Question about Cell Phones
I have a plantronics LiteSet Cordless Phone Model RF100/01. Serial numbers for the base is B87007940 and the Serial number for the head/belt set is R87007940. The Date of Manufacture is 8802. Do we have an after market rechargable Battery for the set. Thanks.
nasirahmed
  • 282 Answers
SOURCE: SERIAL NUMBER
Please write here the numbers printed on backside sticker.
Posted on May 22, 2008
SOURCE: I lost my manual and I need to know how to program a name and number
I just programmed my phone of the same exact model, I was searching on Google for a solution so I thought I'd share it with you. GE does not have a manual on their website for that model, but I went to the manual of a similar model (27940DC1) that has a manual, http://www.home-electronics.net/ge/pc/IB/27940DC1_IB.pdf . The procedure is exactly the same. I was able to program my new voicemail number in with no problem. Good luck!
Bob
Posted on Jun 08, 2008
SOURCE: cordless phone setup instructions
I need to reset the greeting - Help
Posted on Oct 16, 2008
SOURCE: CDM-8915 PHONE IS DEAD!
The solution: I left it alone for 24 hours.
Here's what I did:
I plugged the charger in and allowed it to charge overnight. No lights or screen or screen appeared but I kept it in anyway. After charging, I removed the battery and cleaned all the contacts with Isopropyl rubbing alcohol. When I reinserted the battery, it vibrated intensely, which indicated a strong battery. I did not turn the phone on right away but waited a day. When I turned it on, it responded like nothing was wrong. Perhaps the phone reset itself. That’s how it behaved.
In any event, I have my phone back and it’s working well.
To summarize what happened:
The phone drops into a puddle and is partially submerged for an hour or so. I find it, dry it off and make some calls, with no effects of any kind.
The next morning, it fails completely. No response whatsoever. I recharge the battery and that doesn’t work. What did work was to remove the battery and clean all the contacts and reinsert it and leave it alone for a day.
Lesson learned: record all phone numbers before I lose them forever.
Also, get a better holster so that the phone is secure from falling out.
Thank you very much for your support.
Bill
Posted on Nov 10, 2008
  • 3 Answers
SOURCE: serial number or dcn number
The serial # is on the bach of your battery
Posted on Jan 02, 2009
I require manual for Logik cordless phone
It is hard to find manual for a phone using the serial number of the base and hand units. Please check if the Logik phone is one of these models
L15DTAM10
L25DTAM10
L35DTAM10
The manual for these can be loaded from
http://documents.knowhow.com/Audio-Mobile%20Phone-Satnav/L15_25_35DTAM10_IB_A6_final100804_running%20change2.pdf
Aug 21, 2014 | Lands Phones
K_akima. about my question on Uniden DECT6.0-cordless phones- where do i find the model number?
Look on the bottom of your phone for the serial number sticker. If you have a multi-handset unit, it will be on the main base.
The product name is in the top left corner of the sticker, above the bar code:
Oct 20, 2011 | Lands Phones
I have the head set connect and can hear the person speak, but the person can not hear me
First, you want to make sure all your connections are secure (the cord from the telephone handset to the base is crucial). Second, make sure the round compatibility dial located to the left of the base is set correctly (never between numbers and usually set to #1 for most phones). Third, oftentimes the wireless signal between the headset and base is compromised so a re-subscription is necessary to make a full connection. Here are the instructions:
http://www.headsetsdirect.com/plantronics-cs55-subscription-pairing-instructions
Aug 05, 2011 | Plantronics CS55 Wireless Headset
I have three handset cordless phone only the main base phone work the other two says connecting when you turn it on but it wont connect it have loss its connection with the base phone
Often the handsets must be re-registered when they won't work. Sometimes they have to be de-registered, then re-registered before getting them to work. Uniden has many different model number 5.8 GHz cordless phones, send a comment with the model number and I will give specific help on your cordless. I have included a link where Uniden cordless manuals can be downloaded if you need it.
http://www.uniden.com/index/manuals_results.cfm?cat=1
Mar 27, 2011 | Uniden 5.8GHz Cordless Phone
Toshiba laptop with IOgear bluetooth adapter installed will recognize phone but won't detect plantronics explorer headpiece. I would like to use it to chat on skype
If the Bluetooth adapter can detect the phone but not the Plantronics headpiece, then there's no problem with your computer or your Bluetooth adapter. The problem has something to do with the Plantronics.
Try to turn the headpiece off, then turn it back on. Set it to discovery mode, then try to detect it using your computer. If that did not help.
Try to detect the Plantronics, using your phone. That will help you in isolating the problem.
Aside from that, make sure that no possible wireless interference while you're searching for the headpiece. Cell phone, base of the cordless phone should be away from the computer while you're searching for the headpiece. Because Bluetooth and cellphones/cordless phones are running on the same 2.4GHz frequency RF signal. They might interfere with each other.
Apr 14, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Lost set up instruction manual for GE cordless phone DECT 6.0
You can find manuals for GE cordless phones here. Pick your model from the list. The model number is on the base unit and is a 5-digit number. The page has a link near the top to help you find the number on your phone. (DECT 6.0 is not a model.)
Mar 12, 2010 | Uniden Cordless Phone
We do not have a manual for our Uniden cordless phone model # U000000175845. Is there any way we can get a copy?
The number you gave looks more like a serial number; it certainly isn't a Uniden model number.
For the manual, select the model from
Oct 20, 2009 | Uniden Cordless Phone
I need an instruction manual for my 222
what manual i have one i have no manual
turn on head set by holding power button
when paired with phone,come on it can't browse your phone for numbers
the side buttons are for volume
if you press the power button two times you will dial the last caller
or you may be able if you have set your voice commands
if you are paired but not connected you can press power button once and it should connect
Oct 01, 2009 | Plantronics - Bluetooth Headset Plus Base...
My bluetooth
Sorry I post the wrong link before, for plantronics manual it is: http://www.plantronics.com/media/media_resources/literature/user_guides/explorer320_userguide_en.pdf
Jul 31, 2007 | Plantronics Explorer 320 Wireless Headset
Cell Phones Logo
94 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
