Question about Briggs & Stratton Garden
Oil type, oil filter, air filter, spark plug for a 17.5hp B&S engine?
  • 755 Answers
What do I need done to my 2010 mitsubishi endeavor it is at 109,000 miles.
replace the timing belt , crank and cam shaft seal , hydraulic belt adjuster and idler pulleys ( 100,000 km limit)
rest of the service as per the service manual
if automatic . change the auto oil and if CV Transmission check with the dealer as the transmission oil to use as it is different to automatic oil
Nov 12, 2017 | Mitsubishi Cars & Trucks
22' snapper walk behind mowewont start .cleaned spark plug and still wont start .swapped spark plugs from another mower that does work and the other mower starts with the snapper mower's spark plug .
You need several things for a running internal combustion engine:
  • Air
  • Spark (to start)
  • Fuel
  • Compression
  • Lubrication
  • Exhaust.
You've shown that you have a workable spark plug so far. Going from the above, consider as well
  • Fuel. Bad / old / contaminated fuel. Clogged fuel filter. If it's a motor that needs gas/oil mix, does your gas have the right oil mix?
  • Air: Dirty, clogged air filter or air inlet.
  • Spark. Is any electricity making it to that proven-workable spark plug?
  • Compression. For this one, the most likely problem (other than a toss-the-engine thing like a broken piston) would be if the spark plug is not tightened into the mount hole, allowing the air to leak out rather than compress.
  • Exhaust. Most lawn mowers will have a spark arrestor on the exhaust to make sure you don't set a dry yard on fire with your exhaust. It's often overlooked in diagnosing two-stroke engines. Make sure it's not clogged or blocked.
  • Lubrication. Is there oil of the right type, and up to a proper level on the dipstick. No oil equals way too much friction in the engine.
Good Luck!
DH
Apr 25, 2016 | Snapper Garden
I have a 1990 mitsubishi might max it wont run smooth unless you keep your foot on the gas and keep the rpms up a little bit and it wont drive cause it stalls everytime you try to move it. ive replaced the...
You've already eliminated the spark plug & wireset, distributor cap & rotor.
Sounds like your car needs a tune-up, specifically, the PCV (positive crankcase ventilation) valve, and/of the EGR (Exhaust Gas Recirculation) valve.
Components checked/replaced during a tune-up are:
air filter
motor oil
motor oil filter
breather filter
fuel filter(s)
fuel strainer
PCV valve
EGR valve
spark plugs
spark plug wires
ECM or distributor cap & rotor
cabin air filter
transmission oil filter
transmission oil
engine coolant
check all vacuum hoses and lines
Troubleshooting the no-start condition - from the 1990 Mitsu Mighty Max Repair Manual:
Priority Action Part Type -- Cause
1 Inspect Battery -- Battery Discharged or Faulty.
2 Inspect Battery Cable -- Corroded, Broken, Shorted or Poorly Connected Battery Cable.
3 Inspect Distributor Cap -- Distributor Cap Cracked or Burned.
3 Inspect Fuel Filter -- Clogged or Dirty Fuel Filter.
5 Inspect Ignition Coil -- Faulty Ignition Coil.
6 Inspect Wireset -- Worn, Damaged or Faulty Spark Plug Wire(s).
7 Inspect Spark Plug -- Incorrectly Gapped or Fouled Spark Plug(s).
8 Inspect Starter -- Starter Motor Faulty.
9 Inspect Fuel Pump -- Low Fuel Pressure.
10 Inspect Solenoid Switch -- Faulty Starter Solenoid Switch.
11 Inspect Fuel Pump Relay -- Faulty Fuel Pump Relay.
12 Inspect Fuel Injector Pressure Regulator -- Faulty Fuel Injector Pressure Regulator.
13 Inspect Ignition Switch -- Improperly Connected or Faulty Ignition Switch.
14 Inspect Starter Drive -- Faulty Starter Drive.
15 Inspect Fuel Injector -- Dirty or Worn Fuel Injectors.
16 Inspect Fuel Pump Strainer -- Clogged or Dirty Fuel Pump Strainerat.
17 Inspect Engine Control Computer -- Incorrect Operating Information Being Delivered and Sent From The EEC.
18 Inspect Fuel Tank -- Fuel Tank Empty.
19 Inspect Carburetor -- Carburetor Flooded or Faulty Choke.
20 Inspect Distributor -- Worn, Loose, or Incorrectly Installed Distributor.
Aug 17, 2011 | 1993 Mitsubishi Mighty Max
What parts do i needed for a tune up on a kia 2004 saoda
write down the manufacture date the vin number engine type and capacity eg1.5,1.8,2.0 armed with this info head down to your parts shop you will need. oil correct grade for your car 5litres will be more than enough or just right for 4 cyl. oil filter spark plugs some cars use irridium or platinum with some cars these do have standard equivilant that are cheeper fuel filter air filter a can of throttle body cleaner to clean the throttle body jack up the car sit it on stands never trust a jack remove the drain plug from the sump drain the oil into suitable dish or container and dispose of it responsibly replace the sump plug and tighten it firm locate and remove oil filter fit new filter spin it on then tighten by hand half a turn locate and change fuel filter dont forget to inspect filters for leaks when service is finished add new oil to correct level start engine run til oil light has gone out swich off recheck oil level remove spark plug leads mark them or do one at atime change spark plug put leads back on open air box remove old filter loosen clamp on air intake where it fits on to engine at throttle body move out of the way hold butterfly open and spray with cleaner to remove built up deposits a small bottle brush is good to get inside refit the air intake pipe and filter the cleaner will make the engine run a bit rough you may have to wind it a bit to start it it will clear itself after running for a short time be shaw to refit any plugs or connectors and pipes
Apr 06, 2011 | 2004 Kia Sedona
What does a major tune up for a 2004 chevy impala consist of? What should be done and needs to be done?
New spark plugs, oil and oil filter, transmission flush and fill, fuel filter, air filter, coolant flush and fill, clean throttle body plate and bore, clean the MAF sensor, replace any loose or cracked vacuum lines, PCV valve, new air filter, new battery.
99% of the time all you should ever need for a tune up is new spark plugs, and a clean air filter and throttle body. But since your inquiry indicated "major" I gave it more critical thought.
Feb 18, 2011 | Chevrolet Impala Cars & Trucks
What does the b14 maintenance code mean for a 2006 honda pilot?
Maintenance Codes:
A - Replace just engine oil
B - Replace engine oil & filter
1. Rotate tires & check air pressure
2. Replace air cleaner element, check drive belt and replace dust & pollen filter
3. Replace Transmission fluid & transfer fluid (if equipped)
4. Replace spark plugs, timing belt, inspect water pump, valve adjustment
5. Replace engine coolant
6. Replace rear differential fluid
If you have a B14, it's B, 1, 4 as in the list
Oct 06, 2010 | 2007 Honda Pilot
How often should I change the Transmission fluid, normal driving ? Thank you Gary
It's listed in your owner's manual. Schedule A is normal driving conditions.
SCHEDULE "A"
7,500 miles (12 000km) or at 6 months
- Change engine oil.
- Replace engine oil filter.
15,000 miles (24 000km) or at 12 months
22,500 miles (36 000km) or at 18 months
- Inspect front wheel bearings.
- Inspect brake linings.
30,000 miles (48 000km) or at 24 months
- Replace engine air cleaner filter.
- Replace spark plugs.
- Drain and refill automatic transmission fluid and filter (4.7L).
37,500 miles (60 000km) or at 30 months
- Drain and refill automatic transmission fluid and filter (5.2L/5.9L).
- Drain and refill transfer case fluid.
45,000 miles (72 000km) or at 36 months
- Flush and replace engine coolant at 36 months, regardless of mileage.
52,500 miles (84 000km) or at 42 months
- Flush and replace engine coolant if not done at 46 months.
60,000 miles (96 000km) or at 48 months
- Replace ignition cables (5.2L/5.9L).
- Inspect PCV valve, replace as necessary.
- Inspect auto tension drive belt and replace as necessary (5.2L/5.9L).
- Drain and refill automatic transmission fluid (4.7L).
67,500 miles (108 000km) or at 54 months
75,000 miles (120 000km) or at 60 months
- Drain and refill transfer case.
- Flush and replace engine coolant if it has been 30,000miles (48 000km) or 24 months since last change.
- Inspect auto tension drive belt and replace if required.
82,500 miles (132 000km) or at 66 months
90,000 miles (144 000km) or at 72 months
- Inspect auto tension drive belt and replace as necessary.
97,500 miles (156 000km) or at 78 months
105,000 miles (168 000km) or at 84 months
- Flush and replace engine coolant if it has been 30,000 miles (48 000km) or 24 months since last change.
112,500 miles (181 000km) or at 90 months
120,000 miles (192 000km) or at 96 months
Thanks for using FixYa -a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 05, 2010 | 2001 Dodge Durango
Drove 96 dodge caravan thru a flash flooded roadway. had to make a quick a quick stop, van died. Have replaced starter because of grinding upon trying to start. Now it just makes one click when trying to...
Check cables must be tight at battery & starter. You must have 12 volts coming out of battery to starter.
Pull your dip stick is it over filled or milky looking. If so you very likely have water in engine.
Can you turn the fly wheel or is the engine locked up?
Drain the oil replace filter remove spark plugs turn engine backward to unlock engine. Drain fuel and replace fuel filter. Remove air filter has it gotten wet? Now crank it over with Air filter & spark plugs out. Now put in new air filter spark plugs dry wires & coils. And start the car, If car starts don't drive drain transmission change filter. If it did not start you may have done damage to computer or wiring.
But you got to see if engine is locked up if 12 volts is to starter & that no water is in oil or fuel.
May 31, 2010 | 1996 Dodge Grand Caravan
What parts should I buy to tune up my 2001 sls
Spark plugs,the ones it calls for,not plain spark plugs,and spark plug boots,fuel filter,and air filter,and pcv valve.
Mar 06, 2010 | 2001 Cadillac Seville
Reduced engine power
New fuel filter, Spark Plugs & Wires, New air filter.
Tires at max cold psi.
Use a bottle of injector cleaner and change oil every 3k
Aug 19, 2009 | 2002 GMC Envoy
Garden Logo
37 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
