Question about Refrigerators
Hi, I have a KitchenAid KSSS48QDX05 refrigerator. I am no longer getting water at the door or to ice maker. I am thinking the cause is a clogged water filter (ten years old, has never been changed). Could it be something else? In any case, I want to replace the water filter. Will I have to pull out the whole unit to get at this filter? I removed top and bottom grills, and no filter or water is visible. Thanks.
    Champion:
  • 239 Answers
There is no filter on your refrigerator. I suspect the valve is bad. It is located behind the lower kick plate and is easily replaced.
Kelly
Posted on Mar 27, 2011
KitchenAid KBFA25ERSS01 I replaced the water
if its computerized make sure someone didnt turn icemaker off check to make sure its in all the way
Oct 27, 2013 | KitchenAid KBFS25EVMS Stainless Steel...
Ice maker makes ice but freezes before it can be dispensed so the dispenser is always clogged with frozen ice. Cleaned out the ice maker and started over but same results. The temp is set at 38 for the...
Hi, The freezer should be "0", the possible clogging you have could be a leaking water valve or an over filling ice maker. I would have the ice maker checked for volume of water dispenser during harvest, should be 5.5 oz. (2/3 cup), if more the 6 oz. the ice maker is bad. If fails to stop filling or leaks/drips, replace the water valve behind the unit.
I hope this helps.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 27, 2011 | KitchenAid KBFA25ER Bottom Freezer French...
Discovered ice build up on bottom of freezer in side by side KitchenAid Superba. Figure it is a defrost drain clog.... How do clear the clog?
I have ice in the bottom of my freezer section also in an older one of these, but I have traced it down to some sort of leak in my ice maker line. It only occurs when the ice maker is making ice, and not when the ice tray is full. Mine also leaks through the front door seal and into the floor if I don't keep scraping out the ice from the bottom (to clear out the "reservoir" that holds the water till it turns to ice).
I came on this site looking for a way to locate the leak and get to it. You might try scraping out the ice and turning off the ice maker for a while and see if the ice no longer forms at the bottom. Then at least you have localized it a little!
Feb 09, 2011 | KitchenAid Superba KSRG25FK Side by Side...
Kenmore refrigerator ice maker not making ice. Could this be caused by an old, dirty or clogged filter cartridge?
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Aug 28, 2010 | KitchenAid KSCS25FKSS Side by Side...
Ice maker not working
heatman101
uiouio67
May 24, 2010 | KitchenAid Architect 25.3 Cu. Ft....
Kitchenaid refrigeratorice make no water
When the ice maker stops to fill with water ,check if the solenoid (dual valve) gets power (110 volts) ,if it does and won't open you have to replace it ,but if it doesn't get any power ,the problem is the ice maker itself.
Sep 04, 2009 | Refrigerators
Ours kitchenaid icemaker has stopped making ice. It makes a few very slowley. It has clogged up in the box a few times and we have taken it out and cleaned it out of the frozen pieces. Do we need a part?
hello. i can assist you.
If the ice maker is producing ice poorly--making small cubes or too few cubes--you probably have a clogged water line, a defective water-inlet valve, or a defective ice maker mold thermostat that isn't cycling properly. Check these:
  • The water line that's attached to the back of the refrigerator. Make sure you have good water flow. If the flow is poor, repair, clean, or replace the tubing or the shut-off valve that supplies the water.
  • The water-inlet valve. Replace it if it has failed.
  • Check the freezer temperature. If should be 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker mold thermostat. Make sure that it's cycling properly.
Jul 02, 2009 | KitchenAid 22.0 cu. ft. Side-By-Side...
Not making ice
Hi: Change or just remove the water filter first. As your water dispensing slowed that is a clue. If the water filter is that clogged it will cause a problem with the ice maker. Plus the water you drink is not filtered anymore. City water is being run through 2 years of crud. If you don't replace it just remove it. I hope this helps, Jeff
Jun 03, 2009 | Frigidaire FRS3R5EMB Side by Side...
KitchenAid door ice and water dispensers don't work
Hi
If  the ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate the solution as "FixYa" and revert for further assistance.
Thanks
Rylee
Mar 31, 2009 | KitchenAid KSRG22FK Side by Side...
Refrigerators Logo
129 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
