Question about Xantrex Technology Xantrex Trace Series Inverter/Charger - 1500 Watt, 24 Volt, Model# TR1524-1
Xantrex dr 2424e i need your diagram shematic, so, buy components.... thanks. carmelito
Issues with xantrex dr series inverter
Make sure the battery connection is solid, if the 12 V collapses at the inverter -> no power. If that is OK, make sure to apply first a known good load, like a light bulb, if that still causes a problem the inverter is broken :-(
Apr 19, 2014 | Xantrex Technology Xantrex DR Series...
Need shematic diagram for asus 1215n
There are none available only the repair manual and there is more information than that on utube.
Feb 26, 2014 | ASUS Eee Computers & Internet
Where can I get PCB for my xantrex DR Series power inverter. PCB number is 39cx3yM. I'm in Tanzania.
Officially Xantrex has the position of Note: In order to protect our intellectual property, Xantrex does not release schematics, part lists or wiring diagrams to the public. Xantrex does not sell internal parts to the public. If you need an internal part replaced, your inverter will need to be serviced by an Authorized Service Center or at the Xantrex factory.
So your options are to ship it to an authorized Xantrex repair depot, or reapair it based on electrical knowledge in general
If you decide the latter approach, you have to see if there are any IC's or other semiconductors you can identify. If they are true sine wave inverters- the wave form genesis is what counts- you will have to locate the low frequency oscillator, if it will power up and you have an oscilliscope. you can see if the waveform genesis is a square wave originally, triangle wave or a sine wave. essentially move through the traces to see where the signal goes away. your failure point will be close.
If the original waveform is sine wave, applying class A, AB or B audio amplifier principles should allow you to effect repair.
If the original waveform was square wave or triangle wave- the wave form is shaped by an LC network. Depending on what sized Capacitors and inductors are inside of the cabinet will determine where the sinewave form was achieved. If they are physically small, the waveform was shaped off the Pulse Width modulation circuit, audio amplifier principles should apply in the circuit trace and troubleshooting with the scope.
if they are physically large- the waveform is shaped at the output device(s) Usually an IGBT or power darlington..
If you are working with a modified sine wave inverter, the principles and block diagram is similar to a Class D audio amplifier or a crude AM transmitter with none of the pass filters (oversimplification perhaps)
this ought to be either enough of a start or enough of an outline for you to determine how you want to proceed.
Dec 30, 2011 | Electronics - Others
I need a control board.
You could buy the control board from :-
http://cgi.ebay.com/Xantrex-Inverter-Repair-Board-DR3624-Control-Board-/260652658387?pt=LH_DefaultDomain_0
I hope i have been helpful.
Thank you!!
Aug 21, 2010 | Xantrex Technology DR3624 Inverter/Charger
Can the input voltage be changed in the field?
Yes you can. Then it would now operate on 12 volts.
May 26, 2009 | Xantrex Technology Xantrex DR Series...
Have a whirlpool MH3184XPS-3 and need a shematic wiring diagram
Found a "schematic " diagram of electrical lay out and repaired the associated problem of being mis wired.
May 01, 2009 | Whirlpool MH3184XP Microwave Oven
Xantrex Technology Xantrex Trace Series Inverter/Charger - 1500 Watt, 24 Volt, Model# TR1524-1 Logo
123 people viewed this question
Top Xantrex Technology Electronics - Others Experts
Craig Butler
Craig Butler
EE Eddie
Are you a Xantrex Technology Electronics - Other Expert? Answer questions, earn points and help others
