Question about Jacuzzi Water Rainbow Tub Faucet T582/T581-805
I need to remove the faucet handle from the Water Rainbow fill assembly because it is in the way of my replacement of the Flow Control Handle. I have the cap off and screw out, but it is not lifting off. The parts list shows a gasket under the handle. How do I get the handle off and leave everything else in place?? I don't want water gushing everywhere and the builder didn't put in an access panel! Thank you, V James
4 Suggested Answers
  • 80 Answers
SOURCE: "Jacuzzi j-400 series" hot tub- F1 code flashes on control panel
There are two things you can check, there is a tranformer that plugs into the main circuit board(usually a four wire plug). Unplug and check pins for good connection and then reconnect There are usually one or two fuses inside the control box mounted on or near the circuit board. Turn off power to spa and pull fuses and check continunity. This is a good start.
Posted on Aug 19, 2009
  • 7 Answers
SOURCE: leaking hotwater from the tap
You have two options. You can either replace the faucets- which is much easier for a novice, or you can rebuild them. As far as removing the handles, double check and make sure there is no set screw. If there is not, then the handles should come off. You may have to gently rock each one from side to side. Once you get the handles off, you should see where the valve unscrews. Now would be a good time to turn off the main water going to the tub. Once that is done carefully unscrew the valves and remove them. Take this to Lowes or Home Depot and you should be able to find repacking kits. They usually have full installation instructions included.
Posted on Sep 27, 2009
Testimonial: "GreaT"
  • 16326 Answers
SOURCE: how do i install an jacuzzi that has no faucet
either mount on wall or need to drill holes through jacuzzi 99 % of tubs dont come with faucets
Posted on Apr 25, 2010
Have crane tap set , two taps and a spout with an in and out lever to shower or fill tub.I have no cold water when tap set is in place, when i remove the tap set from the fixture i have water flow.
Look inside the faucet handle for damage. A cracked handle would need replacing, as it cannot grip the faucet stem. If the ridges inside the handle are worn, the handle cannot connect with the stem and control the faucet.
Inspect the end of the faucet stem for damage. The tip of the stem should have ridges that connect with the ridges inside the faucet handle
Nov 08, 2016 | Home
Tip
How to repair disc-type faucets
DISC-TYPE FAUCETS
  • Disc faucets may have one or two handles. The water is controlled by openings in the two discs. When the discs are rotated to align, the water flows; when the discs are misaligned, the water shuts off. If the discs wear, the worn discs cause the faucet to leak. Simply turning the handles harder will not stop the leak.
  • To repair a leak in a two-handle disc faucet, turn off the water and remove the handle on the side that's leaking.
  • Use pliers to pull the disc assembly out of the faucet.
  • Beneath the disc unit is the seat assembly, or seal. Replacing this special O-ring may stop the leak.
  • You may need to install a whole new disc assembly for faucets that have been used over a long period of time. In this case, all moving parts of the faucet will have been replaced and should last as long as the original discs did. The parts of some disc units snap apart into a separate bonnet assembly and bottom cap.
  • To repair a leaking single-handle disc, turn off both the hot and cold water and remove the handle to expose the disc assembly. Take out the screws to lift the assembly out of the faucet.
  • You'll notice that beneath the disc unit are three O-ring seals. Though unlikely, water could be leaking between the unit and one of these seals. In this case, you may be able to stop the leak by cleaning the disc assembly and faucet body and installing a new set of seals. If that doesn't work, the entire disc unit must be replaced. This will renew all moving parts.
  • Replacing the unit is fairly simple. Place the three O-rings into their recesses in the bottom of the disc unit. Then install the unit and tighten the screws. Finally, replace the handle–and you're done!
on Jan 16, 2010 | Plumbing
`hot water spout handle not fully opening
When opening the faucet if the flow is not as it used to be, there could be a couple of reasons. First the machine may not be filling correctly. Check the fill probe is clean and free of scale.
The most likely scenario is that the rubber seal within the faucet has become detached and is therefor not lifting correctly. You will need to contact your local Bunnomatic service agent to either request a repair or get the seal to fit yourself. Remember to drain water out of the boiler with the machine switched off, and ensure there is no flow from the faucet before you remove the top section of the faucet to replace the seal
bb4a0281-cb42-4d60-98d7-98e5258fd47d.jpg 66a2710c-cd82-4a2e-ab14-31eb46f75843.jpg
Jan 24, 2013 | Bunn Dual TF DBC Coffee Maker
HOW DO I INSTALL A SEAL KIT
A metal ball controls the temperature and flow of water from the spout in the vast majority of Delta single-lever faucets. That ball rests on three rubber seals, each seal suspending the ball with a single spring. Over time, wear on the seals, the springs and even the ball itself typically results in leaks. Thankfully, repairing the faucet is relatively simple, and Delta even makes repair kits with the replacement parts needed for each model.
Turn off the valve that controls the main water supply. The valve is located next to the water meter, inside or outside the house, and must be twisted in a clockwise direction.
Remove the plastic cap from the center of the faucet's handle by prying the cap free with the blade of a dull knife or a flat-head screwdriver, then remove the screw in the center of the faucet handle with a Phillips-head screwdriver. Pull the handle off the faucet assembly to remove it
  • Remove the single bonnet nut that surrounds the faucet valve with an adjustable wrench. Grip the bonnet nut at the base, which is ribbed to give the wrench a surface to grasp, and turn in a counterclockwise direction to remove it.
  • Remove the circular, white plastic cam that surrounds the top of the faucet, pulling it off and revealing a rubber seal, which you also remove. Next, pull the metal ball out of the faucet assembly and pry out the ball's supporting rubber seals and their springs with a screwdriver (the springs slide onto the bottom of each seal, so they will come out along with the seals).
  • Slide one replacement spring onto each of the three replacement seals that come with the Delta repair kit for your faucet model, then insert each seal into the assembly. Insert the replacement ball from the repair kit, then cap it by putting the replacement rubber seal over the ball, followed by the plastic cam
  • Place the bonnet nut over the faucet valve, then tighten the nut with an adjustable wrench. Position the handle onto the end of the faucet, then insert a screw into the center of the handle, tighten it with a Phillips-head screwdriver and, finally, press the decorative plastic cap over the screw.
  • Turn on the valve that controls the main water supply by twisting the valve in a counterclockwise direction to complete the repair
  • Jan 28, 2011 | Delta & Single Handle Shower Faucet
    How do you remove Jacuzzi Waterfall handles to get to the valve. There are no visible screws??
    On the top of each handle you will need a very small flat head screwdriver or something similar to "pop" the top cap off. Under that cap there is a phillips head screw so you can remove the handle.
    Jan 10, 2011 | Jacuzzi Water Rainbow Tub Faucet ...
    I have a Grohe Ladylux plus kitchen faucet very similar to this one, when I turn the water on there is a slight clunk and the water flow decreases. I am assuming I need a new valve but I havent' been able...
    Before you start taking the whole faucet apart try taking the airiator or head of the end of the faucet. It may just be some sediment blocking the filter screen on the head. Unscrew the head and see if the water flows with the head off.
    Jun 12, 2010 | Grohe Ladylux Cafe Faucet with PullOut...
    Handle is loose water flow weak
    to tighten handle, you hold lever(top of handle) while unscrewing round piece below, entire assembly should come off.look down and should be screw down there, tighten it up. flow problem could be the areator, unscrew and clean if need'd. check supply tube's,shut off valve's, (if you have them)make sure they are wide open.
    Mar 22, 2010 | Moen Bathroom Sink Faucet - 4-inch...
    Kohler Fairfax single control kitchen sink faucet
    Remove the air-irater at the end of the faucet where the water comes out. That is where 99% of clog are on faucets. If that does not do it then you need to replace the cartridge.
    Good Luck and please rate 4 thumbs up for the free answer.
    Mar 19, 2010 | Kohler Fairfax Single Control Lavatory...
    THE SCALDGUARD ALLOWS VERY LITTLE HOT WATER HOW TO CHANGE TO BEABLE TO FILL TUB I HAVE A DELTA#T13220 I CAN'T THE HANDLE OF EITHER
    You probably need to adjust the faucet to give you hotter water.
    The other problem can be low water pressure... if your cold water pressure is low or there is a restriction in the line, it willl also restrict the hot water flow.
    Follow these instructions to pull the whole valve assembly out and check the water flow of the cold water with out anything in the valve body. This will tell you if the problem is in the piping of the valve.
    http://www.everyfaucet.com/Delta-T13220-DLT2970.html
    Page down to near the bottom and look for the PDF attachments. They will give you the details you need to take the faucer apart and amke the neccesary ajustments.
    I hope that this will help you to solve your problem!
    Thanks for using Fixya!!
    Heatman101
    Dec 09, 2009 | Delta & Single Handle Shower Faucet
    Low flow from Kohler K15160 spray kitchen sink faucet. If I take off the spray handle I can fill a jug through the hose alone (including the filter screen) in 15 seconds while with handle on the same...
    Are you sure the spray handle is allowing the valve to open enough to allow enough water through? The problem it seems like is physical or mechanical. I am assuming you get good water flow through the faucet itself.
    Mar 01, 2009 | Kohler Coralais Black Single-Control...
    Jacuzzi Water Rainbow Tub Faucet  T582/T581-805 Logo
    71 people viewed this question
    Top Jacuzzi Home Experts
    Mike
    john h
    armylifer
    Level 1 Expert
    Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
