Question about Motorola Mobility Z9 Cellular Phone
I only have had my Motorola Z9 for two weeks and it just turned off of me the other day, when it had a full charge. I tried taking out the battery and putting it back in and keeping it plugged into the charger for a period of time and it still won't work. When I press the power button the AT&T screen comes on but then it goes dead again.
  • 902 Answers
Try taking the battery out plugging in the phone to the charger see if it turns on if it does then plug in the battery . let me know if that worked i have other ideas but thats a start
Posted on Mar 26, 2011
Unlock motorola z9
Using codes you can unlock your mobile because its safe for your mobile.......
Get the unlock code for your motorola Z9 model mobile here Simpleunlocking.com , it gives the easy instructions to get your mobile as unlocked........
Dec 15, 2011 | Motorola Mobility Z9 Cellular Phone
Motorola RDU2080D Short Battery Life
Short battery life can be due to several factors:
1) Short initial charge(s) when the battery was new.
2) Age of battery. Check your date code embossed on the lower portion of the battery below the label. On a three digit code the first number is the year, next two are the week of the year. If a four digit code the first two are the year. Example 142 is 2011 the 42nd week. OR 1142 if a 4-digit code. If you battery is more than 18-24 months old it likely needs replaced.
3) Short charging the battery by putting the radio on the charge too often, or with the radio turned on. Always turn the radio off when charging.
4) Poor connection with the charger. Clean your battery contacts on both the radio and the charger with a pencil eraser.
5) Excessive talking. Heavy talkers radios will run down quickly. It takes more energy to Transmit than to Receive. Using the 5/5/90 rule, your battery should go an 8 hr business day.
Note: There are 3 battery styles available for your radio. The one which comes with the radio is a 1100 mAH battery. There are also two others with higher capacities available.
Best regards.
Oct 26, 2011 | Motorola RDU2080d Two Way Radio
Turn it on, the screen says ATT then shuts off
Check the battery if it needs to be replaced. Borrow same phone from a friend and use your battery on the other phone and check if it will turn on or will just do the same thing and shut off after the ATT... if it did the same thing...replace your battery.
May 12, 2010 | Motorola Mobility Z9 Cellular Phone
Motorola motokrazr i cried on while talking to a
Ok some moisture has got into your phone.
Take the battery compartment cover off and rmove battery dry both.
Take phone and parts into a warm room and leave for 2-3 hrs .Dont put on a radiator.
Then reconnect and try.Charge to full , replace battery and cover. Fingers crossed for you.
Dec 23, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Battery 3 bars full but won't charge when plugged in.
How old is the battery? I had to get a new one for my phone...not that expensive. Do you let the battery go dead once in awhile?...if not, you should. The li-ion batteries are better than the nicads, but still a good idea. I left mine on all the time, and was told to turn it off at least twice a week...and to charge it from dead to full...with phone off...every 1 or 2 months. finally, Try typing *228, and send. Select option 2 -- updating your roaming capibilities. The phone will go through a sequence of unlocking and reprogramming...DO NOT SHUT THE PHONE OFF DURING THIS PROCESS. It only takes a couple of minutes...or less...and will notify you that the phone was successfully updated. Had two people tell me that for some reason, this helped restore some battery capacity.
Dec 15, 2009 | Motorola Mobility RAZR V3
Okay I have the Motorola G9 and my buttons froze. What do I do?
try taking out the battery, and unplugging it from any power cords. keep it unpluged for about 5 min, and then put the battery in, maybe this will reset it.
please rate me
Nov 15, 2009 | Motorola Mobility Z9 Cellular Phone
Display turned off, but i can make and receive calls
If you take the battery out then with the battery out plug in the charger, this worked for me.
Jun 15, 2007 | Motorola Mobility RAZR V3
Motorola Mobility Z9 Cellular Phone Logo
112 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
