Question about HP Officejet 5610 All-In-One InkJet Printer
The print cartridge can not move - HP Officejet 5610 All-In-One InkJet Printer
  • 30 Answers
Turn on the printer then try to move it manually..
if it does not work turn it off and try to move the carrriage manually.
still does not work then do following steps...
1) connect printer directly to wall
2) remove the power chord from back of the printer and then press and hold down power button for 30 sec. release the button and plug in the power chord..
3) if still it does not work out then unplug the power chord from the back of the printer.. press and hold the pound(#) and number 6 key together. then without releasing the button plug in the power chord.. once the power chord is plugged in release the buttons.. the printer would align .. if still it does not work then replace the product as it is an issue with the carriage
Posted on Mar 26, 2011
I am looking for a color access door for a print carriage on an hp psc2210 all in one printer. (C8654A)
  1. If you are putting in a new cartridge, make sure to remove the tape.
  2. Turn on the unit, then open the print carriage access door. The print carriage moves to the center of the unit.
  3. Fit the cartridge into the proper carriage.
    • The carriage with the gray latch is for the black ink cartridge (HP 56), or the optional photo cartridge (HP 58).
    • The carriage with the blue latch is for the tri-color cartridge (HP 57).
    Slide the cartridge into the carriage at a slight angle, as shown in the illustration above. When the cartridge is fully inserted into the carriage, rock it upright.
  4. Hold the hinged flap of the latch out while lowering the latch.
  5. When the latch is fully lowered, release the hinged flap. It should catch under the tabs on the carriage, as shown in the illustration.
  6. Close the cartridge access door.
  7. The LCD display may indicate that the cartridges need to be aligned. Press Enter on the front panel. You may discard the alignment page that prints.
Remove cartridges
  1. Turn on the unit, then open the print carriage access door. The print carriage moves to the center of the unit.
  2. Press down lightly on the top of each ink cartridge latch and pull the lower section of the latch out to release the cartridge.
  3. Pull the cartridge out of the print carriage and relatch the empty print carriage. The print carriage may move to the right automatically, and if the latch is up, it could be damaged.
Aug 23, 2011 | HP PSC 2210 All-In-One InkJet Printer
My hp d2360 is not working properly and i bought new cartridge but printer wasnt recognize the cartrige..
Please follow the steps below to install the Cartridge:
Install or replace the print cartridges
  1. Turn the printer on. The cartridge cradle will not move if the power is not on.
  2. Open the printer cover. Figure 1: Printer cover openc00658567.gif
  3. Wait until the print cartridge cradle moves to the center of the printer and is idle and quiet.
  4. If you are replacing a print cartridge, press down on the print cartridge to be replaced, and then slide it out of the print cartridge cradle. If you are installing print cartridges for the first time, go to the next step.
    NOTE: HP recommends using a print cartridge protector to store an opened print cartridge for later use. Figure 2: Print cartridge being inserted into a print cartridge protectorc00658568.gif
  5. Remove the new print cartridge from its packaging and carefully remove the plastic tape. Hold the print cartridge so that the copper strips are on the bottom and facing toward the printer. Figure 3: Removing the protective tapec00658569.gif
    CAUTION: Do not touch the print cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections. Do not remove the copper strips. They are required electrical contacts. Figure 4: Print cartridge facing upc00658570.gif 1 - Ink nozzles 2 - Copper contacts
  6. Slide the print cartridge at a slight upward angle into the cradle until the cartridge snaps into place. Figure 5: Installing the print cartridgec00658571.gif
  7. Repeat steps 3-4 for the remaining print cartridge.
  8. Close the printer cover. The printer automatically prints a calibration page.
Mar 07, 2011 | HP Deskjet D2360 InkJet Printer
My printer is showing an E sign, and flashing lights next to the ink symbols, but I have changed both cartridges
Issue : One or both Check Print Cartridge lights are blinking. On light Resume light Check Print Cartridge light Paper Type lights On Off Blinking Off Figure 7: Check Print Cartridge light is blinkingc01058982.gif Cause 1
The print cartridge access door is open.
Solution 1
Make sure that the print cartridge access door is completely closed.
Figure 8: Close the print cartridge access doorc00858057.jpg Cause 2
The print cartridges are missing or not seated correctly.
Solution 2
  1. Open the print cartridge access door. Allow the carriage to move to the center of the product.
  2. Make sure that both print cartridges are installed. If one is missing, obtain a compatible print cartridge and install it in the slot. To check the cartridge compatibility for your product, go to HP SureSupply . To identify your cartridge type in a language other than English, click the language link that appears near the globe icon in the top right corner of your browser.
  3. Run a finger along the top of the print cartridges. If any are sticking up, gently press the print cartridge down and forward into the slot until it clicks into place.
  4. Close the print cartridge access door. If a new print cartridge is installed, the product automatically aligns the print cartridges.
  5. Try the print job again.
Cause 3
The plastic tape was not removed from the print cartridge.
Solution 3
  2. Gently press down on each print cartridge to release it and then slide each print cartridge away from the product, out of its slot.
  3. Turn the print cartridge over so that the ink nozzles are facing up and make sure that the plastic tape has been completely removed from the print cartridge. Remove any plastic tape that remains. CAUTION: Do not touch the ink nozzles or the copper-colored electrical contacts on the print cartridge.
  4. Slide each print cartridge into its slot and then gently press the cartridge down and forward until it clicks into place.
  5. Close the print cartridge access door and try the print job again.
Cause 4
The print cartridge is not intended for use in this HP All-in-One.
Solution 4
  3. Make a note of the number on the print cartridge label.
  4. To check the cartridge compatibility for your product, go to HP SureSupply . To identify your cartridge type in a language other than English, click the language link that appears near the globe icon in the top right corner of your browser.
  5. Make sure that each print cartridge is compatible with the product. If both are compatible, reinstall the print cartridges, close the print cartridge access door, and continue with the next solution. If the print cartridges are not compatible with the product, replace them with genuine HP print cartridges that are compatible with the product.
Cause 5
The print cartridges might be defective.
Solution 5
Replace the print cartridges with genuine HP print cartridges that are compatible with the product.
NOTE: The printer might be packaged with only a tri-color print cartridge.
If all of these steps have been completed and the lights continue to blink, continue to the Service the
Jul 21, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
How to change a cartridge on c4345
Installing new cartridge:
Remove cartridges:
Nov 26, 2008 | HP Office Equipment & Supplies
The print cartridge cradle cannot move.
"The print cartridge cradle cannot move."
I fixed this problem by disconnecting the power cord from the power-strip and connecting it directly into the wall. My printer was not getting enough voltage from the power-strip. I hope this helps.
Nov 18, 2008 | HP Photosmart C3180 All-In-One InkJet...
Ink cartridge carrier jam
If possible, shut off the printer completely and manually move the ink carriage to where the cartridges can be swapped out. turn it back on and try again. try to see if some mechanism that holds the missing cartridge in place has swung down and is bumping into something, preventing the carriage from moving past a certain point.
Aug 21, 2008 | Dell 926 All-In-One InkJet Printer
How do I install ink cartridge into HP Photosmart Model C4280 all in one printer. I purchased the black and colored cartridges but can't seem to find any info on how to install.
Step seven: Install the print cartridges
NOTE: The product must be on before you can insert the print cartridges.
  1. Open the print cartridge door. Figure 7: Opening the print cartridge door c00880893.jpg
  2. Make sure the print carriage moves to the right. If it does not move to the right, turn the device off, then turn it back on again.
  3. Open the packaging and remove the tape from both cartridges. Figure 8: Removing the tape c00880894.jpg CAUTION: Do not touch the copper-colored contacts or re-tape the cartridges.
  4. Hold the cartridges with the HP logo on top.
  5. Insert tri-color cartridge in the left cartridge slot and the black cartridge in the right cartridge slot . Figure 9: Inserting the print cartridges c00880895.jpgc00880896.jpg
  6. Push the cartridge firmly into the slot until it snaps into place.
  7. Close the print cartridge door.
Aug 17, 2008 | Office Equipment & Supplies
HP PSC 1300 All in one Printer
  1. Turn on the HP PSC and lower the print-carriage access door.
    The print carriage will move into the access area. Figure 1: Opening the print-carriage access door
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot.
      NOTE: The black cartridge is on the right side of the print carriage.
    Figure 2: Removing the print cartridge
      NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab.
      CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles.
    Figure 3: Removing the plastic tape
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place.
      CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle.
    Figure 4: Inserting the print cartridge
  5. Close the print-carriage access door.
Using a photo print cartridgegtabtop.gif To use the photo print cartridge, remove the black print cartridge and insert the photo print cartridge in its place.
The photo print cartridge can be purchased separately and will optimize the quality of printed photos.
With the tri-color print cartridge and photo print cartridge installed, you have a six-ink system, which provides enhanced quality photos. For printing regular text documents, use the black print cartridge.
Use a print cartridge protector to keep either print cartridge secure when it is not being used. Figure 5: Storing the print cartridge
c00034854.jpg 1 - Inserting the print cartridge
2 - Removing the print cartridge
Aligning the print cartridgesgtabtop.gif After installing or replacing a print cartridge, the HP PSC will automatically print a cartridge alignment page.
  1. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  2. Press Scan .
    The HP PSC will align the print cartridges. During the alignment the button LED will blink until the alignment is complete.
Aug 04, 2008 | HP PSC 1350 All-In-One Thermal Printer
Changing printer cartridges for HP Photosmart C4250 All-in- one
Pictures and Step-by-step here
  2. Remove the old cartridges, they will move into a position you can reach automatically.
  3. Make sure the print carriage moves to the right. If it does not move to the right, turn the device off, then turn it back on again.
  4. Open the packaging and remove the tape from both cartridges.
  5. Hold the cartridges with the HP logo on top.
  6. Insert tri-color cartridge in the left cartridge slot and the black cartridge in the right cartridge slot .
  7. Push the cartridge firmly into the slot until it snaps into place.
  8. Close the print cartridge door.
Hope this helps.
Jul 30, 2008 | HP Office Equipment & Supplies
Paper jam?
Check Paper light flashes but there isn't a paper related problem The check paper light may also flash if there are other problems. Verify the following conditions:
  • Verify that the print cartridge door is closed.
  • The print carriage may be jammed, follow these steps to correct the problem:
    1. Open the print cartridge access door. If the print carriage can move, it should move to center. If the print carriage stays all the way left, unplug the power cord and then plug it back in. This will reset the unit and may allow the print carriage to move from the left.
    2. Disconnect the power cord from the all-in-one.
    3. Remove both print cartridges.
    4. Move the print carriage left and right slightly to verify that the print carriage will move freely. If the print carriage will not move freely, check for obstructions.
    5. Close the print cartridge access door.
    6. Plug the power cord back in.
    7. After the all-in-one initializes, the print cartridge light will flash. Open the access door and install the print cartridges.
    8. Close the print cartridge access door. If the problem returns, remove the print cartridges and wipe the electrical contacts before reinstalling them.
  • Try to make a copy. If the all-in-one pulls in paper but cannot make a copy, there may be a problem with the scanner mechanism. Contact HP for assistance.
Nov 01, 2007 | HP PSC 1410 All-In-One InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
49 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
