Question about Shimano Ultegra FC-6503
Remove the crank from the axle - Shimano Ultegra FC-6503
    Brigadier General:
  • 8,546 Answers
Http://techdocs.shimano.com/media/techdocs/content/cycle/SI/Ultegra/FC6500/SI-16T0B_En_v1_m56577569830611829.pdf
"The crank arm can be removed simply by turning the fixing bolt counterclockwise."
Posted on Mar 26, 2011
Excercise bike clunking noise
please follow this steps and fix it. God bless you
Remove the screws or bolts securing the ends of the pedals to the crank axles. Slide the ends of the pedals off the axles. Remove any screws or bolts securing the left and right disc shields to the base unit. Pull or pry the disc shields off the base unit and set them aside.
Remove any screws or bolts securing the left and right side shields to the base unit. Detach the side shields and set them aside. Examine the interior of the base unit and locate the drive belt.
Pull the drive belt free of the crank pulley, flywheel and any other pulleys. Discard the old drive belt and install a new belt in its place. Turn the crank axles by hand to confirm that the belt will turn smoothly when the device is in use.Detach the ends of the pedals from the crank axles. Spread a layer of machine grease over the crank axles, then reattach the ends of the pedals.
Remove the bolts connecting the pedals to the swing arms. Detach the pedals from the arms, then spread a layer of machine grease over the axles on the swing arms. On some models, the bolts may also serve as the axles. Reattach the pedals to the arms.
Remove the bolts connecting the swing arms to the elliptical's upright. Detach the swing arms from the upright, then spread a layer of machine grease over the axles on the upright. Reattach the arms to the upright.
Nov 26, 2013 | Nordic Track Exercise & Fitness
I have a Proform Smart Strider. We just assembled it & when I tested it there's a very loud scraping sound when I stride, regardless of the level or program...help, pls. Thx.
I recomend you to disassemble again, and repeat the steps. Something must be there ARE not according with the instruction assembling. Try however for to see the some loose parts, bolts, nuts, and lube.
See this small instruction.s
God bless you
Lubrication:
Oct 15, 2013 | Proform Smart Strider SpaceSaver...
The wheel on my elliptical is stuck. A couple steps and it got stuck. How do I fix that?
see this causes and fix it. God bless you
Lubrication
1 Drive Belt
Oct 14, 2012 | Exercise & Fitness
Loose crank
It sounds like it is probably a "cotterless" crank, which is now fairly common on modern-day mid to higher level bicycle. These cranks are mounted on the tapered ends of a hardened steel axle. The cranks are aluminium alloy and are easily damaged so they need to be protected when you are tightening them. To properly tighten a cotterless crank, remove the covers that are threaded into the crank over the bolts securing the crank to the axle. Place one crank against a solid point of support (centered on the axle) but protected from damage with a block of wood. Use another block of wood (centered on the axle) with moderately heavy (2 lbs or so) hammer. Strike block of wood as close as you can to the centerline of the axle several times with a heavy blow (like you would need to drive a 16d framing nail). Then tighten the bolts that secure the cranks to the axle and replace the dust covers. Provided the crank didn't become so loose that the tapered sockets on the cranks became mis-shapened, this should solve your problem.
Aug 12, 2012 | Cycling
I need to take my bicycle crank apart
I assume you have a three piece crank (axle plus two crank arms). Go look at the Park Tools website. You will need to remove the little hubcap about the size of a 50 cent piece, then remove the nut on the end of the axle, then use a crank puller to pull the crank off. The crank puller is like a wheel puller in that it has a bold in the middle the pushes against the end of the axle, but instead of having jaws the hook on the outside of the wheel, it has a large male thread that screws into the threads where the hubcap was screwed into. Good luck.
Aug 07, 2012 | Cycling
Bremshey (Tunturi) Orbit Control S elliptical belt alignment
Dear Si: Please do the following>
Detachthe ends of the pedals from the crank axles. Spread a layer of machine greaseover the crank axles, then reattach the ends of the pedals.2
Removethe bolts connecting the pedals to the swing arms. Detach the pedals from thearms, then spread a layer of machine grease over the axles on the swing arms.On some models, the bolts may also serve as the axles. Reattach the pedals tothe arms.3
Remove the bolts connecting the swing arms to theelliptical's upright. Detach the swing arms from the upright, then spread alayer of machine grease over the axles on the upright. Reattach the arms to theupright.
sincerely.
ernesto cuadra
managua, nicaragua. c.a.
Feb 12, 2012 | Exercise & Fitness
My Pro-Form 330 elliptical has a resistance problem--it won't adjust and it seems to be set on a difficult resistance, I can't really pedal it. how do I fix this? I tried switching the levels, but...
Removethe bolts connecting the swing arms to the elliptical's upright. Detach theswing arms from the upright, then spread a layer of machine grease over theaxles on the upright. Reattach the arms to the upright.
Oct 27, 2011 | Proform PFTL79807 - 850 W/ Gamefit...
My proform 2605 elliptical the right foot pedal is making a loud noise like it's slipping.
Oct 01, 2011 | Proform PFTL79807 - 850 W/ Gamefit...
I am trying to remove the covers on my Schwinn 418 elliptical trainer. The covers hang up on the crank/flywheel. The repair manual says to use a crank puller. Is there another way. If not what type of...
Hello there. Unfortunatley there is no way other than removing the crank arms. You do need to remove the nut on the axle and you will need a crank puller. The puller is available at any local bicycle shop for around 10-15 dollars.
Good Luck Tim
Jan 31, 2010 | Schwinn 430 Elliptical Trainer
How to disassemble crank bearing on Schwinn Mesa Mountain Bike
You wil need a couple of special tools, or be fairly creative with the tools you have.
  1. remove the dustcovers in the crank arms at the crank axle
  2. loosen the crank retaining nut/bolt.
  3. thread in a chank puller and pull the crank arms.
  4. remove the lock ring on the adjustable side of the crank axle (Requires lock ring wrench)
  5. remove adjustable bearing cup.
  6. remove axle and bearings
  7. replace or repair as needed.
Once you have it opened up ou can determine if you need new bearings or crank axle.
to assemble, reverse above procedure, insuring bearing play is minimalized.
Hope this helps.
Ed
Apr 16, 2009 | Schwinn Mesa Gs Mountain Bike
Shimano Ultegra FC-6503 Logo
195 people viewed this question
Top Shimano Cycling Experts
Michial Gueffroy
john h
Paul Bade
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
