Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I can not get my remote for my sears 1/2hp door opener (1996) to program. The wall consoles and keypad work, but not the remote. I tried changing the batteries with no luck. Do I need a new remote? I have 2 garage doors and can't get it programmed for either one.
    President:
  • 3,197 Answers
Sounds like you need a new remote. Make sure you purchase the correct remote for your model opener. There are many that will not work.
Posted on Mar 28, 2011
How do I check a wireless garage door keypad, to see if it is transmitting?
These remotes don't loose the programming code when a battery goes dead, most likely the remote or the board on the opener went bad, do any other remotes work? You can take the remote to an auto parts store and test it there. (They have a tester for key fobs)
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mike_a0891ab86974ea74
Sep 24, 2014 | Sears Craftsman LiftMaster Chamberlain...
My craftman 139.52606 opener does not have a learn button to set pin on keypad. I had keypad working at one time but since I changed the battery I can't rember how to reset the keypad.I also changed...
If the keypad is hardwired, do this:
To program the keypad, first unplug the garage door opener from the electrical outlet. Next, remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next, enter your desired four-digit PIN number into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
Sep 02, 2011 | Sears Craftsman LiftMaster Chamberlain...
We have a new chamberlain door opener. The remotes work but it will not allow us to program a 4 digit number for the security code. We have tried using the Learn button and the wall mount button....
If you are trying to program an old keypad to work with a new opener they are not compatible. You will need to purchase the correct keypad for the new opener.
Apr 25, 2011 | Sears Craftsman LiftMaster Chamberlain...
The wired keypad (Chamberlain) of my garage door is not working. The red light on the keypad keeps blinking. Can someone tell me how to fix that? FYI, the garage opener, the remote, and the wall unit all...
You can try programming the keypad using the procedure below.
Mar 14, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a 3/4 hp model 139.53990D from sears. My reomtes have quit opening the door. they will close it. The light on the control console blinks very lightly, not like when the lock is set. Door works...
The symptoms you give are exactly the way it is when the lock function is used. The wall control and the keypad will work but not the hand remotes. If holding the lock button for 3 seconds doesn't change it you should hold in the smart/learn button for 6 seconds. This will erase all remotes from memory and only the wall control will work. Now program it for the remotes and the keypad.
Jan 21, 2011 | Sears Craftsman LiftMaster Chamberlain...
Remote works randomly,changed batteries now the
Keypad flashing is normal. Sounds like you may have a bad logic board. Try programming everything.
Dec 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keypad and remote will not open door
Did the remote and keypad work before you changed the battery? Changing the battery in the keypad should not affect the remote.
Jun 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears garage door keypad/remote programming problem
The button you added in your car is an earlier technology that is not compatible with the rolling code technology.
Apr 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener remote won't work
meerkat1 your receiver has quit working which is part of the logic board. The logic board runs around $80.00 for the part alone. Might be time to get a new opener.
Apr 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
166 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
