Question about Craftsman 21 Hp 42" Lawn Tractor Riding Mower Warranty
What are the engine bolt (mounting to frame) on a craftsman 21hp twin engine riding mower
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
  • 6 Answers
SOURCE: Craftsman riding mower loose belts need tighting
http://www.disruptit.com/manuals/L0403195.pdf
Here ya go.
  • 81 Answers
SOURCE: i started my craftsman 21hp 42in deck today it had
Backfiring is a sign of too rich on gas and not enough air. Not enough gas will cause the mower to bog down when blades are engaged as it isn't powerful enough to run the motor AND turn the blades. Check your carb and see if you need to clean it and replace diaphgram. Sounds a lot like a carb problem.
Posted on Jun 22, 2009
wadembly
  • 513 Answers
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Posted on Jun 28, 2009
  • 110 Answers
SOURCE: I need to find mounting bolts, blade to shaft
Do you meanengine mounting bolts, blade boss, and 'Operator Presence Control' cable? If so, they are generic parts - not specific to your mower. I have no idea why you are having problems ordering them - they are consumable parts, and should be stock items for ant garden machinery repair outlet.
Posted on Sep 24, 2009
How to remove v twin engine from craftsman garden tractor
Most of these engines have 4 mounting bolts holding them to the frame. The problem is all of the other items you may have to remove, muffler, belts for deck and drive, throttle linkage, fuel lines etc.
Oct 07, 2016 | Craftsman Garden
Can a Kawasaki FD611v be bolted to a craftsman frame?
Whendres an engine is to be bolted to a different frame, your first concern would be, the bolt holes, pattern on the frame, match with the engine pattern.... and then size of the holes... other than that, if you have the space on the new frame, then you're good to go...
Oct 10, 2015 | Craftsman Garden
Why is my 2012 21hp sears 42" lawn tractor blowing smoke
If it is a V twin Kohler engine, you may have a blown head gasket. It is a common issue. Great engine but has this one issue. Kohler has a head gasket kit with improved head bolts. Torque specs are included. You will need a inch pound torque wrench and common hand tools.
Jun 14, 2014 | Craftsman 20 hp 42 in. Deck Yard Tractor
I have an model 917259560 with a working engine but shot frame, i also have a model 917276010 with a shot engine but great frame. Can I change the engine from one model to the other?
Assuming they both have B&S engines, get the engine numbers and find the B&S website. Google helps. On that site if you are patient enough you will find the physical specs for both engines, if the mounting holes and drive shafts are the same go ahead and bolt it in. Most lawn tractors have similar engine mounting holes, so the real issue will be the drive shaft dimensions.
Aug 11, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Have crafstman riding lawn mower: replaced battery, ignition switch, solenoid, and spark plug but it still will not crank and start up. what is the problem?
double check the ground wire going from the battery terminal to the engine...it is usually on a mount bolt at the engine...if the mount bolt is loose, it's a poor connection...
Apr 25, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Need manual for craftsman LT1000 21hp v-twin 42 inch
Go to craftsman website. They offer manuals, but you have to buy them.
Or; Look on ebay.
Aug 23, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
How to replace the drive belat on craftsman 917273280, 21hp, 48 in cut?
you remove shield from engine remove belt, remove deck from mower and remove pulley guards and install belt replace guards , reinstall deck, put belt on engine pulley replace guard
Jul 07, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 21 Hp 42" Lawn Tractor Riding Mower Warranty Logo
139 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
