers
Sounds like av panel needs replacing................
cheers
Posted on Mar 26, 2011
Why is there no picture?
Hi ricky
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Check the cables, connectors and connections.
If your TV, flatscreen, or monitor is more than 5 years old it is more like to have suffered a
component failure.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
May 13, 2015 | Sylvania LC320SLX 32 in. LCD TV
Screen don't work
If less than 3 months old the set is under warranty-- Any attempt to open or repair it will void the warranty.
May 24, 2012 | Sceptre 32 X320BVHD 32 LCD TV
55" approx 5 months old.
The tv have a problems,with the board that call the Tuner signal board.This is the board,where the incomming broadcasting cable wire plug into this board.This a new tv,take it back where u bought it.Exchange it for a new tv replacement.
Mar 22, 2011 | Element ELC-HS321 32 in. LCD TV
Hi, I have a 3yr old lexsor 27" lcd suddenly the
maybe the lcd screen is the defect already, lcd tv often use daily has a shorter life span compare to crt tv's. also there's possibility the inverter power supply of lcd screen has defect, or the connector is loosen
Feb 06, 2011 | Televison & Video
I turned on my HP LCD 32" TV and just got the
So Brad Brown, if this is what is broken and you take it to a repair shop, what would you expect to pay? I am trying to decide if it is worth it if the TV is 6 years old and we could go get a new one for $350.
Jan 15, 2011 | HP LC3260N 32 in. LCD HDTV
We have a sharp lcd tv. it is 2.5 years old. The
the lcd tv hhave somethig like a bulb and after a period of use that bulb must be changed. take the tv on service. the service man wil see what is the problem most accurate.
Feb 14, 2010 | Sharp LC-32AV22U 32 in. LCD TV
I have a lexsor plasma tv, blue power on tv but no picture screen as if switched off. Remote working on as remote light signal is showing
I have lexsor LCD 32" sound is on no picture,have had to wait for 1 hour for picture to come on ,now nothing?...
Jan 21, 2010 | Televison & Video
Wide screen lcd simple question.
Hi pooing stone,
You may sometimes find that even with a television referred to as “widescreen,” widescreen movies still have letterboxing.
This is likely because the movie you are playing is still in the ratio used at a theater. While most televisions are 4:3 for the more square-type or 16:9 for widescreen, a theater screen is much wider still. Unless the movie has been reformatted specifically to 16:9 for your television, you will either see letterboxing or lose portions of the picture by zooming in.
If a movie is available in several ratios, I suggest thinking of all the options before buying. Although purchasing a movie reformatted to 16:9 will prevent the black bars, purchasing it without any reformatting of the size will prevent you losing part of the picture.
FYI: It is very common with Blu-Ray Discs that widescreen means original size, not 16:9.
Thank you,
Jason,
Go Ahead. Use Us.
Jul 03, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Polaroid FLM 2632 HDTV
I hae replaced my polaroid FLM-2632 3 times it is a crappy tv same problem every time do not buy one
Dec 18, 2007 | Polaroid 3211TLXB 32 in. LCD Television
Televison & Video Logo
965 people viewed this question
Top Televison & Video Experts
